Question about HP Officejet 5610 All-In-One InkJet Printer
Help i have hp officejet all in one 4355 we want print only black print pl giv me seting
Go to START SETTINGS PRINTERS.
right click on the officejet 5600 icon and then click on preferences. On the color tab indicate, print in greyscale & black print cartridge only .Apply , then OK. Reverse process to use color again.
Posted on Jan 18, 2008
6ya staff
SOURCE:
Hp officejet 4355 and DV6300 VISTA laptop. unable to install device driver for printer
Manually unzip the files and right click the setup.exe nd select "Run as Administrator" Vista and 7 are notorious for requiring this even if you are the administrator account.
Jul 13, 2012 | HP Officejet 4355 All-In-One InkJet...
Hp officejet 4355 all-in-one printer software not getting down loaded pl. guide
Select OS,down load the drivers..
Link: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=1138373&lc=en&cc=us&dlc=en&lang=en&cc=us
Sep 20, 2011 | HP Officejet 4355 All-In-One InkJet...
Hi i have a hp officejet 4355 all in one printer at my place. i m having problem fixing with the cartridge as it is showing error. pls guide
Problems with Hewlett Packard Officejet 4355 printing can often be due to issues with the cartridges. The printer has two cartridges, one black and white, and one color. Both can be physically inspected for problems. The printer also has a self-test report to determine if there is a non-obvious problem with the cartridge. The report can provide valuable information, including status.
  • 1
    Take the black ink cartridge out of the slot on the right. Be careful not to touch the ink nozzles or the copper contacts.
  • 2
    Look at the cartridge and make sure that the plastic shipping tape isn't still attached. There shouldn't be any tape covering the ink nozzles.
  • 3
    Replace the black cartridge and then perform Steps 1 and 2 on the color cartridge. The color cartridge is the one on the left side.
  • 4
    Print a self-test report. Load paper in the tray and press "Setup." Press "2" and then "4." The HP Officejet 4355 will print a report. Make sure the lines of color extend across the page. Missing, faded or streaky lines can indicate a cartridge failure. If the color bars don't show as black, cyan, magenta and yellow, you should clean the cartridges.
  • 5
    Press "Setup" and then press "6" and then "1." The print cycle will commence. Allow it to complete and then print another test report. If the test still shows errors, replace the cartridges.
  • Feb 01, 2011 | HP Officejet 4355 All-In-One InkJet...
    IseMY Hp all in one 4355 printer is unable to scan
    The HP Officejet 4355 can print, scan, copy and fax.
    You need to install the printer software to print and scan. Copy and faxing does not required software installation.
    Regards,
    Rizwan
    Feb 11, 2010 | HP Officejet 4355 All-In-One InkJet...
    No disk to install hp officejet 4355 all in one, need to print How can I get a print?
    You can download the driver from the following link. Just need to choose which operating system you're using - and then download the driver.
    Officejet 4335
    Hope this helps with your problem.
    Sep 24, 2009 | HP Officejet 4355 All-In-One InkJet...
    Driver CD of HP Officejet 4355 in Windows 2003 O/S
    Unfortunately , Officejet 4355 does not support / work with Windows 2k3 family.
    Oct 06, 2008 | HP Officejet 4355 All-In-One InkJet...
    HP Officejet 5610 All-In-One InkJet Printer Logo
    73 people viewed this question
    Clive
    Clive
    Ekse
    Thomas F. Schneider
