Question about SanDisk Sansa e270 MP3 Player
E270 Does not keep date and time.
Every time I go to check the time on my Sansa it's wrong as the date! I had already reformatted it and updated the firmware to correct a freezing promblem it had. Anybody seen this problem?
  • zcrank
    zcrank Jan 16, 2008
    It's a sanDisk Sansa E270 MP3 player. No I don't remember having this problem before reformating the player and then updating the firmware. I do not know what the production date is nor where to find it.
Hi zcrank
just two questions, what is the manufacture date of your phone or how long have you been using it and did it have this problem at first?
Posted on Jan 15, 2008
Probles with formatting and resync sansa e270
hi! you can try reformatting by activating the keylock and then press and hold the record key while turning the power on. it will go to the recovery mode.
plug the mp3 usb to your pc.
open a notepad apllication and create a new blank file.
save as sansa.fmt and change save as type, it should be All Files. it will create a file with 0 bytes.
you can now disconnect the usb and wait til the mp3 displays formatting.. it will reformat by itself.
Jun 30, 2009 | SanDisk Sansa e270 MP3 Player
Sansa e270 it lost driver
Go to Sandisk's website and get the software you need. If the reinstall fails:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Mar 21, 2009 | SanDisk Sansa e270 MP3 Player
My sansa e270 6gb is frozen and wont go past the refresh database screen what can i do to erase all the data that is on it and start all over
I'm always hesitant to give this answer, because if it's done wrong, you can do more damage to your player, but the answer is: you need to format your player. I would format the player from inside the player's settings menu - but if it's stuck on Refresh database, you may not be able to do this. Follow these steps in order:
-Tha Mp3 Doctor
Feb 15, 2009 | SanDisk Sansa e270 MP3 Player
Format my Sansa e270
1 way is to let windows re-format it.
Plug player into usb of computer.
open up mp3 drive. click on tools.
have windows re-format it.
2. Download firmware http://www.sandisk.com/Retail/Default.aspx?CatID=1449
download the new firmware and check the box that says reformat
data area.
Jan 04, 2009 | SanDisk Sansa e270 MP3 Player
E270 mp3 player taking time for refresh
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Nov 07, 2008 | SanDisk Sansa e270 MP3 Player
Sansa e270 error message
Your device firmware may have been corrupted...Please follow the link below to get the firmware update....
Thank you
Computerrep
Oct 15, 2008 | SanDisk Sansa e270 MP3 Player
Sansa e270 freezes when USB cable disconnected
Reformat the whole thing with Rockbox. That's the whole point with buying the Sansa, as far as I understand.
Jul 12, 2008 | SanDisk Sansa e270 MP3 Player
Sansa e270 problem
You cannot - the firm upgrade delted them - you will have to refind them and redownload.
Jan 21, 2008 | SanDisk Sansa e270 MP3 Player
E270 sansa
-Tha Mp3 Doctor
Dec 12, 2007 | SanDisk Sansa e270 MP3 Player
Why is my product freezing
when it freezes just keep hitting the smallbutton like 50 times and it will refresh.
Dec 29, 2006 | SanDisk Sansa e270 MP3 Player
SanDisk Sansa e270 MP3 Player Logo
43 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
