Question about Samsung HP-R5072 50 in. Plasma HDTV
Every button on remote turns tv off or on. The buttons on the tv itself do not work.
  • jsharris Jul 14, 2008
    having same problem with Polaroid TDA-03211C.
    jsharris
  • 52 Answers
Harleypastor, Have someone service your front panel buttons. Some could be stuck on causing abnormal operation.
Good Luck.
Posted on Jan 29, 2008
E500i-B1 won't come on.
Suspect a failing power supply
Jan 13, 2017 | Televison & Video
How to program this remote.
Hey mate is there a set button on your remote? or similar type of command, if so, turn the tv on by its main on/off button on the tv itself then stand back and point the remote at the tv, now press the SET button down for a few seconds, if you see a flashing light on your remote this means it is searching for a IR signal, cool now just keep pressing the on/off button on the remote say every 2 seconds, as soon as your TV turns OFF press the SET button on your remote and hopefully it should be tuned in and you can use the remote to turn your TV back on and play with menu and stuff. If this worked dude you can join my... getting a remote to work easy club .
May 23, 2013 | Televison & Video
I have a Mitsubishi 73"
i would suspect your control buttons on your front panel on the set have become shorted. specifically the volume buttom down. This is freezing you control functions. like someone is holding the volume down button all the time. or intermitantly. this cuircit board is on front of the set. I have seen this problem a few times at the shop. The common repair is to replace that button assembly cuircit board. I believe the last time it cost the customer around 85 dollars, but like all things depends on the part and the technician that puts it in.
Apr 21, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
The tv was turned off with the remote 'set' button. Now, none of the power buttons including the one on the tv itself work to turn the tv on. Perplexed.
my remote control will not work after changing the battery on POLAROID ORIGINAL LCD FLU-2632 TV REMOTE CONTROL please help
Dec 12, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
There is shadows on the insdide of the screen
Turn your TV on by pushing either the power button on the front of the TV or the power button on the remote control, which is located in the upper right corner of the remote.
Step 2
Press and hold the "up arrow" button on the remote control. The up arrow button is located in the middle of the remote, to the left of the "Input" button and below the "Picture" button.
Step 3
Press the power button on the TV while still holding down the up arrow button. The TV will turn off and then turn itself back on.
Step 4
Release the up arrow button. Once the TV turns itself back on, it will restore your TV to its factory settings.
Hope this helpout.......
Aug 03, 2010 | Televison & Video
How do i reboot my konka television?
Step 2
Step 3
Step 4
Release the up arrow button. Once the TV turns itself back on, it will restore your TV its factory settings.
Aug 03, 2010 | Konka KDL32AT23U 32 in. LCD Television
The TV is frozen on one channel manual buttons not working nor re
hello here is how to reset your tv. turn on the tv while holding the reset button on the remote control,press the power button on the tv (the tv will turn itself off, then back on again) release the reset button. if this don't work get back to me and we'll try some think else good luck
regards
shaun
Jul 11, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Philips Magnavox TV turns itself off and on
I had a problem that has not been fixed that i had put glass cleaner on my tv and every time i turn it off it comes back on sooo i do not have a solution so i need more and cheap ways to fix my tv.
p.s. i am 9
May 19, 2009 | Philips Magnavox 32PS55S 32" TV
All buttons on tv stopped working only turns ON no ...
There is a button lock in the menu of the television. Using your remote access the menu screen and unlock the buttons.
Feb 19, 2009 | ViewSonic N3735W 37 in. LCD TV
My tv will not turn on.
First of all, forget about the remote and see if the TV functions normally using the buttons on the front of the set itself. If the TV will not power on with the power button on the set itself, then something is wrong inside the TV. If the set works fine from the front buttons but no longer responds to that remote, then the remote has either gone bad or was accidently set to a different brand. In this case, look for the original book that came with the remote (or TV if it is the original remote) and follow the instructions for setting the remote back to Zenith. Try that and post your results here.
Aug 09, 2007 | Zenith C27A24T 27" TV
Samsung HP-R5072 50 in. Plasma HDTV Logo
Jerry Greenberg
Jerry Greenberg
