Question about Adobe Photoshop 7.0 for PC
Broken tv Our TV just switched itself off with a little pop the other day and now will not come on. Its only a year and a half old. Its not the fuse, we checked. Please could you offer some advice.
    Genius:
  • 1,665 Answers
Hi I suppose quaranty has expired.
Power supply output must be checked first.
Write down model No and mfg to check if there any schematic diagram or repair manual available.
Posted on Jan 15, 2008
Pop/Explosion from my TV
Check all the electrolytic capacitors at its main power regualtor section circuit. It will be best to replace the power regulator board as card basis.
Oct 08, 2013 | Insignia Televison & Video
The screen was hit by a toy and now stays black, can this be repaired?
The tv LCD screen panel itself it is dead,by force.Sorry,no not repairable.Only way to repair this tv,it is to replaced the whole LCD screen panel itself,not practical or possible because the LCD screen panel it is mission impossible to buy as a refurbish items,only can buy it from tvs manifacture itself only,but it 90% important to the tv and it functions and it is very limited production items,so they'll sell it to u,but the cost it is the same as a new tv.Buy a brand new tv it pretty cheap these day at Walmart stores.Tries buy another tv same make and model as ur old tv.Save the dead broken LCD screen panel old tv somewhere for later years,as refurbishes electronic PCB boards for ur new tv later uses.
Jun 04, 2011 | Samsung PN50C450 50 in. TV
3 YEAR OLD SANYO DP 32746. SHUT ITSELF OFF, CAN NOT TURN BACK ON
If you leave the tv unplugged for 2 days (atleast) then plug it back in and try to turn it on and if it comes on its the power supply board. If it comes back on it will probably shut off between 30min to 4hrs and you would have to unplug it for 2 days again. All the power needs to drain out of the tv. If thats the case take the back pannel off and check the part number out on the internet. Not hard to do becarefull touching things the power supply does store a little bit or shock in it. Good Luck.
Dec 13, 2009 | Sanyo DP32746 32 in. LCD Television
Did my tv just blow up?
Yes, I think you have lost the bulb and maybe the color wheel is on the way out too. But try a bulb first. If the old one has a broken "glass tube" in the center--be assured it is bad.
Oct 10, 2009 | Samsung Televison & Video
TV shuts itself off. ON/OFF switch no longer works.
If your sure the switch is broken, you can remove the switch and directly attach the wires and plug and unplug to turn it off and on. But it sound like that if the switch is broken you have a slight connection and with an ajar it will turn off and on by itself. The good thing to do would be to purchase a push button switch at your local electronics store for between $1.25 to $10.00 depending on what one you would like to have.
if it is remote control you could have what they call a sliver on the circut board to that can cause this to make the tv turn off and on. Best way to check this is to take the remote batteries out and see if the tv still turns off and on. If so replace the switch.
May 07, 2009 | JVC Televison & Video
TV BLEWUP
What would cause that is failure of some part (probably a filter capacitor) in the set's power supply. The usual cause is component stress due to manufacturers keeping their costs down by using parts that just barely can stand their operating voltages. (Higher rated parts would last longer, but would cost more.) Some parts are just a little too weak and break down. It's not unusual to have this kind of problem these days. The set would be repairable unless there was physical damage to the circuit board itself. You might have it looked at and get an estimate for the repair.
Nov 22, 2008 | Samsung 32 in. LCD Monitor TV
Westinghouse ltv32w6hd power supply
One of two symptoms on this model (LTV-32W6HD) Blue light comes on but cannot shut off. No picture; OR No picture but sound is OK. 1: In both cases replace ALL the electrolytic capacitors onthe output side of the power supply. This should get the power switch to worknormally. 2: Replace the small tiny wee little tiny small 2.0A fuse onthe inverter board labeled F1. This is the small black fuse, not the slightly bigger whiteones labeled F2 and F3.Ta Da...all fixed.
Nov 19, 2008 | Westinghouse LTV32W6HD 32 in. LCD...
Funai tv
Open the back cover and check any fuse blow in Y Sustain board or Z Sustain board. If you do find the fuse gone, replace the board. Good luck!
Jan 25, 2008 | Funai F42PDME 42 in. Plasma Television
Problem with tv turning off by itself.
First of all, you should try making sure in your menu that you do NOT have your timer set to shut off.  You'd be surprised how many people call Zenith every single day and fuss at me because their tv is 'broken' and they have a timer set.  Secondly, it sounds to me like it could be an issue with your power supply.  Does it turn itself back on randomly as well?  Do you hear any popping sounds when it turns off?  Check with your manufacturer to see what their repair warranty is.  Some have full warranties for 90 days parts and labor, and some have it parts and labor warranties for a full year.  You'd be surprised how much the customer service agents working for your tv's manufacturer actually know about the product.  Give them a call for sure to get more information! :)
Oct 21, 2007 | Samsung DLP HL-P5663W 56" TV
Sony KV-32S26 32"
One of the front control switches, that are located in the back of the buttons on the front of the set most likly are damaged or broken. These switchs are small and your going to need to pull out the entire chassis of the TV set to replair or replace them. If you have solid state TV repair experience thenm it should not be a big deal, but if you DONT please seek out a local tech to assist you with this repair as sliding out a TV printed circuit board can be a tricky thing, as it can bend ,crack or pop the surface mounted componets right off the board. A repair like this shouldnt cost alot. really all depends on if the board is damaged or not. good Luck
Sep 12, 2006 | Sony KV-32S26 32" TV
Adobe Photoshop 7.0 for PC Logo
35 people viewed this question
Top Adobe Computers & Internet Experts
Alun Cox
Laxman Bisht
Laxman Bisht
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
