Question about Cuisinart DCG-12BC Electric Blades Grinder
Stainless Steel bowl is stuck to the body and is not removable. HELP!!!
The bowl on the grinder twists but will not unhook from the housing. I've tried everything short of breaking the darn thing. Any ideas?
  • Anonymous Feb 09, 2008
    Mine too, did you get yours unstuck?
  • whitneyjb May 11, 2010
    Same problem. Based on Solution #1, I tried a similar approach. I put a bunch of ice cubes in the cup and held them there for about 2-3 minutes. Then I dumped out the ice cubes, and the cup came off just fine. This solution doesn't exactly help if you grind your coffee and want to just take the bowl off, but at least you can get it off without breaking anything. I'm thinking I'll store it in the unlocked position now.
  • 24 Answers
Remove the six screws that hold the lower plastic cover on the motor base (four screws are hidden under the adhesive rubber footpads). This exposes the lower end of the motor shaft, which has a slot in it. By inserting a flat blade screwdriver into the slot and holding the cutting blades with a rag or a wad of paper towel to avoid cutting one's fingers, it is possible to twist the shaft back and forth about 90 degrees. You may need another person to help, because one needs to perform this twisting action while pulling the motor base away from the grinding cup and blade assembly.
Once you get the @&%$#! thing apart, reassemble the motor base. (With the slotted motor shaft, why didn't the designers simply put a hole in the plastic base so one could stick a screwdriver in without disassembling it?) Now, use a small object like a toothpick or matchstick to activate the recessed motor switch so you can spin the motor without the grinding cup in place. Use the blunt edge of a small snap-blade utility knife as a scraper to gently scrape the plastic pin of the motor shaft as it spins, much as one would work a wood turning lathe. Periodically check the fit of the brass hub of the grinding cup on the plastic pin. Continue to shave the pin until the grinding cup slips onto and off the pin with no resistance. Take care to machine the pin uniformly from top to bottom, minimizing the creation of grooves.
Why this mechanism worked properly when my grinder was new about 18 months ago and suddenly decided to get stuck this week is a bit of a mystery. The unit in question has been used since it was purchased exclusively to grind flax seed, but the ill-fitting pin normally doesn't come into contact with foods, anyway. There was no obvious evidence of swelling of the plastic due to heat from the motor or oils from seeds. Since the blade and hub are free to travel up and down on the plastic motor shaft pin a bit, I suspect that on occasion the blade doesn't settle properly and the clutch doesn't engage, allowing the pin to spin in the brass bushing until it starts melting, and then the hub settles so that the clutch is fully engaged. This may happen in a matter of just a couple of seconds of operation. Once that happens, the pin conforms to the microscopic grooves inside the brass bushing, allowing it to still turn slightly relative to the motor shaft, but locking it on so that it can't come apart. If Cuisinart had made the pin more tapered and the hole in the brass bushing to match, much like a Jacobs taper on an industrial drill press spindle, this would be much less of a problem. BOTTOM LINE: Before loading the grinding cup and starting the grinder, push the blade hub down with your finger to make sure the clutch is fully engaged.
Posted on Dec 09, 2009
Several times before, the grinder bowl has been difficult to remove from the base, but became free after wiggling it a bit. Today it was locked on, and would no amount of wiggling or twisting would release it. I was afraid that any greater amount of force would break something. After waiting a while, and trying again without success, I got the idea of putting the whole thing in the freezer. (My thought process was that the locking pieces which mate up between base and bowl are all plastic. In normal conditions, they fit together rather snugly. What if the plastic components expanded, even minutely, due to either higher temperatures in the room, or heat from friction while grinding the coffee? I figured it would not take much expansion to cause them to bind up.) I left it in the freezer a short while; maybe about 15 minutes. I'm happy to report that when I took it out, the bowl unlocked and came off without the slightest resistance. So I'm thinking the freezing cold made the plastic contract slightly, and the parts released. PS: I don't think I would want to just forget about the appliance in the freezer. Definitely, the power cord was beginning to stiffen when I took it out. It is possible that letting it freeze solid might make cracking of the rubber possible.
Posted on Jul 03, 2009
  • NJCommutr Jul 04, 2009
    UPDATE on my suggestion about putting the DCG-13BC coffee grinder in the freezer to release the bowl: it is one day later, and when I started the morning grind, the unit vibrated and made a lot of noise -- as the grinding happened, I could see it slowing down -- then it stopped completely, but I could hear the motor still straining to turn it. I unplugged it, and noticed smoke coming from the underside of the stainless basket. (The basket DID release with no problem this time. :-) It appears that the whole spinning blade portion inside the basket siezed up completely. I'm guessing that whatever is used as a bearing on that spindle got altered somehow by my freezer treatment. Maybe it had some sort of food-quality lubricant that I screwed up. In any event, DO NOT try my previous solution at home. I'm off to the mall to find another grinder. Cheers !
    Problem Solver:
  • 5 Answers
This happened to mine this morning. I was so frustrated because the reason I bought this was because of the removeable bowl. My bf got it off but he broke off a piece of plastic (he is pretty sure the piece of plastic was on the bowl part).
I put it back on and it kind still worked- I think I will just need to get a replacement bowl now - but it was hard to get off again.
When I tried to get it off the second time, I moved it into the "unlocked" postion and then manipulated the the blade part while pulling and it came off - but of course mine was broken already.
