Question about Gaggenau 47 in. CK 594 Electric Cooktop
Replacement dual burner Gaggenau CK594
I have a Gaggenau CK 594 cooktop with the center burner burnt out on the large round dual element. The replacement burner has five electric connection lugs and the cooktop has six wires from the switch that need to be connected. The local repair people that I have contacted said that the Gaggenau people sent them a wiring schematic for the new style burner which they cannot understand. My repair people are saying that Gaggenau will not help them any more that what they already have.
  • Rob Robinson May 11, 2010
    What color are the six wires. 2 each for the elements and 1 for grounding would make sense. Maybe each element comes with own equipment ground. If that is the case two would be green wires.
  • Anonymous Mar 31, 2014
    rest of electric cooktop fine
  • 38 Answers
A heating element is a ' load ' only and has nothing to do with 'line' a heating element consumes energy and a line supplies energy. The nomenclature for both is unambiguos. Line and load would indicate a switch or overcurrent device. We are referring to a heating element that is beyond the switch or overcurrent device. Applying a meter to the element with a good understanding of the fundamentals or having a clear diagram that indicates the function of the wires is the only safe way to proceed. Connecting indicator lights in series would never get through UL and your appliance would not have reached market. Obtain the information necessary as to the function of the conductors and connect them according to the manufacturers instructions to avoid violating the UL listing. See NEC 110.3(B) (NFPA 70): Listed and labeled equipment shall be installed and used in accordance with any instructions included. The equipment we are discussing is dangerous if not connected properly please be careful.
Posted on Jan 16, 2008
    Sergeant:
  • 288 Answers
You have 2 line, 2 load, and if there is an indicator light, 1 for that and 1 ground. The other guy may be right about the 2 grounds, if not, the indicator light may have a connection for hooking it to another light in series. The tech cannot understand the schematic? get someone who can.
Posted on Jan 15, 2008
My 5-burner 36" gaggenau has stopped working. I
Hello.
What the problem is a part in the cooktop that opens to let gas flow to the knobs as soon as they are turned on is bad and no gas coming to surface unit burners. This a safety feature that the German goverment(where Gaggenau is made) requires that part to prevent a gas leak when cooktop is off.
Gene
Aug 08, 2011 | Gaggenau 36 in. KG 291 Dual (Electric &...
Large burner elements ignite, and igniter spark fails to stop, then the burner shuts off as if ignition failed. Tiny central burner element does NOT light at any time. Apparently the safety cutoff...
There is a thermistor that must be in the flame area that needs to get hot. When hot it will turn the igniter off and keep the flame on. Check it's location and if it is in the flame then it needs to be replaced. not sure about the central flame problem. could be the switch.
Sep 20, 2010 | Gaggenau 36 in. KG 291 Dual (Electric &...
Gas stove burner will not turn on
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Apr 29, 2010 | Gaggenau 23 in. KG 260 Gas Cooktop
My Jenn AirCooktop Model CVE3401 burner problems
The part you need to replace is the switch. The switch is housed under the top and connects to the dial you are turning.
The switch for the dual burner is 12002125, and 74011242 for the single burner.
The single burner switch runs about $20.00 and the dual runs about $50.00 for the parts
Apr 24, 2010 | Jenn-Air 30 in. CVE3401 Electric Cooktop
My large dual burner does not heat up completely. Only the center burner works
The only way to find out the problem and repair it is to disassemble it..
Most have to be disassembled from the bottom, with the unit pulled and laying on a blanket to protect the top.)
Could be a bad switch, a bad element, or a wire is burnt off.
Good luck....
Apr 08, 2010 | GE Cooktops
Range replacement switch installation ???
sounds like you have the wrong sw . do not install . ck the old # and see it this is a proper replacement . / I did look your sw and it has a blue housing and muilti break of shaft . it should replace a standard sw but not the dual element . re ck where you purchase to make sure is the right one .. mm
Dec 08, 2009 | Cooktops
Did the element fail, or the switch, or the harness?
Buying and learning to use an ohmmeter is best. You can also inspect both the harness and the burner for damage. If nothing is burnt or broken, then you probably need the switch. Hope this helps!
Dec 29, 2008 | Jenn-Air JED8430 Electric Cooktop
Jammed knob on Gaggenau cooktop
It looks like the gas valve for FR burner has to be replaced. Very unusual for Gaggenau gas cooktops.
Nov 18, 2008 | Gaggenau 23 in. KG 260 Gas Cooktop
Gaggenau 47 in. CK 594 Electric Cooktop Logo
270 people viewed this question
Top Gaggenau Cooktops Experts
Paul Carew
Are you a Gaggenau Cooktop Expert? Answer questions, earn points and help others
