First stretch the gun lead straight ,unlock feed rollers try gently to real the wire spool backwards,if it wont move then cut the wire back towards the spool so you can take the gun off the unit lay it staight out use pliers and try hard to pull wire out.if that dont work you will have to replace liner.
Are you using flux core or solid wire. They use different rollers so the flux wire doesn't crush and clog up the sleeve.
