Toshiba SA2500 stereo reciever
I have this reciever that I bought back about 1980. It quit working several years ago and got put on a shelf when I bought a new system.
I thought the switch had gone bad, but when I got it out recently and tried to fix it, I found that the switch was ok, that there was some other problem. When I turn it on, nothing happens, no light on the dial, no static on the radio, nothing. I took the cover off and tried replacing the fuses that I found there (3) but still no luck. I couldn't see anything that was obviously out of place, no loose wires or anything.
Thank you for your help.
  • Audio Player... Master
  • 10,543 Answers
There may be some missing voltages from the power supply or a circuit pulling it down. Needs to go to a shop that knows how to fix older equipment.
Posted on Aug 14, 2016
6ya staff
SOURCE:
Johnny Bramton
  • 51 Answers
SOURCE: fisher ca 9025 amplifier
I suggest you get a schematic, find the main power transformer -- not the big one -- and see what the output voltage of it is. Could be there was a line surge and it cooked a zener diode that regulates power supply voltage. I can help you find a schematic.
Posted on Jul 04, 2007
john doe
  • 55 Answers
SOURCE: Doesn't power up
try the fuse first normally you can see if it's damaged
Posted on Nov 18, 2007
Anonymous
SOURCE: Amber light only
CHECK R104,R105 AND C109 NEXT TO THE TRANSFORMER.
Posted on Jul 30, 2008
SOURCE: Harman Kardon DPR 1005 problems
Sounds like the power supply or associated module. Definitely fixable, but probably needs a technician.
Posted on May 13, 2009
mlapres
Mike LaPres
  • 757 Answers
SOURCE: Sony DE-445 reciever flashes PROTECT
Sounds like a grounding problem. If the ground plug isn't missing or loose try plugging it into a different outlet.
Posted on Jun 18, 2009
Hooking up EQ to RECIEVER for a TECHNICS MODEL SH-8017
You'll need 4 connections total. On my integrated amp, I connected the four connections to all Line In and Line Out ports. And the other ends into the tape 2/EXTRA ports respectively.
Jul 19, 2013 | Panasonic Technics Stereo Graphic...
I have a MicroExpress laptop model FL92 that I bought several years ago. Ever since I got it, I've had problems with it suddenly quitting without warning. It appears to be heat-related and has p
depending how computer savey you are, you could open it up . clean heat sink and apply new thermal paste to the processor. not too moch, but not too little
Jan 30, 2013 | Computers & Internet
How do i unlock my kenwood ddx512 in dash touch screen dvd and nav stereo
with your remote control,or any kennwood remote control ( for car seteroes), dial the letters KCAR
Sep 25, 2012 | Kenwood DDX-512 Car DVD Player
Red/white x over sound icon lower left/ installed new audio driver it worked earlier today then quit/ no audio device installed
the problem is your using a toshiba. I bought one several yrs ago and in just a few yrs things stopped working. first the sound wuit, then usb ports stopped working then when booting up the laptop it asked for a non existant password. finally i just tossed it out
Mar 07, 2011 | Toshiba Satellite U305-S5097 Notebook
Cd & g drive quite working
I had the same problem. The fix is a bit unorthadox. I removed the 4 screws holding the circuit board that is mounted directly under the CD player. Now with the board hanging free the unit works fine.
Good luck.
May 19, 2009 | The Singing Machine DVD/CDG Karaoke System...
No disc
clean the laser lens maybe got some dust good luck
Jan 31, 2009 | Sony MHC-GX450 CD Shelf System
Hooking up surround sound
to get the digital you have to have the digital optical line or the coax rca jack digital audio connection from device to stereo reciever to get the dolby digital surround sound to work , otherwise you can only get a virtual surround sound from the reciever( no dolby digital )
Jan 04, 2009 | Sharp CDBA3100 Remanufactured Mini-System...
Kenwood in dash deck plug missing
I work at Best Buy and I have one
Apr 10, 2008 | Kenwood KDC-MP235 CD Player
Manual for stereo system
I need to know the product # in order to try to locate a manual.
Oct 29, 2007 | Sony CMT-EP404 Shelf System
Turntable problems
buy a better record player
Sep 27, 2006 | Emerson NR303TT CD Shelf System
320 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
