Question about Nintendo Wii Console
Wii Remte Problem
The Wii remote worked using the computer once however when going to use it again it wouldn't, we tried changing the batteries and synced the remote again however it is still not working do you have any ideas why this could be?
  • Ray Diaz
    Ray Diaz Jan 16, 2008
    I have the same issue. I have returned one controller already and am having the same issue on the replacement controller as well.
  • 4disapointed Feb 18, 2008
    The game worked fine first day we had it. Next day.......nothing. You have to stand thisclose to the sensor to get any kind of cursor or make the cursor do anything. If you move more than 2 inches from the sensor it stops working. Both remotes are like this. I spent an hour on the phone with Nintendo this morning. I think we tried re-sync five times! Plug in/Plug out...remove batteries, installed new battery.......Still nothing. Now they tell me I need to send the unit back to them. They will try and fix it. If they can't they will send me a "re-manufacted" replacement! I could just scream right now.
    Problem Solver:
  • 7 Answers
Try this:
open the cover of the wii's sd card slot. press the sync button for 15 secs. or so and all the sync data will be gone. then try to sync it regularly
Posted on Jan 17, 2008
Our second remote will not allow the second player to join in Just Dance 2 . The second remote works fine with wii sport or wii play. What do we need to do to allow the second player at the same time....
You could try wiping all pairings of the remotes and then repair them, that should solve the problem. To do this just hold the red button under the flap of the wii for at least 30 seconds. Then simply let go of it then press it once and press the red key under the battery compartment of the wii controller to pair them again
Please vote for me if you found this info useful
Mar 14, 2011 | Nintendo Just Dance for Wii
Wii hand will not show up we tried syncing, taking out batteries, unplugging and plugging sensor bar and nothig works
Synchronizing the Wii Remote with the Wii Console Synchronizing the Wii Remote to a Wii console allows the Wii Remote to communicate with the console. The Wii Remote included with your system should already be synchronized to your console. However, all additional Wii Remotes you use with your system also need to be synced in order to function properly..
There are two different modes of synchronizing (syncing):
  • STANDARD MODE - The Standard Mode procedure is used when adding additional Wii Remotes to your system or if you want to re-synchronize your original Wii Remote. Once synchronized, the Wii Remote will stay synced to the console unless you overwrite the settings by syncing the remote to a different console. For instructions on Standard Mode syncing, please click here.
  • ONE TIME MODE - This mode allows you to temporarily use your remote on a Wii console other than your own, or to use a friend's remote on your console. It can also be used to change the order of the Wii Remotes, without the need to turn off the Wii console. One Time Mode does not delete the Standard Mode setting stored in the Wii Remote. In this mode, the Wii Remote will only communicate with the Wii console while the power is on. When the power is turned off, the Wii Remote will lose its sync with the Wii Console. For instructions on One Time Mode setup, please click here.
Note: Only a Wii Remote in Standard Mode can turn the Wii console power ON or OFF.
    Standard Mode Synchronization
    Note: Make sure you have placed batteries in the Wii Remote (how to).
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button just below the batteries on the Wii Remote; the Player LED will blink. Quickly press and release the SYNC button on the inside of the SD Card compartment on the console.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
  5. wiiremotesynchstandard.gifThis procedure must be followed for each additional Wii Remote added to your system.
    Go to the Next Step (Playing Game Discs) >
    One Time Mode SynchronizationNote: This mode temporarily removes Standard Mode synchronization setup for all Wii Remotes until the power of the Wii console is turned off. When the power is turned back on again, the Standard Mode settings will return.
  1. Press the HOME Button on a Wii Remote that is synchronized with the Wii console.
  3. Select the Wii Remote Settings option from the Home Button menu.
  5. Select the Reconnect Option.
  7. Press the 1 and 2 Buttons at the same time on the Wii Remote that you want to synchronize with the console. If you are syncing multiple Wii Remotes, press the 1 and 2 Buttons on each Wii Remote immediately (without a significant pause) in the order you want them synced. The order in which you synchronize Wii Remotes determines the player order (1 through 4) for multiplayer games. The Player LED will blink during the syncing process. When the blinking stops, the connection is complete.
Jan 27, 2011 | Nintendo Wii Console
We received the wii system w/ a battery charger included ,but there were no instructions as to whether you can recharge batts. w/o having the them in the unit ,what the red,green light means what the...
Installing the Batteries
    Important Note: If you would like to use rechargeable batteries, the only type of battery recommended are Nickel Metal Hydride batteries. When it comes to using rechargeable batteries, you must follow manufacturer guidelines for safety and proper usage. Failure to do so could cause damage to the Wii Remote and void the warranty.
  1. Remove the battery cover on the back of the Wii Remote and insert two AA batteries, using the plus (+) and minus (-) guides in the Wii Remote's battery compartment to insert the batteries in the proper direction.
  2. Be sure to insert the minus (-) end first when inserting new batteries, and remove the plus (+) end first when replacing the batteries.
  3. Replace the battery cover.
  4. Go to the Next Step (Wearing the Wrist Strap) >
  1. Place your hand through the wrist strap and hold the remote firmly in your hand. wiiremotewrist1.gif
  2. Slide the strap lock towards your wrist so that the strap will not fall off. Do not over tighten the strap lock so that it's uncomfortable. It should be tight enough to hold the wrist strap in place. wiiremotewrist2.gif
    Go to the Next Step (Syncing the Wii Remote with the Wii Console) >
Jan 23, 2011 | Nintendo Wii Console
Cant use the remote
The remote has to be sync'd with the wii properly. If you sync it with another wii you have to sync it back.
