Question about IBM Lexmark Z715 InkJet Printer
Problem printing to wireless print server
Installed netgear WGPS606 wireless print server connected to one desktop via ethernet cable that prints fine, wirelessly on my laptop i can find print server and intalled port connecting to print server i was able to print windows test print page but if i try to print from anything else on the laptop. It seems that the status monitor for the lexmark Z715 is a problem or maybe the printer it self will not work through the wireless print server?
any help appreciated!
Best regards
  • BigDaddyLove Feb 18, 2008
    I am having the same issue. the z715 is connected to a win xp home system with USB and I am trying to share it to a vista home premium laptop. I have enabled the guest account on the xp home system and I have also tried adding the printer via the local port (\\xpsystem\printer). This did not work for me. still getting access denied. computers are in the same workgroup, file and printer sharing is enabled, and the user logs into each computer with the same username and password.
I have a lexmark z715 printer that won't work my pc is a emachine windows xp please contact me at noahmackey@bellsouth.net
Posted on Jan 28, 2008
Wireless connection with a wireless router (Netgear WNDR 4000) a pc and a laptop.
I assume you connect your printer to the desktop with the USB cable.
I assume the laptop is connected to the Wifi network.
First you need to setup the printer to connect to the wireless network. Follow the printer installation instructions to do that.
Next insert the install Disc into the laptop and follow the installation instructions. Use the network installation section.
The printer has a built-in server for printing.
If UPNP is enabled on the router then you should be able to browse the printer on the network.
Sep 30, 2017 | NetGear WGPS606 (WGPS606NAR) Print Server
Hello, How do I connect my Epson stylus PHOTO px700 to my laptop?
NETGEAR’s 54 Mbps Wireless Print Server with 4-port Switch allows you to connect one or two printers to your existing wireless network, without using unsightly Ethernet cables. Simply place your printers anywhere in your home or office that works best for you, plug them into the print server’s USB ports, and the Smart Wizard set-up function automatically guides you through configuration. Then you can send your business documents to a high-end color printer, and your kids’ homework to a black-and-white printer. The print server also acts as a wireless Ethernet bridge, connecting a cluster of up to four PCs and laptops without requiring dedicated wireless adapters. I t employs powerful WEP Encryption and WPA-PSK to keep your wireless network secure, and interoperates with all standard b and g wireless devices. All this in a sleek, space-saving stand-up case.
Mar 22, 2010 | NetGear WGPS606 (WGPS606NAR) Print Server
How do I connect with my WGPS606 if there is no setup cd and the default ip does not work? My router has encryption and the WGPS needs the info.
you need to set your print server for dhcp, you need to log in and verify the settings OR just set it back to default because dhcp is default. gl
Nov 06, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
Computer can's see Print Server in Add Printer Wizard The WGPS606 installation -- part 1 -- seemed to go fine. It sees our wireless network, we assigned it an IP address, it sees the printer connected to...
Make sure the printer has been connected locally first and that the print drivers have been installed. This should then allow you to add the printer via the set up.
Regards gaz
Sep 28, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
My wGPS606 wont print on my Windows Vista laptop!
I just found a way to enable the HP P1006 with a different print server (Liveprint on Orange Livebox router). Perhaps this might work with the WGPS606 wireless print server?
I set up the P1006 via the print server as instructed (I'm using Vista 32 Home Premium) but no test page would print.
BUT!! (with thanks to another another forum):
I selected printers, then right-clicked on the wireless printer I'd just installed and selected 'properties'.
Under the 'Ports' tab I deselected 'Enable bidirectional support'.
Problem solved.
Hope this helps.
let me inform you that this printer is not compatible with any wireless print server. The drawback is that it is not possible to network such printers. A printer needs a steady flow of data, which is easily accomplished when it is connected directly to a PC, but cannot be guaranteed when the printer is connected via a LAN. Also, these technologies require intensive handshaking between the driver and the printer.
The host-based software uses the computer's resources to process print commands and rasterizing data, taking advantage of the computer's memory and processing power."
Sorry I can't be more upbeat - but its probably useful to know that someone at HP thinks the job's imposible - unless someone out there has a fix?
May 11, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
Connecting the WGPS606 to Dell AIO 962
Try installing a lower end printer to the same port. For example HP LaserJet 3.
Mar 30, 2009 | NetGear WIRELESS PRINT SERVER 54MBPS...
Can't connect WGPS606 wireless printer server to cable router
suggest plugging print server directly into p.c via blue ethernet cable during setup. Then run setup program and then pick an ip address that works with your router (in same network ip range of router) that does not clash . I would use print server as a switch if it is close to the router by ethernet cable between router and wireless print server. Then both should work
Wireless to server and other wired computers as well .
Feb 06, 2018 | NetGear WGPS606 (WGPS606NAR) Print Server
Installation assistant cannot detect print server
Results of attempting to connect the Netgear Wireless Print Server WGPS606 and the Canon MF6550 multifunction laser printer. I was on the phone for several hours last evening (March 9, until about midnight EDT) with a very competent support agent from Netgear (actually in the Philippines). The Netgear setup Wizard software would not connect the Print Server to my Verizon FiOS wireless G router automatically, so the Netgear support agent walked me through it manually. The Print Server connected that way, for sure. Then we manually attempted to connect the Print Server to my Canon MF6550 and subsequently, my HP 932C Deskjet. Neither printer is on the WGPS606 compatible list, nor is either on the known incompatible list. Now we know - both printers are INCOMPATIBLE with the Netgear WGPS606. I bought both the Netgear Print Server and the Canon MF6550 at Staples on Sat., March 8, 2008, based upon the assurance from Staples staff that it would all work. The question now is whether ANY brand of wireless Print Server will work with the Canon MF6550, or do I have to return this printer and get either a Canon with built in networking (ethernet or wireless) or switch to the Brother equivalent (MFC 8870DW). If I get a (multi-function) printer with built-in Ethernet networking, does the Ethernet capability bypass the USB incompatibility problem, or will the problem remain?
Mar 10, 2008 | NetGear WIRELESS PRINT SERVER 54MBPS...
IBM Lexmark Z715 InkJet Printer Logo
279 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
