Question about HP Photosmart 8750 InkJet Printer
Paper jam I out of 2 jobs sent to this printer get jamed on the ink jet cradle
  • sipcoffe Aug 31, 2008
    How do you get the back cradle off the 8750 photosmart printer ? Can't force it... only one side releases, the other sstays put...Hmmm Don't want to break it off.
Back cradle will not com off HP 8750 photosmart
Posted on Aug 31, 2008
    When there is a paperjam on the 8750 photosmart... How do you get the back cradle off in order to pull paper out of the print rollers manually ??
  • 1,003 Answers
Is paper crinkled or is printer just giving a jam error/
Posted on Jan 15, 2008
Printer show paper jamed without paper in it
There's a small piece of paper on the sensor. 4 in 1 Cleaning Paper for Laser Ink Jet Printers 12 Pack Perfect Data PD... You need paper path cleaning sheets like tho ones here. That should clear the jammed condition.
Aug 12, 2016 | hp deskjet 3600 series
Error message that paper jam in paper cradle
Try this:
  • open the lid of the printer (from where you can see the ink cartridges);
  • remove the ink cartridges;
  • use warm water and cotton swabs to clean both the ink cartridges and the print head (where the cartridges sit on) off of any ink residue;
  • place the ink cartridges back into the printer and test if this works by printing something.
If you're still having issues, there may be a mechanical problem; in which case you need to get it repaired by someone.
Oct 18, 2012 | HP Photosmart 8250 InkJet Printer
My printer keeps saying print cartridge cradle is stuck clear jam then press ok, but there is no paper jam
Because it's NOT a paper jam, but a cartridge cradle jam, I suppose it's an ink jet printer??? if so, check for debrie arround the cradle shaft that could prevent the printing cradle to move from left to wright... you could also lubricate the shaft by rubbing a little bit of grease on it with the tip of your finger (verry thin layer), as ink sometimes gets on it and tends to become sticky with time...
Aug 10, 2011 | HP Office Equipment & Supplies
Error 5700 impresora MX700
"Printer died after 1 1/2 years, error code 5700." on May 1, 2009 by danmc7777 (2 reviews)
Pros: This is a pretty decent product as far as ink jets go.
Nice to be able to use the feeder to scan multi-page documents and even cover two sides by running two passes and then the software interleaves the pages to make a seamless pdf file.
Cons: Ink jet technology. It worked very nicely for a year and then a few jets plugged up and wouldn't clear out even with cleaning.
Today the unit is dead, reporting error code 5700 and refusing to do anything after a paper jam.
Cartridges with chips.
Summary: I was pretty happy with this printer until one day it decided to grab about 30 sheets of paper at one time from the top feeder. This created a pretty major jam, and it reported the error code 5700. This jam must have stripped something in the gearing since now all it will do is report this error even after power cycling. Web search reveals that this is a serious fault that requires it to be sent in for repair. Yea, right. This unit is designed to be never disassembled since everything snaps together and opening it up is a major puzzle.
This is only reader review which i found in the web. this may tell you what is the error is all about..
Nov 10, 2010 | Canon PIXMA MX700 All-In-One InkJet...
My paper keeps jaming
paper keeps jaming - Brother MFC-3240C All-In-One InkJet Printer
Nov 09, 2010 | Brother MFC-3240C All-In-One InkJet...
Printer will not jammed ......the paper jammed in the machine..and I pulled it out....
1. Inspect the paper trays to make sure they are not overloaded. To determine if this is the problem, do a test print with only one piece of paper loaded in the paper tray. (If this turns out to be the problem, keep the paper tray half-full in the future.)
2. Check that the type of paper being used falls within the printer manufacturer's recommendations. For example, paper designed for ink-jet printers doesn't necessarily work well in laser printers. High-quality, bonded paper will cause paper jams in some printers; look for bonded paper that is "laser and ink-jet compatible."
3. If someone has recently printed labels on this printer, check to see if a label has come unglued from a sheet and become stuck inside the printer.
4. Check the gears and rollers for stuck shreds of torn paper from previous jams. Turn off the printer before you attempt to remove the bits of paper.f you have a laser printermag-glass_10x10.gif, inspect the printer's paper rollers. They should be smooth but not shiny. Rollers that are cracked or glazed are a frequent cause of paper jams and should be replaced by a technician.
5. if you have a laser printer, try cleaning the printer's paper rollers with a lint-free cloth and isopropyl alcohol (available atelectronics shops or drugstore.Try changing the toner or ink cartridge.
Feb 04, 2010 | HP Office Equipment & Supplies
HP C4385 display reads Paper Jam continuously
check the paper jamed or not other wise try to reset your printer
Oct 03, 2009 | HP LaserJet P2015dn Printer
Try looking for the jam from the rear of the printer. Also, using one of those compressed air cans, blow all the paper dust our of your printer, because the sensors usually are photo-electronic sensors, and paper dust wil register a paper jam, even when no paper is in the printer.
Jun 19, 2009 | HP LaserJet III Printer
Paper Jam - HP G85 Ink Jet Printer
You open the door from the back of the printer (turn the knobs) and the paper can be removed from the back. After removing paper jam, replace the door. It is a long door as wide and the printer, but about 2 1/2" wide.
Feb 28, 2009 | HP OfficeJet G85 All-In-One InkJet Printer
Print cartridge cradle stuck there was a paper jam. That was cleared, but now it says the cradle is stuck and the paper does not feed please help print cartridge cradle will not move
Hi, I have a HP Photosmart 8050. Runs good till Now. 1, ONE Sheet of paper Jamed. THe RED Light Keeps Blinking Like crazzzy. I unhooked it to re-boot. It says Print Cartridge Cradle is stuck. Clear Jam & press OK. Iv'e L@@KED 4 anything. Nothing in way. I took the ONE sheet out. Still Nothing. It's Like my X-wife. 1 item wrong and a Bunch of ****. New Ink. Got Milk. Oh wrong Commercial. Got Fix. Retired Handi-capped sanior, Ron
Mar 17, 2008 | HP Photosmart 2575 All-In-One Printer,...
HP Photosmart 8750 InkJet Printer Logo
140 people viewed this question
Ben Johnson
