Question about Technics SA-DX950 Receiver
Technics SH-AC300 Connection to Power Amp & Pre-Amp
I have a Technics Processor SH-AC300 & a Technics Power Amplifier (SE-A900s) & a Technics Stereo Control Pre-Amp (SU-C800U) & I want to connect these components together to work properly.
I have 2 Front Speakers, a centre, 2 Sourrounds & a subwoofer, so this Power Amp of mine don't have the outputs for the surrounds, sub & centres so I thought the processor would help but It doesn't seem like.
Please help.
  • 6561 Aug 30, 2008
    i need a connection cable between technics SE-A900S and SU-C800U, thank you
Hi!
The problem is, that your SH-AC300 needs an amp with 5.1 input (but no decoder). For this purpose technics delivered SA-AX710.
So if you'd like to use your current equipment it would be impossible.
The only option is for you to buy 2 more Power Amps (SE-A900S), so that each of 3 amps would take care for one part of music. (one for FL, FR; one for RL, RR; and one for sub and center).
Another option is for you to buy SA-AX710. Then all the problems would be solved with it.
Posted on Feb 24, 2008
Ok, i interested in the technics se a900s amplifier, just for vu meter use, not amplifier,and...
Pre-amp only needed for phono. Otherwise, line in is just fine.
10 to 20 ohm load resisters to substitute for speakers. get 50 watt rated ones at least, they can get hot....
May 12, 2016 | RCA Car Audio & Video
I will buy a Technics se a900s amplifier, but
I think you are saying you want to connect the amp and use it's vu meters but not connect it to speakers?
Presumably you are already well catered for in the matter of amplification but lacking good vu meters?
There is a fair amount of information about this premium amp online including operating and service manuals that can provide a better answer than I can.
One note of caution; it is generally bad practice to operate a power amplifier without a load at the output and it might damage the amplifier. If it is desired to operate it without speakers providing the load, dummy loads are available.
I suggest you have a look through ebay or Amazon where you might find digital or analogue vu meters at a reasonable cost or alternatively I believe computer software could turn your laptop into vu meters.
May 11, 2016 | Technics Audio Players & Recorders
Where can I get a free manual
go on panasonic website or google the manual you want.i use manuals lib
Jul 02, 2014 | Technics Audio Players & Recorders
How do I hook up a stereo reciver to the technics su-g91
I assume you want to use the SU-G91 as a power amplifier to drive your speakers. If your receiver has connections for inserting an equalizer (may be labeled pre-amp output and power amp input), remove the jumpers between the pre-amp and the power amp, then run cables from the pre-amp to the SU-G91 inputs. You can have an equalizer between the receiver and the integrated amplifier.
If this is not available, use the recording output (for a tape recorder on older receivers). Note that the volume control on the receiver will be bypassed with this connection.
Sep 23, 2012 | Audio Players & Recorders
Su-c800u pre-amp switching not steady, keep darting from one mode to another and disrupting smooth flow of music
I had the same issue.the contacts on selector switch is dirty.All u need to get a good contact cleaner and spray the selector rod( remove knob first with preamp facing up), the liguid will find leak into selector and clean contacts.
after doing mine, the slector knob feels more solid when turned and does not change input anymore.
Junior
Jan 14, 2012 | Technics Audio Players & Recorders
I am looking for the manuals for Technics SE-A808 Stereo Power Amplifier ST-K808 Quartz Synthesizer Stereo FM/AM Tuner/Preamp SH-R808 Infrared Wireless Remote Unit Kind Regards John
I don't believe that these are available electronically without cost. If you can describe the problem you are trying to solve, I may be able to guide you through the repair.
Dan
May 25, 2011 | Audio Players & Recorders
SL-BD22 SETUP
go to RADIO SHACK and get a pre amplifier module (hope its still available) , that will do the trick , AJ
May 20, 2009 | Technics SL-BD22 Turntable
No cable for technics
I had the same problem with my sua900s pre-amp.
If it's the same cable, you need a (I think 6 pin) mini din cable, male to male. It's sometimes called a PS2 cable (nothing to do with Play Station!). It's the same cable that runs from your mouse into your pc and is readily available for about £5 from online computer retailers. Check the number of pins first though!!
Feb 08, 2009 | Technics Audio Players & Recorders
Conect eq. with the turntable
hi there, first you have to pit your turntable phono at the pre - amp phono to amplified then after you can put now direct into your equalizer and then to your amplifier
Dec 30, 2008 | Spectrum Technical Hifi EQ-B5200...
Technics SA-DX950 Receiver Logo
2,039 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
