Question about Bassett Cottage Sleigh Crib
Bumper pad dilemma.
This crib has a solid back with no place to attach the bumper pads. Any suggestions?
Skip the bumper pads - they are a safety hazard anyway.
Posted on Jan 15, 2008
How do I pop-out a big dent in the plastic bumper of my 2007 Toyota Sienna?
You need to remove the bumper outer shell from the backing of crumple pad, but doubt that it will say popped out
Feb 28, 2017 | 2007 Toyota Sienna
I want to remove rubber on top of back bumper. I would like to replace my back up sensors
Hi Bruce:
First off, I don't have specific experience with your make and model, but I have had the occasion to replace the part you describe on a Dodge pickup.
On that vehicle, the rubber "tread" was attached to the bumper by protruding wedge pins that were inserted in holes in the bumper.
My suggestion is to either lie down under the bumper with a flashlight, or use a mirror and flashlight to look at the underside of the top of the bumper to see if the method of attachment can be determined.
If it is pins, and you can get at them, a squeeze with pliers will usually release them.
Hope this helps.
Cheers.
May 02, 2016 | 2006 Mercury Monterey
How to remove front bumper pad on a 2998 gmc sanoma
First remove bumper cover--pad is underneath.
Apr 15, 2015 | 1998 GMC Sonoma
How to remove rear bumper 1999 blazer
Hi there:
Check this Removal Procedure...
1. Remove the rear bumper step pads.
2. Remove the license plate lamps.
3. Remove the nuts and the bolts that retain the rear bumper impact bar to the bumper bracket.
4. Remove the rear bumper impact bar from the vehicle.
Installation Procedure
Notice: Refer to Fastener Notice in Service Precautions.
1. Install the rear bumper impact bar to the vehicle as follows:
1.1. Position the bumper impact bar on the bumper brackets so that the holes in the impact bar are aligned with the bracket holes.
1.2. Install 2 bolt plates and 4 nuts on top of the impact bar.
1.3. Install 2 bolt and nuts through the bottom of the impact bar. Tighten the rear bumper impact bar nuts to 90 N.m (66 lb ft).
2. Install the license plate lamps.
3. Install the rear bumper step pads.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jun 23, 2012 | 1999 Chevrolet Blazer
Remove front bumper
For front bumper removal,i suggest you to click the link below :---How to Replace Front Bumper? http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-front-bumper-on-audi-a4.html
-------How to Attach the front bumper cover to the fender? http://technoanswers.blogspot.com/2012/01/how-to-attach-front-bumper-cover-to.html
This will help.
Thanks.
Dec 14, 2011 | 2007 Suzuki SX4
I forgot my family settings password and forgot the random question what should i do to remove family settings
  1. Go into settings.
  2. Push these buttons exactly so - "X", "Y", "LEFT BUMPER", "RIGHT BUMPER", "X", "LEFT D PAD", "LEFT D PAD", "LEFT D PAD",
  3. you will then be asked if you want to restore the default settings. Click Yes.
  4. Play on.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jun 22, 2011 | Microsoft Xbox 360 Console
Trying to get the plastic pieces of the rear bumper of a 2004 ford f250
Remove the rear bumper and push clips out from the inside of the bumper. Careful these tabs are plastic molded to the pad.
Nov 04, 2009 | Ford F-250 Cars & Trucks
Front bumper of 94 cad eldorado slipping on driver side - need to
There are 4 points of attachment for the front bumper. The nose has two long bolts that go through each of the 2 horizontal shock absorbers and screw into clips attached to the bumper reinforcement. You can access each bolt head with a long socket extension inserted in front of the fog lights.
The remaining two points of attachment are on the side of each of the front fenders, they are plastic guides that meet up with groves on the inside of the bumber sides, as you slide the bumper onto the reinforcement bumper, you line up the bumper groves with these plastic fender-mounted guides and you will reach a point where the bumper snaps in place.
I suspect the driver side bumper sliped out of the inner grove (best caes scenario), or the bumper goves cracked or the plastic fender-mounted guide cracked.
Get under the car to take a look, alternatively undo the 2 front nose bolts and remove the bumper, actually not a big job, and you will then be able to assess the problem.
Hope this helps.
Apr 05, 2009 | 1994 Cadillac Eldorado
Bostitch Flooring Stapler is making dents
Is the flooring a solid wood flooring or is it an engineered? Is the stapler an MIIIFS or a SX150 or a LHF97125? If its solid then its a square edge board nad it its not centered on the flooring properly it will dent the ens.
Feb 15, 2009 | Stanley Bostitch MIIIFN Flooring Nailers
Possible caliper problem on 07 G6 brakes; noise but pads ok
call the dealer where you bought the car from, tell them exactly what is happening, if the caliper is the problem it should be under base warranty, although the dealer may make you pay for the pads, they are a non warranty item, the rotor should be covered also if the caliper is the problem. get it in writing before any work is done. I would push for the pads to be covered since it was caused by the caliper. dont back down.
Dec 31, 2008 | 2007 Pontiac G6 GT Convertible
Bassett Cottage Sleigh Crib Logo
304 people viewed this question
Top Bassett Baby Gear Experts
Jennifer Rock
Jennifer Rock
ray gallant
Tom Chichester
Are you a Bassett Baby Gear Expert? Answer questions, earn points and help others
