Tv vertical our tv monitor is off center. i think it has moved downwards. the video is not reduced but black appears at the top. thanks in advance.
  • Anonymous Dec 09, 2008
    Sharp CH27S6 TV has verticle deflection foldover when warm. Please advise..............
  • 281 Answers
Change the capacitors in vertical deflection section, check if all the resistors in this sections shows the correct rated value.
Posted on Jan 24, 2008
Black circle and vertical lines in 42LG5000 LCD TV
What board did you change?...the Tcon?
Mar 04, 2018 | Televison & Video
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
923nw samsung resolution problem
on ooptions screen, click box that says only show settings the monitor can handle. Then try changing the horizonal and vertical settings on monitor to match it up with your settings.
On your windows main screen, right click, then properties, then settings, check all the settings
Jul 09, 2009 | Samsung 923NW 19" LCD Monitor
Thick dark vertical lines appear on the video taken during playback.
It is problem of dirty / clogged video heads, use good quality video head cleaner in your camera and clean video head. Problem will be resolved.
Nov 10, 2008 | JVC GR-D250 Mini DV Digital Camcorder
Vertical lines in my laptop screen
Try connecting an external monitor to the Dell Inspiron 9300 and see if the vertical line is also present on the monitor. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor also displays the vertical line, then your problem is with either the video card or motherboard located inside your laptop.
Not sure if the Compaq Presario has an external monitor plug, but if it does the above procedure can be applied to that one as well.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 19, 2008 | Dell Inspiron 9300 Notebook
Vista media center
hello what is the screen resolution you use?
Feb 10, 2008 | Microsoft Windows Vista Ultimate Edition
Intermittent vertical lines
PANASONIC PV-C2540 Intermittant PROBLEM, picure is reduced to left to right vertical line. SEEMS TO WORK FINE WHEN SET HEATS UP?
Dec 22, 2007 | Televison & Video
Screen split with black bar through center, top of picture shows in bottom
It sounds as you desribe, the vertical output IC and or the b+ feed capacitor off the Hi voltage transformer feeding the vert. IC its required voltage. Not a really hard job to replace, but not for a handi person to do. This should be left to the professional, as there are no user serviceable parts inside this set and with the HI voltage and the safety issues its best to call somesone to assist you with this repair. Good Luck
Jun 14, 2006 | Sanyo DS31520 31" TV
Televison & Video Logo
79 people viewed this question
Top Televison & Video Experts
