Question about Bosch WFMC 3200 Front Load Washer
Washing machine bosch 1200 exxcell
Error F04 comes up on screen on certain cycles other times it works perfectlyIf I put it to spin cycle to get rid of water can take maybe 3 to 4 times ir it does it first time can u help please
    President:
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 15, 2008
Does the Bosch Exxcel 7 1200 Express have a child lock function?
try the manufactures website for free manual download
Dec 08, 2013 | Bosch Washing Machines
Bosch Exxcel 1200 (WF02464GB) not heating
The machine only heats when it takes the detergent, all three rinses are cold only and this time of year the load will be very cold when it comes out. If the machine is not taking extra time (like a hour or two) longer to run a cycle, then there is no problem.
If you want to check the heater is functioning, try this
1 Put the dial to off
2 press and hole the start button whilst turning the dial one click to left (easycare 30)
3 release start and either two of the progression lights are lit or if it has a diplay should show 8.88 or 0.00
4 turn dial to 90 cotton, take the the long way round ie not thro the off or you will have to start again
5 press start
6 drum will fill and the heater will come on, wait a few minutes and if the heater is working ok you will hear a noise like a kettle boiling.
The drum does not turn during the test to allow you to hear this without the movement of the drum obscuring the sound.
If it sounds ok, cool. put dial to off, wait a second then select drain to get rid of the water in the drum
All the best
Apr 08, 2013 | Bosch Exxcel WFO 2264 Front Load Washer
Bosch Exxcel 1400 washing machine problem
Bosch Exxcel 1400 washing machine This video will show you how to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Oct 20, 2012 | Bosch Washing Machines
Bosch exxcel 1200 express fault code f04 what is it
i had this problem,no drain or spin,opened the flap at bottom right hand corner and pulled out small hose to drain machine opened circular filter cover (some water may come out) and found a 5p and 1p blocking filter after removing ,machine worked fine.
hope this helps
Apr 02, 2010 | Bosch Exxcel WFX 2467 Front Load Washer
I have a bosch washing machine make is a exxcel 1200 express and it stops working in the middle of a cycle and the words f04 come up wot does that mean please
there may be a stuck in cycle of rotating knob kindly rotate the knob more than three times your problem will be sloved otherwise replce the mechanism
Dec 23, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Have a Bosch Exxcel - error code F04 comes up half way through cycle - cleaned filter...still not resolved. Any ideas?
washing machin pipes were frozen in garage, defrosted now. done one wash half way through, error f04 came up. water still in machine and it makes a noise when trying to spin. The fillter knob has broken and i can't undo it to clean it out.
Oct 15, 2009 | Bosch Exxcel WFO 2264 Front Load Washer
Bosch washing machine won't drain and the door won't open.
Sounds like you have a blocked pump.To empty the machine manually lower the drain hose into a bowl or bucket.Once emptied the door should open.On most modern machines there will be a filter behind the kick plate at bottom front of machine, Check this for any foreign objects then try a spin before putting on again.If problem persists come for further options.
Nov 22, 2008 | Bosch Exxcel WFO 2264 Front Load Washer
need more info what point in the wash does it start to display the code
Sep 06, 2008 | Bosch Exxcel WFO 2264 Front Load Washer
Bosch 1400 exxcel
The machine thinks the drain is blocked.. check the pump and outlet pipe for buildup of dirt.
I noticed holding start down for several seconds whilst powering the machine on, then turning it off / then on again would clear the machine's idea of where it was during a program. Does this affect the error code you're seeing?
May 26, 2008 | Bosch Exxcel WFO 2264 Front Load Washer
Bosch WFMC 3200 Front Load Washer Logo
109 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
