Question about Pioneer DEH-P6800MP CD Player
Turning off and on when driving
Sometimes it goes off and switches on alone when drivind, all wiring seems to be connected well.. do you think that it is a faulty unit. it is intermittent.
  • Carlo Brincat
    Carlo Brincat Mar 22, 2008
    ok settled, found that fault was coming from faulty iso plug, (the yellow wire,<+ battery>) thanks robotek :) good way of troublehooting
  • 1,512 Answers
The only way to be completely sure that the problem does not exist in the power cabling is to run BRAND NEW power straight to the battery and/or ignition cct on the cars fuse block. This then ensures that you have solid power supply If you have checked the wiring and are completely confident that it is ok, then it is possible that the unit has dry solder joints. Power switching is done by devices mounted to the chassis of the unit and they often dry joint as a result of the heating and cooling cycle of operation. You could check this too by disassembling the unit and looking for failed solder joints and repair. Good Luck. :) Happy to chat more about it if you wish :)
Posted on Feb 03, 2008
  • Graeme Ross
    Graeme Ross Mar 22, 2008
    awesome, go on you. Pleased to hear that you got it sorted.
6ya staff
SOURCE:
I have an 87 Jeep Comanche sports pick up. There is nothing wrong when running the truck, however when i am driving my wipers, my vent motor, and my blinkers will not turn on. Turns out part of my fuse box...
its possible, the best thing to do is get the Haynes manual for the diagram. Its been a while since i SAW a Comanche let alone worked on one. but I seem to think if the fuse isn't the problem then you should be looking at the multi-switch and the blower motor resistor. its not unlikely that you have 2 problems going on.
Apr 18, 2011 | 1987 Jeep Comanche
I am changing a 3way switch in the garage. I have 2 white, 1 blue, 2 orange, and 2 yellow wires my 3way switch has 2of the black screws. I cant seem to connect it right.
If you are replacing a three way switch with a three way switch, you should only use the wires that were connected to the old switch. (Unfortunately the color coding of these wires is not universal.) Assuming you have only 2 switches, that means you only need to connect 3 wires to the switch (in addition to the ground). One wire (to be connected alone on either side of the top or bottom of the switch) either comes from the electric panel or goes to the light fixture. The other two wires (both at the top or bottom of the switch) are the "travelers" and go directly to the other switch. You can examine the other switch (the one you aren't working on) to confirm which two wires are your travelers. I hope this helps. Good luck!
Aug 03, 2010 | Pass & Seymour Trademaster 3-Way 15 Amp...
I changed the positive cable from battery to starter now truck won't start won't even turn over. i think i put the new cable on the right post ???
There are three posts, a small one that the ignition wire goes on to, and 2 large ones, one that has a braided wire that goes into the starter and one that stands alone. The one that stands alone is the one you need to connect the battery cable to. Check the starter wire from the ignition and make sure the connection at the battery is good.
Nov 21, 2009 | 1985 Nissan King Cab
Hi,i have a 96 accord 4 cyl. vtec. just recently there has beeen a power loss issue. i have changed the alternator,check the ignition switch,tested fuses , battery seems fine,connections are good no...
check the alternator voltage , it has to be 13.8 to 14.4 vdc. it sounds like your car is running off the battery alone. Sometimes a bad battery will take out an alternator,and after replacing it goes again.Check all connections,and check the feedback terminal on the alternator is telling the alternator to switch on.
Nov 05, 2009 | 1996 Honda Accord
Ceiling fan pull chain switch replacement
OK, this is easy, it just seems hard. First off, take all the white wires from the light fixture's clusters, and hook them to the white feed wire. Now take the black side of the cluster of wires, and attach them to one side of the switch. It does not matter which side. The other side, goes to the feed wire that is black or what ever feeds the light. The switch only acts as a valve for one side of the loop. I could explain why some switches have a black and white, but I will leave that alone, so I do not confuse the issue.
Jan 22, 2009 | Solar 2-wire Pull Chain Light Switch For...
ALL BREAK LIGHTS NOT WORKING
Have you checked your brake light fuse? If it is good do your rear turn signals work? If you have turn signal and no brake lights it is probably the turn signal switch these are a common problem and your power for your brake lights goes through your turn signal switch. Sometimes it is actually the hazard switch that melts but this can not be serviced alone. If you have no rear turn signals and no break lights it could still be the turn signal switch but is more likely to be a wiring problem in the rear usually trailer wiring T connections. Chiltons has wiring diagrams in there manuals but they are not always accurate. Let me know if I can help you further and please rate.
Dec 27, 2008 | 2000 Chevrolet Blazer
2001 Chev Astro Cargo Van
the problem is your ignition switch.
the connection with the start contact is sometimes missing.
if you want to save money, you can trace the starter wire and hook up a push button wire to start your starter. the other lead of the wire goes to the ignition switch to from the " on " lead so that if you turn off your key, there is no accidental starting of your engine.
tnx 4 using fixya,
drcool
Sep 13, 2008 | 2001 Chevrolet Astro
KitchenAid KGRT607HWH6 temperture, light, error code
F7-E1 - Common Switch Wire Is Defective - This error occurs when common wire to latch switch and door switch is shorted.
Check all connections at control board and at the latch switch and door switch.
If connections are ok, then check individual switches as outlined for the F5 error code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 22, 2007 | KitchenAid KGRT607 Gas Kitchen Range
Pioneer DEH-P6800MP CD Player Logo
56 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
