Question about Intel D865GBF Motherboard
Acer Aspire 5101after booting its freez
My Acer Aspire 5101 is after booting keybord,tuchpad,USB not working. Like hang plz give me a soluton at chip leavel or any jumper setting or snd me any diagram sholdring jumpers plz plz plz my Email Add:vikram.wasnk@gmail.com
Reboot it to an ealyear day when your usb worked
Posted on Jan 16, 2008
I have acer aspire 5101 ,i can not install windowse xp on it, when the win load the first file in to the ram and then write : windows setup is starting ,the lap top is hanging,ctr+alt+del dont work,i...
U may have a motherboard issue causing all of your problems. Wipe your hard drive completely and then try a vista reinstall with the software that came with your machine. If it still does not work, it has to be the mo bo.
Jun 13, 2017 | Acer Aspire 5101WLMi Notebook
Acer Aspire 5101 AWMLI. Keyboard & usb ports non functioning
I would check out ebay. I have seen them on there.
Nov 23, 2009 | Acer Aspire 5100 Notebook
Acer 5101 problem with keyboard
If the settings told by you are doen then this is the issue with the keyboard only.
You ca try formatting the windows once.
Aug 10, 2009 | Acer Aspire 5101WLMi Notebook
7720 will not boot
off course it is repairable dont worry look try to install OS thru the following procedure to factory default state
Acer: When you first turn on the laptop and see the Acer logo screen, hold the ALT key and press the F10 key (you need to do this before the Acer logo disappears).
if it installs the OS ok then fine if not
pls consider changing RAM take out from beneath the laptop open the cover all screws and take out the L shaped panel then u will see the RAM in front with 2 chips one uper and one lower side try to take out both and then re fit only one in the upper slot and then try to install if hangs again , then try the 2nd chip in the first slot and repeat the procedure if it works ok only try both chips one by one if it resolves ur issue and u find the faulty one replace it with new one with sam specs
in the last case if ur system still hangs then my friend ur hard disk is giving u hard time it needs replacement
when a system boots after bios loading all that is trf from Hdisk to RAM and then OS is loaded if one have problem system will hang or freeze try these solutions and then tell me the results
pls go step by step
and pls rate me fixya if i fixed ur problem
kindly let me know abt it and tell me in detail the messages u get and the system behaviour
Jan 30, 2009 | Acer Aspire 7720 Notebook PC
Acer aspire 5101 inbuilt cam driver required
If you have a grey rectangle where ur cam should be. Especially after a fresh install plus all the drivers. although Then here's your solution :)
Go into device manager and delete the USB controller. Then reboot. When it says new hardware found let it automatically install it. Et voila, working cam :)
Complements of TruthSeeker 69
Jul 19, 2008 | Acer Aspire 5100 Notebook
DV1000T chip PC87541V-VPC is extremly oveheating and freeze keybord
I do repair laptop for 5 yrs and I have a lot of problem with acer motherboard overheating with this chips 87541V like aspire 5580, aspire 3680 and other model...
Im sorry to those who buy ACER good luck... Acer laptop is good within one year before warranty expire.
Feb 26, 2008 | HP Pavilion Dv1000t (ED338AV) PC Notebook
Acer Aspire 5101after booting not working
Can you open Bios setup?
If it won't go pass the login screen, you should try restoring it from CD first, and then replacing the hard drive if that doesn't work.
Jan 15, 2008 | Intel D865GBF Motherboard
Intel D865GBF Motherboard Logo
128 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
