Question about Keurig B100 Coffee Maker
Keurig Coffee Maker - Grinds in my coffee
My Keurig is about a year old and I have been noticing grinds in my cup rencently. Is it broken?
  • Prncessare Jan 26, 2008
    I'm having the same problem with my keurig. It's about a year old as well, and it sporadically will leave lots of grinds in the coffee. Any way to fix this?
  • 6 Answers
SOURCE: Grinds coming out in cup
When that has happened to me it was because the grounds were too fine...or the coffee maker needed to be cleaned with white vinigar, run through it like you were making coffee, then follow up with water, atleast 2 pots of water after that. The third thing that I tried was using a filter that stores in the maker, not the paper ones, sometimes they fold over and the whole thing gets clogged...Hope this might help...from one coffee drinker to another.....
Posted on Apr 04, 2009
SOURCE: My DGB-500 Cuisinart Grind & Brew coffee maker leaks coffee
I found out that internally the water line that comes off of the heating element is made of a rubber/silicon material. The heating element is so hot that it scorches or dryrots the tube and it cracks causeing leaking. Sometimes it comes pouring out and other times it just is enough to make it a pain. I have taken the time to get my specialized screwdriver set and take off the bottom of the pot, but have not been able to find a replacement tube for it. (They also made the tube so that you dont have enough to cut the broken end off and put it back on and if you COULD do it, they also put an "X" in the original tube so if you cut it and try to put it on you cannot push it on far enough. Other than this, it was a great coffee brewer for me for the past four years. (Put baking soda and water paste on the coffee stain if you have formica counters. A few times of doing that and the stain will come clean)
Posted on Apr 13, 2009
co7196
  • 3433 Answers
SOURCE: Grind Off light blinking
There must be a sensor or switch that is stuck. Often the grindings find their way into the nooks and cranys thasurround the mechanism. A bit confused on the grinder off light blinking when the grinder IS off.? But, I'll work with ya on it. Are you saying the light is blinking when it shouldn't be, like when the grinder is on? :-)
Posted on Sep 24, 2009
  • 1089 Answers
SOURCE: My Saeco magic grinds the beans, but no coffee
HI
When a machine grinds but doesn't make any coffee there are a couple of things.
If the grounds are wet in the dredge drawer, then you have a plugged brew head and need to clean it.
If the grounds are dumped dry into the dredge drawer, then you have an overcharge and need to adjust the dosing lever back from the full charge. On your machine it is inside the door at the top center. Pull the lever back towards the front 1 click. Then try again.
Posted on Nov 14, 2009
NewsView
  • 40 Answers
SOURCE: our coffee maker overflows,coffee grinds get in
Coffee overflowing onto the counter is a common complaint found in response to many automatic drip coffee makers. The following are potential solutions that can be used to rule out "operator error" vs. a defect or malfunction:
1. Do not "pack" or otherwise overfill the cone/basket with grinds.
2. If self-grinding your coffee beans, ensure you are using the correct grind setting for an automatic drip coffee maker. (See instruction manual for coffee maker and/or grinder.)
3. Do not overfill tank with water. Use the marks on the side of the reservoir rather than those defined by another measuring method. This is because a "cup" in a coffee carafe is defined as 6 oz, not 8 oz, and in some cases as little as 5 oz as a cup. (See your owner's manual.)
4. Make certain the filter cone/basket clicks into place and that the carafe is centered and pushed all the way in.
5. Try a permanent filter rather than a paper filter or vice versa.
6. Only use the correct permanent or paper filter (see manual).
7. Verify that the Pause 'n Serve button isn't sticking. If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.
8. Clean your machine with vinegar or as instructed by your owner's manual at least three times per year, more if your water supply is hard (prone to leaving water rings). A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew a pot of coffee, to produce "off" tasting coffee, or to clog and overrun the filter basket.
9. Ensure that the coffee machine is sitting level on the counter.
Posted on Jan 04, 2010
I have a model K40 (the fifth Keurig I have purchased). This one now barely drips water, takes forever to make about a third of a cup of coffee
There are instructions on youtube for the proper procedures to clean a Keurig. If you ever ran anything but clean water through the coffee maker, like reheating a cup of coffee the grinds in the bottom of the cup clog the system. Watch the video it is usually done with a small paper clip.and vinegar
Aug 30, 2014 | Keurig Elite K40 Black Coffee Maker 1 Cup
In the last couple of days our Keurig has been giving us lots of grinds. One entire cup was fllled with them while others have them floating. We use the K-cups from Keurig shipped to us. The coffee...
Hi,The bottom needle is plugged so the coffee is running back out over the top instead of going through the bottom needle...use a paper clip to open it up...
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Aug 06, 2011 | Keurig Elite B40 Coffee Maker
Coffee grinds are appearing in the finished product. Any advice?
heatman101
Jul 22, 2011 | Keurig Platinum B70 Coffee Maker
Coffee grinds in coffee.
Check the bottom needle...
heatman101
Jun 30, 2011 | Keurig Platinum B70 Coffee Maker
How do I clean the coffee maker? Coffee has grinds in my cup. I am using separate mechanism that has filter with regular coffee. JM
heatman101
May 17, 2011 | Keurig B50 Coffee Maker
Coffee grinds on K cup holder
try removing the K-cup holder and inspecting the bottom hole opening. This is where the bottom of the K-cup holder would go through. Sometimes grounds can rest on that edge and fall into the coffee. I hope I could help!
Feb 15, 2009 | Keurig Special Edition B60 Coffee Maker
Keurig B100 Coffee Maker Logo
472 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
