Question about Car Audio & Video
Replaceing vectra 2002 window regulator
...just wondeed if ya can give me any assistance in changing the window regulator in the drivers door of my 2002 vectra gsi.....
any help would be appreciated...thanx---lee
  • seabo Jan 22, 2008
    sorted now mate,ended up takeing it to a garage and it was a dodgy solonoid in the motor.......
    thanks again for the advise though....
    New Friend:
  • 101 Answers
Get a repair manual on your model and make of car 1st. the syteps varies from car,to car.also get a door panel removal tool ,this helps with the snaps.must find locations of screws in door panel disconnect batery before any thing unplug window and lock panels. from there u can see the window motor assembly.im not familir with that model but in my experiences it could get complicated.depending how it is mounted.you might have to take out window,or mabye shim uopp the window.depending on how it is moanted .you might not have to do none of does things maybre moter is seperat from assembly/ overall i suggest chilton car repair guides.they give u step by step depending on type year and model of vehicle.when u say regulator ,did yiou mean relay ,or is that refering to the window AASSEMBLY.IF RELAY its probably not in door at all its usually under dash board
Posted on Jan 22, 2008
I need to replace window door motor and regulator, how do i go about doing so
Buy a Haynes repair guide and it gives you step by step instructions.
OR Try U-Tube type in your problem a lot of times people will post video onhow to. so its pretty easy....Good Luck to ya
Dec 02, 2010 | 2002 Chevrolet Suburban
I need instructions on how to replace power window motor for the front driver side window of a 2002 Grand Cherokee
Power Window Motor: Service and Repair
REMOVAL
1. Disconnect and isolate the battery negative cable.
2. Remove the window regulator from the door.
3. Place the window regulator on a suitable work surface and remove the screws that secure the power window motor to the window regulator.
4. Remove the power window motor from the window regulator.
INSTALLATION
1. Position the power window motor onto the window regulator.
2. Install and tighten the screws that secure the power window motor to the window regulator. Tighten the screws to 9 Nm (80 in. lbs.).
3. Install the window regulator onto the door.
4. Reconnect the battery negative cable.
Oct 30, 2009 | 2002 Jeep Grand Cherokee
How do I take the drivers door apart to replace the window motor?
It's easier to replace the motor and regulator than just the motor. www.rockauto.com sells them cheaper assembled than seperately. After you remove the door panel you can look at the regulator assy and figure out what to remove. You'll want someone there, a patient someone, to assist you by holding the glass for you when you remove the bolts. I remember taking the glass right out for some reason, then removing and reinstalling the regulator/motor assy, and then sliding the glass back in. It is kinda tricky and requires patience. Hope this helps,
Oct 09, 2009 | 2002 Chrysler Town & Country
I have a 2000 Dodge Durango. My rear window on the drivers side has come loose and slid down inside the door. I took the door apart and found an unatached cable but I dont know where it snaps back on? Any...
sounds like the window regulator broke,u will need to replace the whole assembly,sometimes u can get them without the motor and change over the motor from your old window regulator to save a little cash
Sep 05, 2009 | 2002 Dodge Dakota Club Cab
2002 pontiac Grand Prix power window off track , cable in bottom
autozone website has all you need for free tech tips and pics. just register its free. just changed my drivers side window regulator. go to partstrain.com. they sell the regulator (replace the whole thing it only costs about 60 bucks which includes shipping. only takes about 10 bolts which are all 10mm. takes about 30 minutes to change out the hardest thing is taking off the door panel. be advise there are 2 screws under the handle that hold the integrity of the door panel don't forget to take them out or you wont get door panel off. they have 2 little cover caps that need pried off with a screw driver. an easy job.
Aug 04, 2009 | 2002 Jeep Grand Cherokee
My drivers side electric window stop working 2002 ford sport trac. how do you change the motor
To remove the door panel, phillips head door screws should be removed, and the panel should slide up. Next, unbolt the window from the regulator and remove the window from the door. Then unbolt the regulator. The regulator and the motor have to be removed together. The motor will be mounted to the door on the inside. There should be three screws or nuts (10mm) holding the motor in. Remove motor and regulator. Reverse to reinstall.
Jul 11, 2009 | 2002 Ford Explorer Sport Trac
2003 ford taurus drivers window will not go up.
you either need a motor or motor and window regulator assembly.
SECTION 501-05: Interior Trim and Ornamentation 2002 Taurus/Sable Workshop Manual
REMOVAL AND INSTALLATION Front Door Trim Panel Removal and Installation
  1. Disconnect the battery ground cable. For additional information, refer to Section 414-01 .
  1. Remove the front door trim panel screws.
  1. NOTE: To release the door trim panel two part pin-type retainers, first pull outward on the bottom of the door trim panel.
    Remove the front door trim panel.
    • Disconnect the electrical connectors.
c64985a.gif --------------------------------------
SECTION 501-11: Glass, Frames and Mechanisms 2002 Taurus/Sable Workshop Manual
REMOVAL AND INSTALLATION Front Door Window Regulator And Motor
Special Tool(s) s2h~us~en~file=st1132a.gif~gen~ref.gif Heavy Duty Riveter
501-D011 (D80L-23200-A) or equivalent
  1. Remove the front door window glass. For additional information, refer to Front Door Window Glass in this section.
  1. Disconnect the front door window regulator motor electrical connector.
  1. Remove the window regulator rivets.
REMOVAL AND INSTALLATION Door Window Regulator Motor Removal and Installation
  1. Close the window.
  1. Remove the door trim panel. For additional information, refer to Section 501-05 .
  1. If equipped, remove the radio speaker.
  1. Position the watershield aside.
  1. Disconnect the door window regulator motor electrical connector.
  1. Remove the bolts and the door window regulator motor.
May 04, 2009 | Ford V6 Pony Cars & Trucks
My drivers side window fell inside my door. Once I removed the interior panel I found a bunch of broken Plastic Parts I need to know what to replace and have a visual to see how to reassemble.
O.K. getting the door off is a little tricky, Their is even a screw hid behind the little red reflector. You should be able to locate the rest. Once you get them out, the door pops off of those little white plugs in most new cars. After that you need to purchase a power window regulator. That is what broke that made your window fall in. It looks complicated, but it is only three or so bolts to change out. If you broke the window, Call around the salvage yards to try & locate a replacement. Don't forget to make sure you get one that has tinting if your was tinted.
Apr 22, 2009 | 2002 Pontiac Grand Am
Rear Driver Window Falls Down
You need to replace the window regulator. Easy DIY for about $100 in parts or pay dealer $500....
Jun 09, 2008 | 2002 Jeep Liberty
Car Audio & Video Logo
211 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
