Hy Experts! Hy, I have one problem, my Sony Tv not work, when I turn on Tv, Tv is going to off nad go to standby, LED blinks twice...what can be with my Tv? Line output transistor Bu2515DX is ok,and everything is ok,R618 270K is ok,maybe is Flyback transformer not work? The chassis is FE2,thanky you,if you say me something about this problem I will be very appriciate... p.s. my e-mail is maxess@net.hr
  • 3 more comments
  • Maxess Jan 15, 2008
    Hello, the model number is Sony KV-29LS30E...
    Thank you bobbyj, I will check this IC and will post back if good or not...
    Thank you very much,if you have something more for help, please post me...
    primary on the board is ok, when I disconnect colector from Horizontal output transistor,tv is work,not going to off, to standby,that mean when the secondary not work,tv is ok,but no picture on tv,why secondary on the board going to OCP!?all diodes is ok... B+ voltage is going to OCP,this voltage is going to flyback transformer,when disconnect B+ voltage from transformer,tv is working,and when disconnect colector from HOT,tv is working,but without secondary...
    thank you again...
  • Maxess Jan 16, 2008
    Hy bobbyj, on C board IC1801 is ok, on C board all is ok...
    I have service manual for this TV, also have schematic,if you need this to help me, I can send you...
    I will chack for vertical voltage...
    is not +13 and -13, the voltage is +15 and -15, going from flyback transformer, i've been before few days disconnected VCC and +15, -15 from vertical, but tv still going to stanby,and flashes blinks twice...
    thank you again...will chack this voltage on vertical and will post to you...
    Hy, i've replace vertical IC with new one, and nothing...vertical IC is good...only flyback transformer can be solution?
  • Maxess Jan 17, 2008
    Hy bobbyj, I will replace the flyback and see if the Tv is ok...I checked everything, and all is ok, the flyback is only solution...
    thank you very much,for your help and for everything...
    I would post it,if the problem is fixed...thank you again...
    My frend is tv servicer, and he say that this Sony, this model,the flyback is have some errors, when you buy it...he say that he is sell 200 flybacks last year for this Tv, I thing that is some factory error just in flyback, will see when replace the flyback...
    I will send you report...if I fix the problem
    Have a nice day...
  • Vista Electronics May 11, 2010
    1. Need Model Number
    Genius:
  • 1,694 Answers
Yes, most likely is the flyfback.....you checked everything else!
Posted on Jan 17, 2008
    Sergeant:
  • 395 Answers
Two flashes is OCP if the HOT is fine check for short on the CRT driver IC on the C,CV,or CW board IC1751 or IC1701 which ever it is labled.
Posted on Jan 15, 2008
  • 1 more comment
  • Robert Johnson Jan 16, 2008
    Ok I've seen this before false flashes like OCP but was in reality vertical. check for +13 and -13 volts to the vetical IC if low replace vertical IC
    You can not remove the power from this IC and have a different result the result is the same because of the feedback to syscon. no vertical pulse, how ever the syscon also senses no H out because of the no start condition and sends the 2 flash code instead. this was corrected in later models. vertical IC is the problem.
  • Robert Johnson Jan 17, 2008
    your are correct!! the one thing I had forgot to ask you is had you rung the flyback? I always forget to ask that question. so yes the flyback would be the culpret, I had pondered on this all day while I was on the road and I couldn't wait to get to a computer to ask you the question. Happy fixing!!
Have a LG 55ls5700 tv that doesn't turn on but the red standby comes on and when i press the power button it starts to blink
Does the screen quickly blink on and then off? Does the standby light slowly blink twice and then go out?If these are the symptoms then it is probably a bad led backlight strip.This was the fault with my lg 47ln540v led lcd tv.I have written this up in a previous post more comprehensively.Hope this helps..
Mar 19, 2015 | LG 55LS5700 - 55 LED LCD Smart HDTV,...
Standby timer blinks times
There are particular blinks meaning on sony TV. I can give you the problem from your sony tv if you specify or count how times the LED flashed.
