Question about Intel Pentium III, 800MHz (229725001)
Nothing on screen
When i switch on my machine i get nothing on the moniter i have different make and models in my house and they all keep doing the same thing all the vga cards are in the right place and the jumpers on board and the leads also but i cannot figure this one out for some reason and the computers seem to be running fine its a bit of puzzler for me can u help
  • Brian Watson Jan 15, 2008
    not getting any beeps and the soloution you provided didnt work any other ideas
  • Brian Watson Jan 16, 2008
    sorry tried changing monitor but still nothing
  • 788 Answers
Do the systems beep when you try to turn them on?
Try turning on the system without a video card installed, it should give you a different set of beeps, if it does then you should be pretty certain the rest of the system is ok.
Put the video card back in and take out the RAM, you should get a different set of beeps.
Once you put the system back together you should at least get the POST screen on the monitor.
Posted on Jan 15, 2008
  • Dean Joly
    Dean Joly Jan 16, 2008
    Sounds like you may have a faulty monitor, do you have another monitor to try?
  • Dean Joly
    You either have a dead motherboard, power supply, or CPU in my honest opinion. Have it checked by someone who has enough spare parts to troubleshoot properly.
Wheni turn on my system nothing come on screen i could see that that power is comming but screen is dead
Try to use another working moniter and see if it fixes that.
If that doesn't work different grpahics card/PSU/ram until you find the broken component.
Mar 18, 2011 | Dell Computers & Internet
Moniter not rebooting when pc is switched on
Check the pins in the monitor that plugs up to the back of the computer and see if they are bent.
Apr 27, 2010 | Acer Aspire M1641-U1521A PC Desktop
We have hardly used our C2 due to continuous house moves[purchssed new in 2005/6] went to set it up today and the screen just has a series of vertical and horizontal line and then goes blank
I to have a C2 rowing machine with a PM3 moniter which i havent used since August last year, and i decided to use it to help loose the excess Christmas pounds and the moniter sounds like it does exactly the same as your moniter with the vertical and horizontal lines then goes blank. I bought the rower new about 2/3 years ago and it hasn't been used too much.
If you find a solution to the problem please let me know thanks (
Nov 04, 2009 | RTO Concept2 Model D Rowing Machine with...
Compaq Presario desktop with blank screen
Reset or Clear CMOS because maybe it hang-up some devices that are plug-in to. You can do that by removing the Lithium Battery on the Motherboard. This tips are only technician can do that but to solve your problems like this, this is a tip. And also check your Memory Module.
Hope this might help you, good luck!
Jul 29, 2009 | Computers & Internet
Dell moniter, brightness adjustment keeps coming on
The up/down button on your flat panel is stuck. Please contact Dell Technical Support to have the monitor replaced if its still within warranty.
Jun 06, 2009 | Dell UltraSharp 2407WFP 24" LCD Monitor
No power to moniter
This kind of problem needs an isolation. Please try the steps below:
1. Check the physical connection and make sure that the power cable is properly seated to the monitor.
2. Connect the monitor into different power outlet.
3. Try using different power cable.
Otherwise, you need to bring your monitor to the repair shop if none of the steps help.
Have a great day!
May 09, 2009 | HP L1702 17" LCD Monitor
No signal input
Check the coolant between the CPU and the cooler to ensure it's not simply over heated.
May 30, 2008 | Acer AOpen AX 6B Plus (91.87810.321)...
Monitor blinks no image
first you need to isolate the problem to either the computer or the moniter. I would sugust that you hook a know good moniter to the compter and go from there. If the other moniter works then you have a moniter issue aif not chek the video card in the computer. good luck
May 01, 2008 | E-Machines eMachines Monitor E15T4
Intel Pentium III, 800MHz (229725001) Logo
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
