Question about Sennheiser Audio Players & Recorders
Reset Settings? Working with a Sennheiser SKM 3072-U wireless stick mic and the channels have been re numbered. I need them back to the factory settings but I can't find a master reset and there is no mention of one in the manual. Is there any way? I don't have the time (or patience) to be resetting them manually.
  • 749 Answers
SOURCE: CASIO FX-83ES - reset to factory settings
try removing its batteries first.
Posted on Nov 15, 2007
SOURCE: master reset for sony cybershot
my camera won't load pic. up to my computer when I plug it up now can I reset it? It use to work but I don't know what happen.
Posted on Aug 06, 2008
rockdiarylv
  • 27 Answers
SOURCE: sennheiser e835 wireless mic won't turn on
how long did you hold the on button for? press it longer
Posted on Mar 02, 2009
SOURCE: want to reset my Zebra 140XiIII back to factory settings?
I resolved the problem by going into the setup program and then exiting and at that point I was prompted to save my changes and one of the options was to load Default settings. Once I chose this I was able to print on the 4X6 labels correctly, before that the configuration was feeding a label and 1/2 and print across two labels.
Posted on May 05, 2009
  • 10865 Answers
SOURCE: Need to do a master reset on my LG Lotus phone
Hi. Go to this link and do the hard reset. http://64.211.90.9/iframe/tutview.seam;jsessionid=7EDF4EE9E99CE14D24F58039AE7CC897?tutorialId=1971&deviceId=664&cid=120388&conversationPropagation=nest
Regards, Joe
ps - kindly rate my answer as helpful. thanks.
Posted on Feb 17, 2010
Need to fix loose wire inside 421 sennheiser how do you open it up?
Well, it looks like an SKM 100/g2 casing so if that is true, then unscrew the bottom part till you have access to the batteries and there are three star screws you'll need to take out right between the battery compartment and the bottom with the LCD screen. The bottom cover slides down and off. If you need the cartridge out then you unscrew the top of the mic where the actual pickup is and pull the core out through the top. That should be close, but might vary a little bit.
Oct 27, 2009 | Sennheiser Flashmic Digital Recording Mic...
On/off button fell off Sennheiser wireless mic
This is quite common with G2's, and really annoying!
If you are lucky, 50% of the time the red button is pushed inside the mic.
You need to remove the bottom section:
- open the battery compartment
- there should be 3 star-bit screws around the outside (remove)
- pull the bottom of the mic off
If the red button is not inside, they are available as a spare part from Sennheiser dealers.
Be carefull when putting the mic back together, it needs to line up correctly with the internal guides, forcing the base back on could damage the ribbon cable. when the line-up is correct it slides on very easily.
Best of luck.
PTB
Jul 06, 2009 | Sennheiser 100/500 G2 Series Wireless...
How do I use 2 mics for the XL2 simultaneously?
Hi, on the left side of the camera you can set 'audio monitor'. Default is channel 1/2. You can choose to listen to 3/4 or 1/2 and 3/4 simultaneous.
In the menu of the cam you can set between 12 bit audio recording or 16 bit. 16 bit only records on channel 1/2 (the front mic). In 12 bit mode you can record audio on 4 channels.
hope this answers a bit of your question
Mar 17, 2009 | Canon XL2 Mini DV Digital Camcorder
Sennheiser e835 wireless mic won't turn on
Mar 02, 2009 | Sennheiser E835 Professional Microphone
Frequency clash
There are different frequencies available and being used in each location.
To get a basic idea of which frequencies are available in your area, try this online tool:
http://www.sennheiserusa.com/findfrequency/
or use the literature provided with the Sennheiser gear (usually a useful chart comes with the wireless gear).
Also, remember that your transmitting frequencies need to be spaced apart a minimum of .400 MHz (or 400 kHz).
Frequency selection shouldn't cause feedback problems though. If you select a frequency for a mic that a local TV station is already using to broadcast, it will cause RF Interference (Radio Frequency). You'll probably hear static noises, pops, or since your Sennheiser has a Squelch feature, just drop-outs in audio.
So first consult the available charts to find a set of frequencies that should be available in your area. Then, if one of your mics is experiencing such an issue, try moving it .400 MHz to the nearest unused frequency and see if the RFI goes away. Repeat until the RFI no longer manifests.
Jan 30, 2009 | Sennheiser 100/500 G2 Series Wireless...
We have a Sennheiser Diversity Receiver ew 100 and when the wireless mic is off the noise line is on the AF and makes alot of staic until you turn the mic on then it stops. How do I fix this?
Hello! Turn the unit on and push set on the receiver then push arrows until tune comes up, raise or lower frequency of the channel until the noise does not appear in the meter, push set to store settings then push power button to return to normal. Then take the mic and turn it on, push set then push arrow until tune comes up then push set and then set the channel the same way you set the receiver. P.S.. The receiver is locking on to a rouge frequency that is what causes the noise. Went you turn the mic on the receiver locks on to the mic and the noise stops.
Hope this helps you to fix the problem.
Steve
Jan 19, 2009 | Audio Players & Recorders
Broken On/Off Switch
Yes, the switch is available from Sennheiser parts, and if you can get to it and know how to work with SMD's, it's quite easy.
Mar 24, 2008 | Sennheiser SKM100 Wireless Handheld...
Broken power switch
If you have a G1 SKM100 mic, the small on/off switch is an SKQLLC Tact switch made by ALPS. I don't know what's in a G2 or anything about the ones with the orange button. I just replaced the on/off switch and it took about 20mins. It's a bit fiddly but not too bad so long as you have a reasonably fine-tipped soldering iron. If you're in the USA then it look like there are a number of distributors who will sell one-offs. I'm in the UK and had to go back to the place I originally bought the mic from (DM music), who got it from Sennheiser and then sold it to me. For some reason Sennheiser wouldn't sell it to me direct. Good luck.
John
Dec 14, 2007 | Sennheiser SKM100 Wireless Handheld...
Open Questions:
56 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
