Question about Pioneer VSX-454 Receiver
WATTAGE OUTPUT I am to determine which no# is the correct watts on the reciver, i bought off someone without manual. can u help
  • whitefox34 Jun 13, 2008
    need to hook up pioneer stereo to a reciever to play cd's
  • Anonymous Nov 26, 2008
    how much total power
Divid max watts by number of channels.
Or figure it puts out around 120watts
Posted on Oct 18, 2011
Posted on Sep 22, 2008
What does 50wx4 mean? i am trying to find speakers for the rear deck and don't know what wattage the radio puts out
There are four outputs rated at 50 watts each. You will need speakers rated at 50 watts or more to handle maximum output without distortion.
Dec 12, 2016 | Cars & Trucks
What faults can a change over switch caurse between the generator and the load
One consideration is how many circuits and how much total wattage is being used when the generator is in service.
"Gas Powered Generator GG2300 2300 Watts Surge 2000 Watts Continuous Output 10 Hours of Run Time at Full ."
This is a relatively small generator with 2000 watts output, so the problem may be that the generator can not handle the wattage demand. You can get a pretty good estimate of the wattage demand by adding up the wattage of everything , all lights, appliances, etc that's being powered by the generator. If the total wattage is greater than the output of the generator (2000 watts) then the generator is too small.
May 21, 2014 | UST GG2300 Portable Gas Powered Generator
Adjusting the wattage output cobra 29 classic
It was probably set low so the person you bought it from could run a little box but as long as you have a watt meter you should be able to turn it up to about 5 watts.
Jan 24, 2014 | Cobra Radio Communications
Gt5 12 inch 275 watts how many watts of amp best?
Depends on what output your stereo is. If you underrate the speakers (speaker watts is less than stereo output), the unit will sound louder for a while, then you end up blowing your speakers with the excess distortion. If you overrate the speakers (speaker watts is higher than stereo output) the speaker will not operate correctly and the distortion can damage it also. Its best to get a close match. Slightly higher is better. It is important you know actual wattage output not PMPO ( Peak music power output) A lot of stereos are rated at PMPO. The higher number sounds great but in reality, the figure is the MAX output and by then the sound is distorting badly. Distortion ruins more speakers than anything else...
Oct 11, 2013 | JBL GT4-10 Car Subwoofer
My problem is that Model 16N5-K, 120v 60Hz 12 amp Bissell Vacuum cleaner has no wattage indication in the unit itself, in the box, in the product brochure. our power output in the Philippines is 220v. I...
All the information you need is in your text :>)
Volts, Amp Watts To determine the wattage, use a simple multiplication formula. The ampere (or amps) is the amount of electricity used. Voltage measures the force or pressure of the electricity. The number of watts is equal to amps multiplied by volts.
How to Calculate Wattage (Formula and Tools) - wikiHow
To find a step down transformer for 1440 watts, you will buy a new vacuum cleaner cheaper.
volts amps watts equation Google Search
Oct 01, 2017 | Vacuums
I was just wondering how many watts the behringer xenyx 1222usb mixer can push?
The board is a mixer only, not an amplifier. A mixer simply, well, mixes audio sources into a line output which then goes to the amplifier. Your question really has no answer since wattage is determined by the amplifier used. Essentially, it can "push" as many watts as the amplifier can deliver.
Jun 23, 2011 | Behringer XENYX 1222FX MIX BOARD
I have a panasonic inverter microwave model #nn-S540BFWR. What is the wattage on this model or where can I locate the wattage
The output wattage is 1100 watts. It can be found on the second page of the operating instruction manual. If you don't have one, you can download it at, just enter the model number and get a pdf of the manual. Hope this helps you.
Apr 19, 2011 | Panasonic NN-S540 Microwave Oven
Radio does not work on '96 cirrus. Sometimes it does, but mostly does not. Sometimes display is totally blank, and sometimes there is a small line on the display. I had the battery replaced awhile back,...
Not sure of the first issue with the radio, but the inverters output is 300 watts at 110v, not 12 volts. If your receptacle is rated at 180 watts that means it draws 15 amps (180/12=15 amps)-I have used a 400 watt inverter in various cars, and never had an issue, and remember just because it is rated at 400 watts does not mean it will draw that much, depending on what is plugged in-a laptop, for example, only uses about 80 watts. Your converter will '**** down' if the load is determined to be too high.
Dec 24, 2010 | 1996 Chrysler Cirrus
I just bought a RoadPro 2500 and i want to buy like a dorm fridge how many watts or volts size would work??
If you are referring to the RoadPro RPPI-250
  • 2000 Watts Continuous Power
  • 2500 Watts Power Output @ 10 Minutes
  • 5000 Watts Peak Power Output.
  • A small fridge will use about 500 -700 watts, with startup wattage at around 2000watts.
  • So, a dorm fridge will work fine.
  • the RoadPro converts DC to AC voltage, so a regular 120 volt dorm fridge will work.
  • Jul 05, 2009 | RoadPro RPPI-2500W Inverter
    The output power for model MA-780 was 700 watts, so I'd bet yours is either 600 or 700 watts.
    We're happy to help and we appreciate your thoughtful rating of our answer.
    Jan 02, 2008 | Goldstar MA-782M Microwave Oven
    134 people viewed this question
    Top Pioneer Audio Players & Recorders Experts
    Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
