Question about Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
I am getting a blue line, vertical, down the right hand side of the screen. It will fade in and go away. Don't tell me my LCD is going out. I've only had it for a year.
    Problem Solver:
  • 4 Answers
Hope you are still in warranty, a single colored line in an LCD or Plasma is usually a screen fault, the only other possibility would be the LCD control board, however it usually generate large stripes or bad image with half the screen, a single line, 99% is a bad screen. Call Sony, screen replacements are not economical to repair.
Crampy
Posted on Dec 11, 2009
SOURCE:
LG 60UF7300 UHD TV has screen issues
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
May 19, 2017 | LG Televison & Video
How do I remove three vertical colored lines from my Television. One vertical line is green another is red and the final one is blue.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
May 24, 2015 | Panasonic Viera Tc-p50u50 Hd Plasma Full...
White vertical lines like jail bars
Jun 26, 2017 | Samsung HLN5065W 50" Rear Projection...
Vertical thin blue line on my IBM ThinkVision Monitor?
they are like screen tvs they have connectors on the vertical lines when they get dirty the contacts have to be cleaned with a q tip and alcohol and repluged in . but is a pain in the but to take apart there a quite a few that are plugged in.but it could be the lcds are starting to go a tv repair man would be able to tell you if it is worth it or not as they are not cheap goodluck!!
Jul 21, 2017 | IBM ThinkVision L200p 20.1" LCD Monitor
I have a vertical line that appears down the right hand side of my Toshiba Laptop screen. It appears when I hover the mouse over to the right and fades away when I move off of the area. It is not allowing...
Try hooking an external monitor to the laptop and see if it works normally then. This signals a video card problem most likely. I don't believe that this model of laptop has a replaceable video chip so your motherboard will need to be replaced by a tech to fix the problem.
May 03, 2011 | Compaq Presario M2000 Notebook
Image is bright but there is a slight issue - on the left hand side a purple line displays vertically. Anybody knows why is this fault appeared and how could it be solved.
There is three LCD in the projector red, green and blue. If green LCD make any fault mean line or dot or dots then screen show these line or dot in purple color:
If line is very straight and sharp edges then green LCD is faulty and need to be replaced.
If line is not straight and faded edges then some thing in LCD block so your projector need service
Feb 22, 2011 | Sony VPL PX40 Multimedia Projector
40 inch lcd blue line vertical
The display screen is made of a matrix of elements connected to cables along the side and top. On your unit, some of these many, tiny connections are making contact intermittantly thus losing the elements in that area. These contacts are held in place with just pressure and if that is disturbed, you lose that line of elements. Try squeezing the cabinet of the TV on the outside at the top in the area of the loss and see if that makes a difference. May have to go inside and see if the contact assembly is disturbed or warped or something.
Hope ya fix it!
Jan 06, 2008 | Samsung LN-S4051D 40 in. LCD Television
Thin vertical red line
This maybe the symptom of a bad Panel. One Vertically This line is 99% bad panel. Call your warranty provider or SONY tech support if purchased under 2 years.
Best regards
CircuitCity
Nov 25, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
LCD TV - Vertical Blue line
use menu and h/v then change then move to higher level and it will take it away.
Oct 09, 2007 | Vizio Gallevia GV42LF 42 in. LCD...
Sony Bravia XBR 40" LCD
First, HORIZONTAL CENTER.
1) Press MENU.
2) Scroll to SETTINGS.
3) Scroll to SCREEN.
4) Go to HORIZONTAL CENTER. Move the picture to the right. Hopefully, the line will go away. Otherwise, there is a problem with the pixels or the signal processor. Call 1-800-222-SONY. Or, http://eservice.sony.com. Have a high-limit credit card handy for out of warranty repairs. Sorry about that.
Aug 27, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony BRAVIA KDL-40V2500 40 in. LCD HDTV Logo
783 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
