Are you in a place with bad reception? My work has wifi and sometimes its very slow and takes forever to work and other times its fast. I always get calls though. However anyone else with an iphone that isnt the same as my provider and tries to use their phone there, it wont work at all. So it could be many different things. Especially if you are in a basement. Best bet is to call you service provider and see if they can suggest something for you.
These codes indicate your accelerator position sensor has malfunctioned. The computer has gone into limp mode, which allows you to drive to safety without damaging the engine. The computer is unable to determine how far you are depressing the accelerator and doesn't want to over-rev the engine. You need a new sensor.
TSB # 08-FL-004-1 CHECK ENGINE LIGHT P2135 DTC DIAGNOSIS.... there is a problem with the pedal assembly which has your throttle position sensor causing the codes, dealer only part you can install yourself with some know how
I assume you actually mean the metal ring that holds the small round case that the bobbin itself sits in. There are usually two arms that swing in to hold that larger metal ring in place and then there is a plastic and metal piece that sit behind the large metal ring. fit the plastic piece that may look somewhat like a scoop next to the metal piece that usually has the post the the bobbin fits onto and has a quite sharp tooth on it. The metal ring then goes on to hold those two pieces in place and the two arms swing in to hold the metal ring into place. The bobbin or bobbin case now can be put back in. Hint on metal ring placement: they almost always have a notch that goes at the very top where the arm on the bobbin case sits in when it is in place. You may find it easiest to do this with the machine laying on its back so you don't have to have 4 hands to hold everything in place while putting everything back in. Good luck!
Before anything you have to make sure the lever in the trunck is in the correct position. Assuming it is...
...does the top start to open or it doens't even move? Does the hatch where the top goes into start to open? If so, stop the top after you see that the hatch has completely opened, then manually push that piece down. Be carefull not to get stuck and make sure nobody is operating the top while you're attempting this so you don't get your arm stuck there for any reason.
You could also try to access it from the truck and pull it down manually. I may just snap back into place and the problem will go away. On my car, one of the sides was stuck UP and the other was working. Once it snapped back into place it works every time.
Well it could be that your fan is blocked and or clogged.You can take a tweezers,turn the television upside down,and lightly pluck out the pieces of **** clogging it up.That should make your fan run and then your television wont overheat and auto-shutdown.Hope it helped
Remove the sim, clean the sim and insert it back in, make sure it is firmly in place and in the correct position and direction... If that doesnt work place a small piece of paper over the top to package the sim in place and make sure it makes contact with the sim reader correctly.
There is a variable speed pulley that is a double pulley....one belt from engine to pulley and one from pulley to transaxle....remove both belts...pushing in the clutch will help with removal....remove o ring on top of pulley and pull up......the middle piece of metal is stuck....this piece is meant to slide up and down.....put the middle piece of metal on your pulley in your vice...wd40 the hell out of the shaft on pulley .....grasp the top with one hand and the bottom with your other hand...work the stuck pulley free.....put lithium grease on shaft...reinstall....done
