Question about Cameras
Canon 17-55mm f/2.8mm IS lens dust problem
Is it true about this canon lens having a dust acummulation problem as shared by so many users in so many reviews? If this is so what would help correct this? Those that have used Lens filters have mixed opinions about the effectiveness of this solution.
  • 1 more comment
  • guyp Jan 16, 2008
    Again thank you for your response. Most reviews I've come across have mentioned that this canon lens' construction is not weather sealed and prone to dust entry. Pls. look at user reviews of this lens in as an example. There is even one user who sent a picture of how much dust has acummulated in the back of his lens.
  • photomunch Jun 24, 2008
    I've had the lens for 10 days and already there are 6 large pieces of dust (plus smaller specks) inside the lens, under the front element. I'm very unhappy- it was not subjected to dusty environments.
  • Kevin Pettit
    Kevin Pettit May 11, 2010
    I am curious to read more of these reviews of this lens, any links you could provide could be helpful
I have the 17 - 55 IS 2.8 and it was dusty right out of the box, brand new! The vendor will have it serviced as part of the warrenty but this is a serious design fault for a lens that is touted to deliver L series image quality (some reviews make this image claim, not Canon). Anyhow I can't say that the dust has greatly affected my images, I just don't like the fact that the dust is there or that it could get worse or return after service. If it give me much more trouble I'll swap it for a 24-105 IS f4 L.
Posted on Aug 07, 2009
  • 216 Answers
My $50,000.00 Hasselblad H3 and Sinar HY6 have no weather seal and I have no problem. Just have to learn not to open in dusty areas.
Those weather seals will go bad within 6 years, then you have problem with light leaks and money for the company.
That's companies way of making money after selling you products.
Posted on Jan 18, 2008
Playback switch does not operate
PDF]Camera User Guide
Switching between Shooting and Playback.....32 .... Please note that Canon digital cameras are intended for personal use and should never be used .... Do not operatethe flash with dirt, dust or other items stuck to its lens. ..... PowerShot A520:.
Repair tips for digital cameras that won't power on. 'Do It ...
Nov 30, 2007 - It was a fix for a Canon A520, but am not sure if it would work for ..... I have a Canon Powershot A540 which will not turn on and lens is stuck out extended.... (even when they are new) in camera mode and not playback mode.
Digital Cameras - Canon PowerShot A520 Digital Camera ...
Dec 02, 2015 | Canon PowerShot A520 Digital Camera
Canon s1is "lens error, restart camera" appears on screen
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
Dec 15, 2009 | Opteka (OPT-42XHD2-S1IS) for Canon...
Dust behind lens
If the dust is inside the lens, then you are unlucky. Canon lenses (except for a select number of the L series lenses) are not dust or weather sealed. So each time you work the zoom mechanism on a inexpensive EF 75-300mm f/4-5.6 III lens, the mechanism is working like a giant billows allowing air (and dust and moisture) to flow through the lens and camera body. Sometimes large dust particles can accumulate on the different lens elements, but it does not have any impact on the quality of the photo
If the dust is creating problem fro your picture get it fixed from service center i will suggest you should not try to open it
Nov 27, 2009 | Canon PowerShot Pro1 Digital Camera
Canon Ixus 900 Ti ~ Lens error Restart camera
Oct 08, 2009 | Canon Digital SD900 / IXUS 900 Ti Digital...
Lens is stuck
You'd need to have it fixed at a service center. For the Canon Powershots as you have, the place that services these models exclusively is: The Canon Powershots are all they work on and they do excellent work, not expensive at all to have it serviced through them. Hope that helps you with it, good luck.
Aug 15, 2009 | Canon PowerShot A480 Digital Camera
I have a Cannon Powershot SD600, just got it recently and it worked great, then all of a sudden I noticed the cover lens's that slide over to protect the lens when you shut it off were messed up. Onle 1...
The Canon series are fine camera's, but they seem to suffer from lens errors (check how many people suffered from this by googling lens error canon).
The problem seems to come from sand/dust entering the body and jamming the lens gear. A handy person may be able to fix it, but I think Canon should have designed an enclosed lens gear so sand/dust can not enter.
Camera's are commonly carried in pockets, so it is logical sand and dust can be expected.
There are some issues with getting perfect focus in some situations.
Jan 03, 2009 | Canon PowerShot SD600 Digital Camera
Dust inside the canon ef 24 85mm lens
CAUTION! DO NOT EVEN THINK ABOUT DISASSEMBLING YOUR LENS. In 1964, I made the mistake of doing the same thing for a single focal-length lens for my Nikon F. This lens did not even approach the mechanical complexity of a modern zoom lens. Lenses are put together like jigsaw puzzles. I removed one screw and found to go further, I needed to do another. In fifteen minutes, the lens was in 50 pieces on the table. It cost over $175 to have a camera repair man reassemble it. This was a a time when the top of the line Nikon sold for $300 vs. $5000 today. Usually dust between elements does not affect performance, but if it is degrading your pictures, take the lens to a professional. This is not a job for an amateur.
Nov 21, 2008 | Canon 24-85mm f/3.5-4.5 EF USM Lens
Dust in lens
Not by a user This seems to be a faulty item so Canon Customer support should be advised.
Jul 22, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Cameras Logo
934 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
