Question about ASUS P4GE-MX Motherboard
Asus P4GE-MX sir, i had reinstalled the mobo (asus P4GE-MX) but i am not sure of hoe to connect the reset,power hdd speaker connectors when i did my pc shoes the asus P4GE-MX screen and at the bottom it has press tab to go to post screen but when i press tab it does not helps the keyboard is connected plz help
    President:
  • 2,351 Answers
If you have your manual you can see how to connect these on pg. 1-22. No manual..
Starting from the right edge of the board moving to your left. Notice there is two rows of pins one above the other. All your case connectors will be connected left to right & not up to down. The first two (BOTTOM ROW) pins are for the reset switch. The connector will have two wires one will be colored white or black. These colored wires are ground & will be the sane for all your connectors. All grounds will face towards the right for both rows of motherboard pins. After plugging in the reset connector SKIP one pin as you move to your left along the bottom row. Plug in your IDE LED connector a two wire connector. Moving to the top row across from the ide led, plug in the Power Led. It is a two wire connector. Some case connectors for the power led come in a three pin connector. If yours is like that than you will need to remove the + wire from the connector & slide it over one slot so it is next to the ground & plug it onto the board.
The last two pins is for the Power button. All Asus boards are marked & colored. You need a stronge flash light to see the markings on the board. Good luck!
Don't forget to vote..........
Posted on Jan 16, 2008
Hi
I don't know if you have the manaul for your motherboard, but if you go here and download the PDF version it has the jumper connection setup for the reset button power hdd and the rest.
http://dlsvr01.asus.com/pub/ASUS/mb/sock478/p4ge-mx/e1862_p4ge-mx.pdf
Thanks
Matty_boy
Dell Asus M2N61-AX MB front panel connector Nix ATX Gaming case
I assume you mean the HDD,reset,on switch etc where they plug onto the mobo.
Most mobos are labelled on the board but you will need good eyesight to read. They are labelled HDD, RESET, SPEAKER etc.
If not simply look up mobo manual from vendors site. You will need the DELL serial / part number from the old unit though.
Apr 29, 2010 | ASUS Computers & Internet
How to connect pwrswitch, pwrLED, IDE-LED, reset,
http://www.motherboards.org/files/manuals/1/p4bmx-101.pdf
Here is the manual for this motherboard, and it shows you the pinout for the power switch, reset switch, power LED, HDD LED, and speaker.
Jan 13, 2010 | Computers & Internet
Asus p4ge-mx no power
Dear Sir Change the power related IC but your have no idea about the IC just send me a mother board we are Repair for this Mother Board Maximum cost 11.54 $ and Normal problem in 8.65 $ charge .......ok.
Email:support@compudesk.in
Web: www.compudesk.in
Jul 14, 2009 | ASUS P4GE-MX Motherboard
No display on my asus P4GE-MX mother board
Is there any beep from the motherboard? First thing that you need to check is the RAM. unplug the power cord and remove the RAM. Now, plug in the power cord and try switching the Comp and see if there is a any sound from Mobo. It should idealy warn you that there is no RAM with continous BEEP. If that happens, the Mobo is fine.... Grab a new RAM and try it out. The system should boot now. (If there was "No RAM warning beeps" when you switched on the system without RAM). There are many issues that may put down the Mobo but in most cases its the RAM that stops functioning... Try this and see if it helps. Please post your result here so that we can see if you need further assistance.
Feb 09, 2009 | ASUS P5PL2 Motherboard
Sound driver
go download the drivers from the following link
www.driverstock.com/ASUS-P4GE-MX-driver-download/6-9-10012/index.html
Jul 11, 2008 | ASUS P4GE-MX Motherboard
ASUS P4GE-MX Motherboard DIRVER DOWNLOARD
here is the link to the driver page:
http://support.asus.com/download/
Download.aspx?SLanguage=en-us
Enter
motherboard
Socket 478
P4GE-MX
for your drivers
Jun 24, 2008 | ASUS P4GE-MX Motherboard
Motherboard P4GE-MX, it broke cause there was thunder hit
This can be a number of things.. The first thing I would do is check all the cables and try a different outlet.. If that doesn't work, you probably need to buy a replacement power supply (can be returned if it doesnt work). If that doesn't work, the mobo is fried.
Mar 27, 2008 | ASUS P4GE-MX Motherboard
ASUS P4GE-MX Motherboard Logo
453 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
