Question about Brother IntelliFAX 4100 Laser Fax
LINE GOING THREW ALL FAXES
I changed the drum and the toner and there is still a line on all the faxes once they have been transmitted and the fax machine still says chage drum soon.
Whatr should i do???
  • TRICIA2878 Jan 25, 2008
    BLACK SMEAR AFTER I HAVE CLEANED THE GREEN ROLLER WITH ALCOHOL.
  • 4 Answers
Take out the toner cartridge. There is a thin strip on the bottom or top inside the machine that needs to be wiped clean. Also, make sure you cleaned the corona wire on the toner holder.
Posted on Feb 07, 2008
  • 84 Answers
You have replace the drum and the toner or refill?
Posted on Jan 15, 2008
Incoming faxes have black line running through the centre
If it is just from incoming faxes and not from anything you print/copy then it is the sender's fax machine that is dirty. If everything you do has that line, try cleaning the scanner glass and corona wire.
Jun 09, 2010 | Brother IntelliFax-2920 Fax
Heavy black line on sent faxes
You have a defective Scanner Block. EXPENSIVE
Apr 20, 2010 | Brother IntelliFAX 4100 Laser Fax
Thick Dark Line on received and copies of faxes
don't know the model of machine, but usually caused by the drum unit or toner cartridge. many machines have both drum and toner in 1 unit. try replacing.
Nov 18, 2009 | Televison & Video
White vertical line on received faxes
hi,
The upper glass is under the drum unit.
- Remove Toner and Drum Unit and you will see the glass. Try to clean it.
Bye.
Dec 02, 2008 | Panasonic KX-FL501 Plain Paper Laser Fax
Dark Bar only on Sent Faxes
open the top where you insert the paper to fax look at the strip of thin glass is there any white out or toner on it that is most likely your line, clean
Nov 10, 2008 | Brother IntelliFAX 4100 Laser Fax
Black line on faxes
Check carefully the glass, a very small point of ink or anything else can cause the black stripe. usually  it is that the problem. use windex to clean it.
Apr 15, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Right side of faxes (or copies) have 1-1/2" black line
Try changing the Drum Unit again....it cannot be anything else besides a worn out drum cleaning blade.
Fax Problem KX-FL541
your scaner is dirty,you have maybe nsome stuck in the scanner,or correcton fluid gooes from document to scanner lamp,check is all ok ,if everythin clean,your scaner lamp has a damaged ,try to change it or call service man
Feb 12, 2008 | Panasonic KX-FL541 Plain Paper Laser Fax
Lines printing out on faxes
white or black lines? what kind of machine? does it have lines when sending?
Nov 29, 2007 | Office Equipment & Supplies
Dark toner streaks
can only be toner, drum or fuser, pull out drum and look at surface are you streaks present? usually drum.
Stop a print half way threw machine and then remove drum and look at print, pre hot bit (fuser) are you marks there? If so it is drum, if not fuser.
Nov 21, 2007 | Brother IntelliFAX 4100 Laser Fax
Brother IntelliFAX 4100 Laser Fax Logo
100 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