There appears to be two areas where it locks - on the base and a part on the bowl. I think somehow they get out of synch.
The problem is not with the base I think but with the bowl.
Although, now that it is "sorta" broken - I can't remember what parts were supposed to be loose before and which ones were not. The blade part of the bowl is very loose now. My boyfriend is pretty sure the plastic broke off the bowl part so I am going to get another bowl. I hope that solves my problem!
Posted on May 28, 2008
Same problem. I even removed the housing and used a screw driver on the slot on the end of the motor shaft, and could twist the blade slightly hold the shaft from turning, but it still would not come off. I even used pliers to try and pull the blade off. Still won't budge.
Posted on Apr 12, 2008
The bean container/hopper on my Capresso 560.01 Infinity Burr Grinder is stuck and can no longer be rotated in either direction or removed from the body. Can anyone help me unseat it?
Grinders that are used daily, especially those in coffee shops will eventually wear out. The fine settings for espresso (or even finer for Turkish grind) will wear out the plates even faster. I've seen burrs needing replacement in 3-6 months for coffee shops. Burrs set on this fine position that do not grind or stop usually means a worn burr or gummed up plate. (especially with oily beans). Either problem requires the removal of the burr set and complete disassembly of the grinder. It sounds like your '1st' problem was corrected by permanently 'affixing' the burrs to a set position and now not able to remove them without causing more damage. I did the same to an old grinder I got from the swap meet. But alas, the plastic collar cracked completely and can't be repaired. well got 1 year's worth of use and it was cheap.
** Suggest checking with your vendor or MFR for service and/or replacement.
Aloha, ukeboy57
Dec 08, 2017 | Coffee Makers & Espresso Machines
IF your bowl is stuck, then gently pry it with a thin flat edge screwdriver. If the bow is separated from the base then you will have to glue it. Watch the youtube video to see how she removes a bowl that is not damaged.
Nov 06, 2013 | Cuisinart SS Grind Central, removable bowl...
What types of materials are cat bowls made from?
Most cat bowls are made from one of three materials - plastic, ceramic/glass, or stainless steel. I recommend a ceramic/glass bowl. Many plastic bowls harbor bacteria and stainless steel bowls (although they are best for keeping water cool) are not heavy enough and will be easily tipped over by your cat.
Aug 26, 2012 | Alessi Cats
There are so many styles and types of dog bowls available, why when I ask my vet do they recommend a simple stainless steel bowl?
Stainless steel bowls will never lose their popularity. They are a standard dog bowl that you cannot go wrong with. They decrease the possibility of contact dermatitis, they last forever and they are pore-free meaning that it is highly unlikely that they will harbor any harmful bacteria. Stainless steel bowls are also very easy to wash.
Aug 26, 2012 | Alessi Pets - Others
Can't remove the container from the motor housing
It will be the blade holding the bowl on. The blade has become locked onto the motor shaft, in the end you are going to need to replace both. Take it to a K/A service agent.
May 22, 2012 | KitchenAid KFP750 Food Processor
The grinder stoped grinding coffee
many grinders have resetable termic fuse, some of them require manual reset, so you should search for termic fuse attached to body of motor(open the grinder from bottom) usualy they are round black termofuses with red reset button.
usualy this happenes when we have loud music and we dont hear that grinder is on and he works long time.
Feb 05, 2011 | Rancilio Rocky Doser Espresso Grinder...
How do I take my Imressa E8 apart?
Remove water container and empty beans. BE SURE UNIT IS UNPLUGGED.First, facing the unit, take out the three black torx screws from the bottom front. It makes removing the sides a little easier. Next, open the top lids, beans and water, and find the black pan screws in the top front and remove. Now, facing the rear of the maker, there are four screws disguised as buttons. Clamp on to the steel with a linesman pliers or you may need a side cutters. If using a side cutters, apply just enough pressure to grip and not cut. Remove screws counterclockwise. The top cover should lift up at this time. The side panels slide back to unhook from bottom and must be manipulated to release from front face. The side panel nearest bean grinder seems to remove a little easier than the water side. At this point, you may be able to clean bean grinder chute without further disassembly. If you need to service bean grinder, right side panel needs to be removed. Then remove the stainless torx screw holding on the bean cover to the grinding chamber. Adjust knob to full coarse setting. Next, find the two black torx screws inset in the bean container, probably have beans stuck above them. Remove bin. Do NOT remove the stainless torx screw on the top of grinder worm (on top of grinder blade)! From the side of unit, make note of clear and black wires on bottom of grinder motor so that wires will be put back on same terminals (can't remember if it was a dc motor). Remove wires. Make a mark on gear teeth of fine/coarse gear and gear ring of grinder to retain calibration. Now remove three stainless torx screws holding in grinder ***'y. Grinder ***'y should come out. Cleaning is easier at point. If you are to go further into the disassembly of the grinder, care should be taken because there are small springs and ball bearings in the ring gear and cutter.
Dec 26, 2010 | Jura Capresso Impressa E8 Espresso/Coffee...
My insinkerator Badger 5 plus 5 is leaking from the bottom plate
Flywheel seal needs replacing if disposal leaks from bottom plate.
May 16, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Cuisinart DCG-12BC Electric Blades Grinder Logo
594 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
