Question about Zanussi 23 in. ZDT6252 Built-in Dishwasher
Zanussi zdt6053 will not fill with water, on any programme, it appears to try to start and makes a moise as if pumping, but there is not water to drain, and pump appears to operate if water is poured into the machine
  • lagerlover34 Oct 16, 2008
    Hi have the same problem but cannot find the water check valve any suggestions as to where it may be located have a ZDT6252.
  • 38 Answers
Check float valve. It is probably stuck. This tells yuor machine to pump the water out and keeps the water valve from opening. Often it is something small that was placed in the dishwasher and lodges under the float telling machine that it is full of water when it is not. The float is somewhere on the bottom inside the machine typically. Make sure it moves freely.
Posted on Jan 15, 2008
How i can operate the zanussi zdt6053 because i lost the manual can you support me please
Posted on Aug 20, 2008
My 5 year old zanussi 1449 E washing machine is not taking in water on any programme. water feed is ok
Water pump has quit. You can fill manually until you can replace pump or washer
Aug 04, 2013 | Zanussi Washing Machines
I have a zanussi zj1217, when select any programme it sounds as it is about to start, but before any water even goes in the start/pause button starts flashing. Any idea's.
check pump /pump filter electronics can sense if the pump not working at the begining of the programme try a pump only prog.Can be heater or main motor with an earth fault. you need an insulation tester to isolate the fault.
Jul 25, 2010 | Zanussi ZJ1217 Front Load Washer
The water has not drained away in my ZDT6053, I have removed filters but the water still wont drain away !
hi you need to open up washer and clean out the filter on the bottom shelve also try and wriggle rthe hose pipe going in at back turn off power and restart
Jan 01, 2010 | Zanussi Dishwashers
Zanussi DCE 5655 dish washer
Unplug at night if doesn't work change the L subport conversion chamber and remove the restricter plate
Feb 27, 2009 | Zanussi 21 in. DCE5655 Free-standing...
Zanussi washing machine wont spin
check the drain hole when you start the machine if the water is coming back out , if yes that means your dump valve is bad.
Apr 23, 2008 | Zanussi ZWF1430W Front Load Washer
Zanussi wj1054 front load
Check the water level pressure chamber for a partial blockage, this can cause all sorts of problems.
Apr 07, 2008 | Zanussi F1045W Front Load Washer
I brought a Zanussi ZDT6053 integrated. - Fixed in position - buttons light up but does not fill in oor start.
Dearest FixYa,
Thanks ever so much for your prompt response and am ever so grateful for standing to support anyone in problem.
Fortunately, I have solved the problem.
Basically the problem was that the water supply tube would kink when unit was pushed back into its space under the kitchen top. And it was totally difficult to see that problem from he rear of the unit.
Last effort wasto monitor every thing as the unit was showly pushed bak under the kitchen top. This time it was discovered that the water tube happened to be seen clearly from underneath the unit as 'kinked'.
When straightened, the unit simply went 'full in motion, and hey presto it worked straignt away.
Thanks for your 'standing by' to support with an army and great team of 'experts behind you.
Sincere regards
Mar 28, 2008 | Zanussi 23 in. ZDi6053SX Built-in...
Zanussi Aquapulse DE6544 not emptying
Zanussi Aquapulse dishwasher - is filled with water inside, is not washing and the lights keep flashing on and off - has anyone any idea what may be wrong with it?
May 27, 2007 | Zanussi 24 in. DE6544 Built-in Dishwasher
Zanussi 23 in. ZDT6252 Built-in Dishwasher Logo
1,037 people viewed this question
Top Zanussi Dishwashers Experts
Owen Barnes
Paul Carew
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
