Question about Recoton Advent Advent Q2035A 20" TV
Advent 7104 (EAA-88) laptop
Hi kind folks,
I need to replace a dc jack on the afore mentioned laptop and need to fnd the part number for it and if possible where to buy one! I am not sure if it also used in other models.
Thanks in advance
Scott
  • Anonymous Apr 14, 2008
    The DC Jack is smashed - trequires a new one
انا العوووووووووووووو
مصطفى
تلفونى
0182359520
مصر
الغربية
Posted on Jan 17, 2008
6ya staff
SOURCE:
Which buttons do i press to turn on the internet on, on a dvent net book
Hi
do you mean to enable the wireless switch so that you can use the internet
as you have not told us which model you have i can not tell you where the switch is
please try some of these options if your model is mentioned
Advent 7086 ---- Button next to the power button
Advent 7096 ---- Button next to the power button
Advent 7100 ---- Fn / F2
Advent 7104 ---- Fn / F2
Advent 7201 ---- wireless key top right and then Fn / F2
Advent 8117 ---- small slide switch on the front of laptop
hope this has helped you
many thanks
Aug 17, 2011 | Advent Netbook
I can't switch on my HCL laptop's wifi
Hi
There are several models of Advent laptops and as you have not told us
which one it is i have included a few of which maybe one of them will be yours i hope
hopefully one of these options may help you to activate your wireless switch
good luck
please let us know if this helped you
so that we may be able to help others
many thanks
Aug 16, 2011 | Advent Netbook
Advent N270 netbook will not charge. Orange light comes on initially then goes off. Also when I wiggle the plug into the laptop the light flashes on and intermittently.
It sounds like either a bad connection on the motherboard or a broken wire in the adapter making intermittent connection.
1. With the power adapter disconnected, do you have a power light? This would indicate the adapter is good and the plug is questionable.
2. Check your power adapter output with a multi-meter.(be sure to wiggle the wires around) If the power fluctuates, replace the plug.
3. If the power is solid, replace the motherboard connector.
Nov 22, 2010 | Intel Computers & Internet
I have been given a Advent 4213 and I can't turn it on?
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced.
Sep 09, 2010 | Advent 4211c Notebook
My advent notebook will not switch on
Sep 05, 2010 | Advent 4211c Notebook
Unable to find wireless switch on Advent laptop. There is a key combination like Fn + F10 but I cannot remember which.can you tell me?
Hi Friend,
Please find the key combination (for wireless/switch) for different Advent laptop models:
I hope this will resolve the issue.
Regards
Chiranjeet
May 20, 2010 | Computers & Internet
I need a direct link for ISO Recovery disc for Advent 7110 (model eaa-88) Currys/pc world model please?!
I've been looking for an easier/cheaper solution to this, but the only thing I have come across is an actual CD for 35 pounds. Link is below. Hope that helps!
http://recoverymedia.thetechguys.com/Product.aspx?productID=709
May 10, 2009 | Computers & Internet
Dismantling advent 7104
i have the same problem, anybody?
Mar 01, 2008 | Recoton Advent Advent Q2035A 20" TV
Recoton Advent Advent Q2035A 20" TV Logo
262 people viewed this question
Top Recoton Advent Televison & Video Experts
Ekse
Inno Laur
Vitally Alcher
Are you a Recoton Advent Televison and Video Expert? Answer questions, earn points and help others
