Question about Panasonic KX-T7633 Corded Phone
SWITCHBOARD PROBLEMS 1.SWITCHBOARD LINE IS DEAD CANNOT PHONE OUT AT ALL. 2. PREVIOUSLY IF THE SWITCHBOARD IS NOT ANSWERED IN 3 RINGS THE CALLS WERE DIVERTED TO 5 OTHER EXTENTIONS FOR ASSISTANCE, NOW SWITCH BOARD RINGS AT EXTENTION 119. PLEASE HELP URGENTLY AS OUR CLIENTS ARE REALLY GETTING FRUSTRATED AND THE TECHNICIAN THAT'S SUPPOSE TO HELP IS NOT IN AT ALL. THANKING YOU IN ADVANCE FOR YOUR ASSISTANCE SILVAINE FERIS
    Scholar:
  • 38 Answers
I'm sorry I never saw this website before, and I hope you're not still having this problem!
It sounds like something happened to your wiring if the phone is truly dead.
We have a support package that allows us to make all the changes you need over the Internet for a flat annual fee. If you want your whole system to work properly and all changes to be made for you at a flat budget, call us at 877-236-8376.
Posted on Oct 14, 2008
Can't send or recive Faxes
Try resetting the machine to it's defualt settings.
Jun 18, 2008 | HP Photosmart C6100 All-In-One Printer
What is wrong with my Telephone, Line completely Dead Can you check urgent.
You answered your own question; the phone line is dead and the phone co. has to handle it..
May 19, 2014 | Computers & Internet
HP L7650 will not auto answer incoming faxes
To set the answer mode to manual or automatic via the control panel
? Press Auto Answer to turn the light on or off, as appropriate for your setup.
When the Auto Answer light is on, the device answers calls automatically. When
the light is off, the it does not answer calls.
To set the answer mode to manual or automatic via the embedded Web server
1. Open the embedded Web server, click the Settings tab, click Fax in the left pane,
and then click the Basic sub-tab.
2. Select On or Off in the Auto Answer drop-down menu in the Other Basic Fax
Settings section.
Set the number of rings before answering
If you turn on the Auto Answer setting, you can specify how many rings occur before
incoming calls are automatically answered.
The Rings to Answer setting is important if you have an answering machine on the
same phone line as the device, because you want the answering machine to answer
the phone before the device does. The number of rings to answer for the device
should be greater than the number of rings to answer for the answering machine.
For example, set your answering machine to a low number of rings and the device to
answer in the maximum number of rings. (The maximum number of rings varies by
country/region.) In this setup, the answering machine answers the call and the device
monitors the line. If the device detects fax tones, it receives the fax. If the call is a
voice call, the answering machine records the incoming message.
To set the number of rings before answering via the control panel
1. Press Setup.
2. Press Basic Fax Setup, and then press Rings to Answer.
3. Enter the appropriate number of rings by using the keypad, or press the left or right
arrow button to change the number of rings.
4. Press OK to accept the setting.
To set the number of rings before answering via the embedded Web server
2. Select a number in the Rings-to-answer drop-down menu in the Other Basic Fax
Settings
section.
Dec 02, 2010 | HP Officejet Pro L7650 Printer
KX-T7730 - Used to have 3 incoming/outgoing lines. Have cut this down to 2(lines 1 and 3). Outgoing calls are automatically selected by line 3, 2, 1. When calling out the second person can't get an outside...
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system.
From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook :
1. Press PROGRAM * # followed by the system password ( default is 1234).
2. Now press 400 and then SP-PHONE. Enter the line number you wish to change. ( In your case 2)
3. Press AUTO ANS / MUTE to change between Connect and Not Connect.
4. Press AUTO DIAL / STORE to save your changes.
5. Press PROGRAM to exit program mode and you are done.
Mar 17, 2010 | Panasonic KX-T7730 Corded Phone
Partner ACS phone system won't fwd calls to mailbox
If they want all calls to be answered by the general delivery mailbox only them you need to change the Group Distribution (#206) on all the lines in group 7 from (1) assigned to (3) VMS Line Cover and also change the Line Coverage Ext (208) on all lines to ext 10
Dec 18, 2009 | Comdial Avaya Partner ACS Phone
Trouble with call forwarding to our multiple lines & voicemail
It's not and they're idiots. The hunt sequence you describe CF-No answer is part of their arrangement, probably Centrex/Centranet.
This is one of the sloppiest setups they can possibly give you, but it relates to destinations for CF busy and CF no answer. Get someone who has a clue and tell them to adjust the time on the No Answer part, or, better yet, give you something that really works.
Carl
Jun 01, 2009 | Vodavi 30-BUTTONVODAV XTS Telephone
Call forwarding on Panasonic Kx-T7633
I have a KX-T7633 and I want to be able to forward calls to my mobile after approx 3 to 4 rings when not answered
many thanks
Fintan
Nov 19, 2008 | Panasonic KX-T7633 Corded Phone
Call forwarding to outside line
To send a call to another telephone within your system, or to an external
telephone. You may not be able to transfer a call on an external line
to an external telephone, depending on the capabilities of the lines.
1. Make or answer a call.
2. Press the feature button then press 70.
3. Call the person you want to transfer the call to.
4. Stay on the line if you wish to speak to the person first.
5. Press the Release button to complete the transfer.
If an external call is transferred to a busy internal or network
extension, or is not answered after a few rings, the call automatically
rings you back.
Sep 24, 2008 | Nortel T7316E 2-Line Corded Phone
Panasonic KX-T7633 Corded Phone Logo
139 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
