Question about Ricoh Aficio AP3800C Laser Printer
I have 3 AP3800C printers - all of them say add toner black, even when i replace with a brand new original black cartridge.
I have tried blowing the pipes through and executed forced toner but have had no success.
Hope you can help
  • Mountainecho Jan 17, 2008
    thanks, but we've tried all that - the closest we've come to getting them going is replacing the PCU but the problem soon arises again after twenty or so prints. we've stripped the thing and blown the pipes through (which had worked in the past) but nothing!! it seems strange that it happens to so many of our printers. 3 out of seven of them have done it.
Tnx GURU, ur solution worked for me...
Posted on Jan 17, 2008
  • 417 Answers
If the toner is an original you should not have a problem unless the Developer unit is faulty. The developer unit mixes the toner with the dev. If the dev unit TD (Toner Density) sensor is not working then it will not add toner. Try the following.
  • Remove black drum unit
  • Remove Black Developer unit
  • Tap the develop unit and shake side to side 5-6 times
  • Reinstall both units close covers and open toner cover
  • wait 15 seconds then close the cover
Hopefully then you will add toner if not the likely thing is that the developer unit will need replacing.
Hope this helps
Thanks J
Posted on Jan 16, 2008
My cartridge is full of toner but the printer says it needs to be replaced, how do i reset the cartridge?
You can't. The toner levels are calculated and approximated. Make sure you use genuine Kyocera toner and replace it.
Sep 27, 2013 | Kyocera 1T05JK0US0 Model TK-152K Black...
The printer refused to print, while giving me a "replace black toner" message. The toner did not feel empty, but I replaced it anyway. There is a brand new toner in the printer, but I am still getting an...
it is a typical new problem for samsung printers. you have to reset the printer. it is a pretty tricky thing to reset this type of printers because you can "blow" it up. try find a local workshop, or a specialized person to do this
Jan 25, 2010 | Samsung CLP-510 Laser Printer
Will not add toner
Reinsert cartridge and restart it by unplugging or powering off
It should refresh the memory
Good Luck
Jan 29, 2009 | Gestetner DSm515pfd Digital Copier -...
Gestetner 3222
Open the front door and close it and check if the display reads loading toner. Try this for 3 times.
If Add toner indicator is still there, check that you had removed the black cap of the toner, before you replaced the toner bottle.
Remove the bottle from the holder and check inside the neck of the holder if there is something blocking the toner supply. (sometimes the inner plastic cap of the previous toner is stucked in the neck).
Check and clean the toner bottle holder unit.
Another problem can be worn gears in the lower development unit and within the dev. bias roller.
Good luck and please rate me, thanks.
Jan 27, 2009 | Gestetner DSm622sp Digital Imaging System
Add Black Toner Msg.
Try taking out the cartridge and reinstalling it. Was this a original ricoh toner cartridge or a el cheapo cartridge off the internet?
Mar 19, 2008 | Ricoh Aficio CL2000 Laser Printer
Toner problem
R u using gen OEM toners?
Dec 28, 2007 | Ricoh Aficio AP3800C Laser Printer
Add Toner
Your machine has got a toner pump on each of the colours wich transport the toner through pipes , these pipes get blocked and needs to be vacuumed out to clear the blockage .i got the service manuals if you need any further assistance
Nov 13, 2007 | Ricoh Aficio AP3800C Laser Printer
Ricoh Aficio AP3800C Laser Printer Logo
400 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
