Question about Bose Lifestyle 12 System
Bose lifestyle 12 remote
Remote was lost for some months and i believe that the settings on the remote have been tampered with, I need to set the remote codes back to original in order to be able to hear my surround system.
  • 48 Answers
Dip switches are inside battery cover and should be as follows :
all in off position (lower / nearest side to battery) except switch number 5 which should be in the up or ON position.
other wise losing the remote for months should have no effect assuming the replacement batteries you have installed are in good condition.
Posted on Mar 09, 2008
The remote does not communicate with the amplifier
[PDF]The Bose® Lifestyle® SA-2 and SA-3 Stereo Amplifier Bose CorporationWARNING: To reduce the risk of fire or electrical shock, do not expose the product to.... ence to radio communications. ... Note: Unauthorized modification of the receiver or radio remote control .... Thank you for purchasing a Lifestyle® SA-2 or SA-3 stereoamplifier. ... Left and right channel line inputs for a local audio device.
[PDF]Owner's guide - Bose
Bose CorporationJan 4, 2002 - WARNING: To reduce the risk of fire or electric shock, do not expose the.... may cause harmful interference to radio communications. ... Connecting theLifestyle® stereo amplifier to a Model 5 music center . ..... Lifestyle® SA-1 stereoamplifier rear panel ... Setting up the RC-20 remote control for Zone 2.
Dec 29, 2015 | Bose Lifestyle SA-2 2-Channel Amplifier
I had Bose lifestyle V35, V20 try to link together. Bose link AL8 transmitter will not connect to receiver. both led is light solid green. Please help.
The commands for the Bose link system are actually going through the remote control system. In order to use the system you need not only a set of AL8 sender and receiver, but also a special remote control model RC48S2-40 these model numbers are slightly different for the US and for Europe. In addition you will need to activate the BoseLink connection through the system settings menu and you will need to tell the remote to which system it needs to talk. When you have done all that, there should not be any problem to "connect" the two systems. If this does not work, you may need some specialized help from a Bose specialist who understands this multi room set-up.
Nov 09, 2014 | Bose link AL8 wireless home-wide audio...
How to add secon subwoofer to my lifestyle bose system?
You cannot add a second sub woofer to your Bose system unless you are very well versed in electronics and would like to tamper with the internal electronics of the Bose module. Unlike other systems the 6 channel amplifier ( 5 + 1sub ) and its crossover electronics + power supply unit is built into the Bose bass module. The circuit uses very small surface mounted devices with double sided pcb ). And even a professional technician might refuse this work in fear that he may damage the whole unit itself !!!!.
Mar 19, 2011 | Bose Lifestyle 12 System
My base module doesn't work anymore , can i replace it with another brand or amplifier
There's a base unit on eBay for bid, currently around $90, expiring tonight at 15:45 PST
another $210 Buy-It-Now
$204 BIN...
Bose products are highly proprietary. If they have non-standard connectors from the amp or in the speakers I'd take that as a clue they're NOT compatible with other manufacturers' products.
Feb 02, 2011 | Bose Lifestyle 12 System
Can a remote for a Bose Lifestyles 18 system control a Bose Lifestyles 5 system?
Yes you should be able to. The house code needs to be the same etc (adjusted by the dip switches under the battery cover) Google for the pdf instructions on how to set them.
Nov 06, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
The remote for Bose lifestyle V20 system does not work with Apple TV. I have component video coming out of the Apple TV into the Bose V20 system and then HDMI from the Bose V20 to a Sony Bravia HDTV. I...
I had the same problem, and called Bose tech support. They put me on track to the solution. The code you need is under AUX, Music Player, Apple where you probably looked already. The secret is that you need to "unpair" the apple remote first. If I remeber right, in apple TV you go to settings, general, remotes and unpair your remote. It still works, but is no longer the only remote that works.
May 01, 2009 | Bose Lifestyle 20 System
Need v30 bose code for remote
Bose V 30 works on Radio frequency ............. so you need to have a unversal radio frequency remote conrol..... no IR (infrared) remote can control a bose lifestyle product..
why not use your bose radio frequency remote( the v 30 remote) to control the dvr plyer from motorola.. you can used the remote even to control your tv and other deices ..
all codes for your other systems are available in th e system settings option under remote control category to set up your system to control other devices
Feb 21, 2009 | Bose Lifestyle V30 Home Theater System -...
Lifestyle 12 receiver vs lifestyle 12 II
yes will work just fine, a slight difference in the output gain from the control baord, but in almost all other cases you wont know the difference. just make sure especially if you intend to use the old cd unit with the new bassbox that if you connect the digital source to to (say dvd player) that you initially use bose remote to turn on bass baox and set volume.
Jan 17, 2008 | Bose Lifestyle 12 System
Bose Lifestyle 12 System Logo
716 people viewed this question
Top Bose Audio Players & Recorders Experts
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
