Question about Casio EXILIM EX-Z1000 Digital Camera
Lost the slide/flap that holds the battery and memory card in
I dropped my camera and the slide that holds the battery and memory card in broke off and long story short i lost it anyone know where i could get the part and not pay over E100 for it??
  • 34 Answers
I have a used one from a camera I serviced. Google my username... ;)
Posted on Jan 25, 2008
My camera is from Digital Concepts. I lost the botom cpver of it because it broke off.i pit in batteries and decided to put tape of it so they wont come out. I try to turn it
But it does not work.
Every battery cover of a camera has a switch, powering down the camera when the cover is opened. This is to prevent damage to the memory card. You should not remove batteries while the camera is writing to the memory card.
Find the little switch and press it. Then try to switch on.
Jul 23, 2014 | Cameras
Open camera
Looking at the bottom of the camera, slide the oval latch in the center of the card/battery compartment door toward the back of the camera. Holding the latch there, slide the entire door toward the nearer end of the camera, and the door will swing open.
To remove the memory card, press down on the card and it will pop up a bit. Grasp it between your fingertips and pull it out the rest of the way. (It'll probably be easier if you let the batteries fall out first.)
Jan 09, 2012 | Nikon COOLPIX L20 Digital Camera
Camera is somehow "card locked"
The SD memory card should be located where the rechargeable battery is, remove battery cover, should be a small tab holding the memory card in place, move it so the card pops up, remove it and look along the one edge for a switch, slide it towards the contacts to unlock the card. The switch that is furthest from the contacts is in the locked position. Now if you find the card is in the unlock position, slide it back and forth to reset, failing that replace the memory card. Sometimes the slider switch becomes defective locking out the card.
Aug 15, 2011 | Cameras
How to use a memory stick right from the start
hi
  • Understand how a Memory Stick Pro works. The small card saves information from a portable device. You can save, delete and rewrite to the card as many times as you want. You can also remove the card and insert it into another device. For example, you can save photos from a camera, then insert the memory card into your laptop to view or download the images.
  • Step 2 Make sure you buy a memory card that matches the demands of your electronic device. The cards have different saving speeds and data-holding capacities. Generally speaking, the more data the card can hold and the faster its speed, the more expensive the memory card. Check your electronic device's product information for recommendations on the best type and size of memory card.
  • Step 3 Insert the Memory Stick Pro into the electronic device. Most devices have a small flap or cover on its side that holds the card. The memory card slides into a slot under the flap. Gently push in the card and close the flap.
  • Step 4 Save to the memory card. Once the card is installed, many devices know to save new data to the card. In some cases, however, you may need to specify where to save files, either to a built-in hard drive or to the memory card.
  • Step 5 To remove the card, open the flap and gently press the card in. The card should then pop out of the slot for easy removal. The card can now be inserted into another device.
  • vote me if your setisfied
    Jun 29, 2010 | SanDisk 2GB Memory Stick Micro M2 Memory...
    If the memory card says card has wrong format and unabe to format is the camera broke?
    If anything is broke it's the memory card. You need to get a new memory card.
    Oct 21, 2009 | HP Photosmart M425 Digital Camera
    My camera was dropped, and now the flap that covers the battery and memory card will not close, because the little part that kept it closed is what broke off. Is it possible to get this fixed, and does...
    Roughly about $60 and yes it can be repaired use the phone and ring around the camera shops That way you dont have to commit and can select the cheapest option
    Aug 17, 2009 | Olympus Stylus 740 Digital Camera
    Dont Know Where??
    Most LG phones have a spot for the memory card behind the battery. Remove the battery and you will see where the memory card slides in.
    Jul 14, 2009 | Leviton Combo Switch Neon Lght - 5226-I -...
    My sister dropped my camera a while go and it now says "protected card"...how do i fix this???
    I am surprised that nothing else has malfunctioned since dropping your S700. Remove the SD or XD memory card from the camera and make sure that the little slide switch on the memory card is in the "unlocked" position. Replace the card back into the camera (make sure that the switch doesn't slide back into the "locked" position again). Some memory cards, especially off-brand ones have very loose lock/unlock slide switches. I had to jam one into unlock mode by shoving a tiny piece of plastic into the slide slot. If that doesn't solve the problem, try using a different memory card and see if the results are the same. If this advice has solved your problem, please rate my answer accordingly. Good luck.
    Jul 05, 2009 | Fuji FinePix S700 Digital Camera
    I have a Fuji FinePix S5000 and the battery door catches (on the body of the camera) have broken off. Replace complete body assy??? I am sure mine is not the only one. any help appreciated.
    I had this problem also (see below).
    After getting poor results with the duct tape solution, I discovered another work-around. This should work whether it is chipped lugs on the door or on the body.
    Firstly I used an old camera flash bracket that screws into the tripod socket, and this holds the battery door in place quite securely. However it was too long, so I cut and filed a piece of aluminium 25mm (1") wide by 2.5mm thick to the right length (around 100mm/4") and shape, and made a hole for the bracket screw.
    End result is not exactly like new, but more functional than the duct tape and does not further damage the actual camera:
    Mar 05, 2009 | Fuji FinePix S5000 Digital Camera
    I have put the battery the wrong way round in my canon ixus 75 & now i cannot remove the slide cover to the battery & memory card. regards richard
    On the slide cover is a rubber flap which can be removed to reveal a hole showing the bottom of the battery,if you press a ballpoint pen directly onto the battery base this lessens the pressure just enough to release the slide lock mechanism.Hey Presto your'e back into the camera.
    Regards Richard
    Aug 17, 2008 | Cameras
    Casio EXILIM EX-Z1000 Digital Camera Logo
    Top Casio Cameras Experts
    pontelemon
    pontelemon
    Ron Grant
    Level 1 Expert
    Are you a Casio Camera Expert? Answer questions, earn points and help others