Jul 06, 2014 | Sony KV-27S42 27" TV
Sony Bravia KDL-55nx720 My tv is stuck in standby mode. Blinking twice.. Would replacing the power supply possibly fix this problem? Please help.
Normally yes. Blinking twice is power protection trip. Look first for open resistor, broken fuses (and short circuits or broken transistors / ICS if thats the case).
Oct 05, 2013 | Sony BRAVIA KDL-55NX720 55" 3D LED-LCD TV...
Code for sony tv
Make sure your TV is on.
press "TV" on your sky remote
hold down both "SELECT" and then "RED" button until the little LED blinks twice on your sky remote. (should be for about 2 seconds)
press "TV" again
enter the code "0000" on your sky remote
the little LED should blink twice again. (if it didnt, restart the process)
if it had blink twice, then press the "STANDBY" button on the sky remote - your TV should turn off. (if it didnt, restart process again)
if it did - press "SELECT" the little LED should blink twice again, and hey presto - you is programmed wink.gif
Apr 25, 2013 | Radio Shack (15-2147) Remote Control
Sony 32" LCD TV KDL-32M3000. No picture, LED will
What does it do if you unhook the flat cables going from the tcon to the panel, does the blinking go away and do you have sound then?
Dec 10, 2017 | Sony KDL-32M3000 32 in. LCD Television
I need the code number of tv to enable me to use sky remote control
Please try 0863 for Hyundai Televisions To program your Sky remote control using the 4 digit code
  1. Switch on the TV set
  2. Press the TV button on the Sky Remote
  3. Hold down the Select and Red buttons for 2-3 seconds until the LED blinks twice
  4. Press the TV button on the Sky Remote again
  5. Enter 0863
  6. The LED should blink twice, if not recheck the 4 digit code used and go back to 1
  7. Press the standby button on the Sky Remote (The TV should go to standby)
  8. Press the Select button to store
If the TV does not go into standby press the TV button then the standby button, then TV then standby, keep repeating this until successful. This will scan the codes used for a particular make of TV.
Please keep me posted.
Thanks.
Lor04
Apr 06, 2011 | Hyundai Televison & Video
32 inch, hannspree tv.1080P I need code to get my sky remote to work.
1) Switch on the TV set
2) Press the TV button on the Sky Remote
3) Hold down the select and red buttons for 2-3 seconds until the LED blinks twice
4) Press the TV button on the Sky Remote again
5) Enter the 4 digit code for your make of TV (try 0206)
6) The LED should blink twice, if not recheck the 4 digit code used and go back to 1
7) Press the standby button on the Sky Remote (The TV should go to standby)
8) Press select to store this setting If the TV does not go into standby press the TV button then the standby button, then TV then standby, keep repeating this until successful. This will scan the codes used for a particular make of TV.
Mar 15, 2011 | Hannspree XV32 32 in. LCD Television
How do you tune Sky+ remote into Sony KDL46W5710 Television
The Sky+ remote should automatically default to Sony TV's. Leave the batteries out for a few minutes and try again. The Code for Sony is 0000.
Or try this :-
With TV and sky box on.
Press the 'TV' button on the remote.
Hold down the 'select' and the 'red' button (of the four coloured buttons) together, until the red light on the remote blinks twice. (takes 2 seconds)
Press the 'TV' button again.
Now enter four zeros, the red light on the remote should blink twice.
Press the 'standby' button (top right).
If the TV turns off, then press 'select' and the light should blink twice again, job done.
If the TV does not turn off then press 'TV' followed by 'standby' again.
Alternate pressing 'TV' 'Standby' until the TV turns off.
When it does, finish by pressing 'Select.
Check the red light on the remote, if it blinks 3 times, then it has run out of options for 0000.
Dec 19, 2009 | Televison & Video
Sony Wega kv27FV310 standby flashes 2 times with no picture or sound
standby button blinks no picture no sound have tried to reset and restart nothing has worked to get tv to back on
Mar 15, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Televison & Video Logo
291 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
