Question about Philips Brilliance 109S Monitor
Philips crt 201b4 monitor
Hello
i have recently begun having problems with my monitor the control menu intermitently comes up on the screen then goes without me pressing the menu button on the monitor itself any ideas ???
    Problem Solver:
  • 12 Answers
Your tactile buttons need to be changed.
Posted on Feb 21, 2011
Menu bar appears automatically in front of monitor and automatically uses it.
My SAMTRON monitor 56V is having a problem now..
The control menu of monitor settings which will appear
when the monitor control panel is pressed(Brightness,Contrast....) is coming frequently at my monitor without activation...
Now when the monitor is turned on, the control panel will come,and will not go even if we change the settings..
The control panel is switching between the CONTROL LOCK and UNLOCKED mode during each 5 seconds....So now I cant see anything on my screen
at the middle of the screen due to this overlaying settings panel.
I is giving the same effect as the Menu key is pressed in the panel..(exit,-,+,Menu).
This problem started some 2-3 months before..
Today I hav put some etylene cleaning solution through the gaps to clean from dust... still no change...
If somebody having a remedy please help me..
Sep 11, 2010 | Computers & Internet
Moniters menu comes up without pressing the menu button
You will need to 1. try to unstick the button on the front of the monitor or purchase a new monitor I had a Compaq 17" monitor do that to me and the button was stuck sideways Let me know if I can help out anymore
Mar 13, 2009 | Dell Dimension 4700 PC Desktop
Samsung SyncMaster 215tw screen goes black after about 1 sec.
I have the same problem its defenitly a problem with the lcd monitor not with the graphics card nor the pc. I hooked up the digital and afterwards the vga connection both had the same result. 1 s perfect screen all visible but than black. pushing the on/off or standby button again shortly 1s the display works than it blanks. Did the same test while connected to a dvd player via the composite video... same problem . Since the previous posts are that old and without a solution I guess there is no hope in getting it fixed.
Jan 20, 2009 | Samsung 215TW SyncMaster 21" LCD Monitor
No menu
One of the buttons on the front of your monitor is probably stuck.
(Only one of the buttons work at a time on most monitors)
I cannot recommend taking it apart your self (have a tech do it)
But take off the front, check the buttons after you take off the front, and if it still occurs unplug the buttons from the monitor.
If it stops (which it should) replace or fix the controls)
If it doesn't, call an exorcist (just joking) or buy a new monitor.
Mar 14, 2008 | iiyama Prolite E430 17" LCD Monitor
Monitor control lock problem
Replace the small 78L05 regulator 5V supply to micro.
Jan 13, 2008 | Computers & Internet
Blank screen (led indicator is orange)
it could be the cable from the monitor to the pc it is defactive try a new one cuz if the monitor works then it is the cable that is makeing your screen go blank
Oct 10, 2007 | IBM E74 17" CRT Monitor
Strange behavior
It think it needs to go back under warrenty, this should not be happening to a Monitor this "Young".
May 01, 2007 | NEC MultiSync 1940CX 19" LCD Monitor
Problem In Control Panel
near microprocessor change c945b transistor, this may help u
Sep 08, 2006 | SAMTRON 55V 15" CRT Monitor
Problem with Control Panel
It sounds like theres a front panel button that has become intermittant and making contact all by itself. Sometimes when you clean the screen, the cleaner will drip down between the crt face aqnd the cabinet and make the switch in front go bad. Im not sure if this is the case in your problem but its a start. If you didnt spill anything or drip anything into the front panel then your maicroprocessor could be causeing the problem, or the 5 volts that feed the micro could be noisy ie, bad filter capacitor in the power supply. Now as im sure your aware of the hi voltage inside these sets? Its best if you dont have the training to get a pro to assist you as this hi voltage can hang around inside the set even if its unplugged. Good Luck
Jul 03, 2006 | SAMTRON 55V 15" CRT Monitor
Philips Brilliance 109S Monitor Logo
184 people viewed this question
Top Philips Computers & Internet Experts
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