Open the battery cover on the wii remote.
Open the front cover door in the middle front.
In each you will see a Red circle sync button in the remote and a rectangle button above the memory slot on the wii front.
Turn on wii, press the sync button on front of wii, then press sync button on remote, the remote should then get a signal and blue lights on front show player #. If not, turn off and try again. Once sync'd it will work with that Wii.
May 09, 2010 | Nintendo Wii Console
When I turn on WII it says ''press A to continue''ut nothing happens. I have changed the batteries in the remotes but they do not respond. I have checked the sensor is plugged in.
If you have multiple wii remotes, make sure the remote you are using is synced to your system. In case you are not sure how to do this:
1. Open the battery cover on the remote and press the red "SYNC" button. The lights on the remote should begin flashing.
2. Open the SD slot on the Wii system and press the "SYNC" button.
3. Once the lights on the remote stop flashing, the process is complete and you should be able to use your remote.
Remember, you have to go through this process with each new remote in order for it to work.
Feb 09, 2010 | Video Game Consoles & Games
Wii Remotes will not resync after using friends Fit Board
there is a flap in the wii open it up. open the spot where the batteries go on the controller. the controller and the wii should have a orange butten press them both at the same time.
Aug 20, 2009 | Nintendo Wii Console
My wii remot can turn on and i can push a and b but the wii remote wont work when i play baceball or boling. for exampol my avatar wont swing the bat when i play baceball.
Make sure the batteries are not worn down. If the sensor bar is in really bright light it will not work. Close the curtains so there is not lots of sunlight. Unplug the sensor bar and plug it back in again. You could try to re synch the remote, open up the wii remote battery pack and press the red button at the top once. Then quickly press the red button on the inside of the SD Card flap on the wii. If this problem persists try to get a new remote, or better contact customer services if these solutions don't work. Info is in the Wii manual.
Apr 15, 2009 | Nintendo Wii Console
Problems with a Wii game
if you are in the mulitplayer mode and still have trouble adding the remote then try syncing the remote with the wii first by pressing the home button then go into the wii remote settings on the bottom then re-sync each control. Then try going back into mulitplayer mode and try again or while the screen is on when you want to add more players press the '+' button.
Dec 28, 2008 | Video Game Consoles & Games
Cursor does not appear
exchange it
    Cursor not appearing
    Please note that our experience shows that this troubleshooting is best performed using only one (1) Wii Remote at a time.
  • Some games do not use the cursor feature of the Wii Remote; Make sure the game you are attempting to play uses the cursor by reading the game's instruction manual. You can also exit out of the game to return to the Channel Menu and use the Wii Remote to see the cursor. If the cursor still does not appear, continue with the steps below.
  • Trying to use multiple Wii Remotes in the Mii Channel or Photo Channel? These Channels only allow the Wii Remote designated as "Player 1" to function.
  • Verify that the Wii Remote's pointer lens is free of obstructions and contamination (stickers, heavy smudges, etc.). The pointer lens is the tinted rectangle at the end of the Wii Remote.
  • Check the battery power level by turning off the Wii console, then opening the battery cover of the Wii Remote. Press and release the red "SYNC" button to check battery strength. The number of lights flashing indicates the Wii Remote's battery strength. Four flashing lights indicates full strength. Our experience has shown that as your battery strength decreases to one (1) or less lights flashing, the cursor may not appear. For troubleshooting, if possible, try using fresh batteries so that all four lights illuminate. For guidelines on using batteries, please click here. If after inserting brand new batteries, you are still seeing less than all four LEDs flash, then your Wii Remote will need to be repaired. Please click here for repair information.
  • Is the Wii Remote properly synced?
    Press the POWER button on the Wii Remote to see if the Wii console powers on.
    • If it does, the Wii Remote is synced with the system. Please skip to the next section.
    • If the power doesn't come on, power on the system manually and try syncing the Wii Remote.
      • If the Wii Remote will not sync, there is likely a problem with the Wii Remote. Please click here for repair information.
      • If the Wii Remote will sync and the cursor still does not appear, try another Wii Remote if possible.
        • If at least one Wii Remote is working, there is likely a problem with the first Wii Remote and it will need to be repaired. Please click here for repair information.
        • If you have only one Wii Remote, or none that are working, please continue troubleshooting.
  • Make sure that the Wii Remote is being used between 3' and 10' directly in front of the TV and that there are no bright light sources affecting the Wii Remote's operation (review Game Play Guidelines for more information), and that the Sensor Bar is placed properly (see Sensor Bar setup).
  • Check the cord on the Sensor Bar for any frayed wires or kinks, and verify that the Sensor Bar is free of obstructions.
  • Check the button functionality, and that the Sensor Bar is operating correctly, by accessing the Wii Main Menu. Use the "+" and "-" buttons to scroll side-to-side through the Wii Channel screens.
    • If you are able to scroll with the "+" and "-" buttons, but the cursor is not appearing, then there is likely a problem with the Sensor Bar. Please click here for additional Sensor Bar information.
    • If there is no response, there is likely a problem with the Wii Remote. Please click here for repair information.
Dec 11, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
19 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
