Question about JVC HR-J437MS VCR
Hr-J437MS VCR Will I be able to watch NTSC tapes on NTSC TV with this JVC multisystem model?
This Multi standard machine will play back NTSC 4.43 and 3.58 with no problem
Posted on Jan 17, 2008
Plz help me live in australia brought series from usa now cant watch it i have a jvc model spthg51f
Hello
System compactablity is the problem you sufferes now. All set released in US will have NTSC {National Telivision System Committe]; system and is only meant to be used in US. Present sets have both NTSC & ATSC systems. In Australia, the transmission and reciving system is PAL [Phase Alternating Line] as I understands. NTSC set is not compactable with PAL system. You can see discs or video casettes recorded in NTSC system with your set, but the player also must ahve NTSC compactable. You have to choose a multisystem set from there. If so you can now use it in Australia. OK.
May 28, 2011 | JVC Audio Players & Recorders
Connecting JVC HR-XVC27U VCR/DVD Combo to DIRECT TV
Here is a link to a line diagram to connect most tv/dvd/vcr/direct tv.
Apr 22, 2008 | JVC HR-XVC27U DVD Player/VCR
My JVC HR-DVS3u Mini DV recorder deck keep displaying use cleaning tape, I use the jvc cleaning tape and it still ask for it.
my JVC HR-DVS3u Mini DV recorder deck keep displaying use cleaning tape, I use the jvc cleaning tape and it still ask for it.
Dec 24, 2009 | JVC HR-DVS3 Mini DV/S-VHS VCR
JVC HR-S7600U VCR. Playback issues with VHS & SVHS tapes.
super vhs tapes has an extra hole on the side where you lift the flap to see the tape the pin inside the machine must be stuck.I have had no problems with this as i have jvc super vcr s as they are great machines also take the lid off and clean the heads around the drum see how you go.
Jan 25, 2009 | Pioneer VSX-D710S Receiver
My jvc hr-s8700 has no hifi stereo playback
The VCR stereo playback sound is only available through the AV/SCART connection and will not work through the coaxial antenna cable.
Cheers
Jan 08, 2009 | Televison & Video
JVC HR-D337MS Multisystem VCR - NO SIGNAL The only information I could find on the internet was it was worth $450.00 in 1991. i hooked up the RF out to RF on the TV in. Pushed play on the VCR. No signal....
Connect RF out of VCR to Antenna IN of TV. There should be a Test Signal switch at rear of VCR. Push it to ON. JVC VCRs generally generate a RF signal in the UHF band, around channel 36. Scan all channels on your TV, you should gete a Test signal of 2 parrallel black bars around channel 36. That is the Channel on which you can view tapes. Switch off 'Test signal' at rear of VCR, and press play. you should be able to watch your tape.
Jul 14, 2008 | Televison & Video
JVC HR -J655EK Video Stuck
Hi hannah. The simplest way to remove stuck tapes is to remove the top cover. Usually just a couple of screws. Then remove the stuck tape and put the cover back into place. You can also look for emergency eject hole and insert a snall pin into the hole and attempt to eject the disc while repeatedly twisting the pin inside the hole.
May 16, 2008 | JVC HR-J461MS VHS VCR
Taping shows on a jvc vcr.
Well from memory... you have to Plug in the Antenna to the Video, then from Video to TV, then ya Tune in the "Tuner" section of the Unit.. that outputs on ya TV, then you can simply press the record button(s).. also there is the option of Timer Recording... There was also a TV/VCR switch that had to be toggled on some models... But ya really need a manual I believe the manual is at the below link... www.sharefx.com/archive2.asp?offset=174400
Sep 04, 2007 | JVC HR-S9500 S-VHS VCR
How to hook-up my VCR to NTSC TV?
Zohar, You must remember that various regions in the world have different Broadcast systems. TVs and VCRs are manufactured for playback and Recording in different regions. But, while the JVC HR - J 437MS is a Multi System VCR as far as Playback is concerned, It has only a PAL Tuner. So , while you can watch NTSC Tapes, you cannot tune a NTSC Broadcast through its tuner, and watch on your TV. You will only get a B&W picture. To atleast view NTSC Tapes, use the Remote of the VCR, and set System to AUTO or NTSC. Again, there are 2 versions of NTSC - the 3.58 and the 4.43 ones. Certain regions of the US broadcast in NTSC 3.58, and some in NTSC 4.43. So select carefully, Similarly, bring up the TV menu, and select AUTO or NTSC for TV reception. Now you will be able to view American broadcasts in color.But I suggest you set System to AUTO, as then you can watch your earlier Tapes collection from Europe also. As for connections, it is fairly simple. I am uncertain if your VCR has a 21 pin euroconnector (SCART)but it is unlikely. You will be having Audio L and Audio R out ockets at the rear of the VCR, alongwith Video Out socket. Just connect suitable RCA cables from these OUT sockets to the Video and Audio IN (L) and Audio IN (R) siockets on the TV. select AV input, and you are ready. check it out. 99% it will be work out.
Jun 20, 2007 | JVC HR-J437MS VCR
Aiwa mx100 (al system vcr)
if your vcr is a multisystem, select the proper system in your vcr for the video to be played. but if not, you cannot play your PAL in your NTSC vcr. good luck!
Feb 25, 2007 | Aiwa HV-MX100 VHS VCR
Televison & Video Logo
144 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
