Question about Loewe Articos 55 55" Rear Projection Television
Blue screen and menus work but hook anything and it tells me no signal
First the color wheel is very noisy. But when it turns on the blue screen comes on bright and clear ( that is on a input with not TRUE signal.) When I hook my dvd player on the component i get audio but I get a blue screen and a small box in the bottom left that tells me I have no signal.
    Problem Solver:
  • 15 Answers
The color wheel bing noisy is a common problem iyt will eventually give a negative type picture, Loewe have now a solution to service this without replacement,I haven't tried it yet but I have one in the wirk shop to do. The second issue is probably a signal board issue, the tv handle menu systems differently from AV inputs. Loewe do part exchange prices on signal boards.
Before you change the signal board test with an AVS input from a camera or something, earlier models were sent out before Loewe had a license for HDCP and this can also cause the problem of no signal.
Posted on Jan 25, 2008
Acer blue screen with warning
Please tell us the FULL brand number and model number of your Acer computer. Then tell us the happenings from the time you turn on the laptop until the blue screen shows. Then tell us what the blue screen warning says.
Aug 28, 2013 | Acer Aspire One 521 532H 533 D260 NAV50...
When I turn the projector, i hear clicking from my AV receiver, the MITSUBUSHI screen then blue screen shows up on the wall, but then it says no signal: then the projector goes to standby without me doing...
The problem is most likely a warped plastic housing around the color wheel. When the wheel is forced to stop, the projector will go to standby and the lights indicate a problem.
Apr 23, 2017 | Mitsubishi HC5500 LCD Projector
It has two yello two black one blue, then two green and two purple
those are probably the speaker wires. one way to figure out the combination is to take turns switching between the balance and fade options on the deck and hooking up a speaker to it at a low volume. when the speaker comes on, you can write down the correct colors and hook them up where they should be in the vehicle. there is probably a white or black line on one of the two wires of each color wire. it represents either positive or negative.
regarding the blue wire, there is only one because this is your remote wire. it controls anything that needs a power signal from the head unit. things like an amp or crossover. if you don't have an amp or anything, cut it so there is no bare wire and either tape it off or use a wire nut. it sends a 12 v signal which will short and blow fuses and ruin your stereo. don't hook it up to a speaker.
Feb 27, 2011 | Kenwood Car Audio & Video
I have a Mitsubishi VS-50604. The sound is working but the screen is blue. No picture. What is the problem?
andychen993,
Depending on how you have your unit hooked up you may have a switch in the wrong position or not have a signal to the TV. Blue screen is the option if no video signal is present. Is your audio going through an amplifier? If so check all the signal feeds to verify that you have a signal going to the TV.
The easiest way to check this would be to hook a DVD up directly to the TV using a separate audio and video cable. If you still have a blue screen I would go into the menus and see if the settings are correct for blue screen.
If everything checks out ok then you probably have a bad small signal board and will need to replace it.
I have a tip at http://www.fixya.com/support/r4425498-basic_standard_tv_troubleshooting which could be helpful to troubleshoot your unit. It explains how to troubleshoot a dead TV but the procedure is the same to isolate a defective board.
Thanks for using FixYa and for the generous rating. We supply these answers for free.
hardrocko
Aug 21, 2010 | Mitsubishi VS-50604 50" Rear Projection...
What color wire hooks up to my amp to subs
Should be a blue one or a blue one with a white tracer. Might be tagged antenna. Sends the signal wire on the amp the signal to turn on.
Mar 26, 2010 | JVC KD-G230 CD Player
The background is blue. how can I turn it white?
Could be a cable problem if not it's a failed lcd
Aug 31, 2009 | Epson Office Equipment & Supplies
Screen color is blue
A blue screen normally comes on in AV or EXT mode, try changing the tv settings back on the controls in TV mode
I hopethis helps
Nov 20, 2008 | LG 32LB9D TV
We just received a big screen tv as a gift and we want to hook up our dvd player and our vcr and have lost the manuals. HELP
You can hook your dvd player in tv by using component video input terminal having green-red-blue colors for video signal and red-white for audio signal. so total 5 wires been used here. color order should be exact at both units, tv and dvd player i.e green to green, blue to blue and so on.
vcr can be hooked at composite video input in tv having 3 pins, yellow for video, red-white for audio in both units, vcr and tv. pins color should be exact on both units.
need further help, post here please.
Sep 24, 2008 | Televison & Video
Sanyo DS32920 Blue Screen
My panasonic Tv pic suddenly turned into a blue color I can't see the pic any more just can hear the audio.....any solutions????
Mar 19, 2006 | Sanyo DS32920 32" TV
Loewe Articos 55 55" Rear Projection Television Logo
272 people viewed this question
Top Loewe Televison & Video Experts
Are you a Loewe Televison and Video Expert? Answer questions, earn points and help others
