Zanussi F1000 Aquacycle Washing Machine
The machine starts and begins to fill up with water - but makes a low vibrating sound then stops completely including filling with water - this happens on all cycles including spin. Any comments appreciated. ps have checked usual troubleshooting in manual
Thanks
    President:
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. If not helped click "thanks for trying" the prob will come up again for someone else to solve.
Posted on Jan 15, 2008
I HAVE A ZANUSSI AQUACYCLE WASHING MACHINE ZWF1221W. IT WORKs THROUGH THE WASH BUT JUST BUZZES ON THE RINSE CYCLE. I CAN TURN IT TO SPIN & EMPTY AND THAT WORKS AS WELL.
clair you may have a cold water problem, it may have filled with hot water and gone through wash cycle but as it got to rince it only fills with cold water ,the buzzing may be the cold water solenoid staying open and if there is no water passing through it will make a buzzing noise,
1.check the cold water valve # is on . it's what the blue /cold hose is connected to, also in some hoses there is a filter ,it's possible it could be blocked but unlikely.
2. check the cold water hose has not bend in half from the wall valve to the washing machine,this will stop the water flowing.
3. or it's possible you could have a faulty cold water solenoid valve.**
cold water pipe on wall> water valve# > blue cold water hose > * *cold water solenoid valve on machine.
Nov 14, 2016 | Zanussi Washing Machines
Zanussi aquacycle 900
You will probably find that the power fluctuation has blown the controller, the door will not open until it's replaced. You can drain out the water by tilting the machine back &remove the pump, please make sure the unit is unplugged befor attempting any work on these machines, They Will Kill You.
Nov 21, 2013 | Washing Machines
Drum fills withe water when machine is not in use
Can you turn off water to machine? The water seleniod needs to be replaced this lets water in the switch sounds like it's stuck open.
Jul 26, 2010 | Zanussi ZWF1420W Front Load Washer
Zanussi Aquacycle 1050. My washing machine seemed to stop spinnin
Locate the filter at the botton front right of washer, behind a drop down cover.
Unscrew anti- clockwise to remove and clean.
If still no go, then you need to check the brushes in the motor.
Hope this helps.
Dec 31, 2009 | Zanussi ZWF1230W Front Load Washer
Zanussi F1045W Front Load
indicated low water pressure from your external supply or blocked filters in the fill hose. turn water off, remove hose and check filter in end of hose - it is just a bit of gauze. also look into the valve and clean out if needed
Jul 20, 2008 | Zanussi F1045W Front Load Washer
Zanussi aquacycle 1200 smells coming from between the drum and casing.Suspect it is caused by a build up of slime etc.
1. Set the washing machine on the highest water level, temperature on hot and the wash cycle to normal.
2. Fill a gallon jug with hot tap water. Once the cycle begins, let it run for a minute or two, then stop the cycle, open the lid and slowly add the gallon of hot tap water. Don't overfill — you just want to raise the water level so that it is able to reach and clean the inside top rim.
3. Add 2 to 4 cups of household chlorine bleach and restart the cycle. In a couple of minutes, stop it again and just let it sit for at least 30 minutes. Afterward, let the cycle finish, and open the lid to air out the inside.
I got it from this link: http://answers.yahoo.com/question/index?qid=20060827101905AANuYg4
and here:
http://deseretnews.com/dn/view/0,1249,600124768,00.html
Jul 02, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi washing machine wont spin
check the drain hole when you start the machine if the water is coming back out , if yes that means your dump valve is bad.
Apr 23, 2008 | Zanussi ZWF1430W Front Load Washer
Zanussi aquacycle 1000 xc washer
faulty fill valve. or tap not switched on correctly if it has the blue tap remove the top of the tap and use pliers to switch it on
Jan 26, 2008 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
95 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
