Question about HP ProCurve 24x10/100 Mbps Networking Hub
Network is SLOW
Hi Sir,
We just switched from a Lucent DSL-HS-2.3MBS to a Westell 6100 modem, using the same cable to connect to our HP ProCurve 24x10/100 Mbps but now our network is SLOW but the we're clocking over 7mbps on speed test so it's obviously the ProCurve. Cable from modem to hum is same and we have CAT5 running to each computer from there. Computers are mix of Mac OSX, Mac OS9 and Windows 2000. With our old modem we had to apply IPs manually, but the new one seems to dynamically generate them using DHCP and the IPv4 Addresses, Subnet and Router info seems correct. On OSX machines, I have made sure to manually configure to 100baseTX, half-duplex. I have no idea how to do that on the OS9 or Windows machines so I turned those off but our network is still slow. I have no idea what to do. The ProCurve 24 (not 24M) doesn't have a console port and I have no idea what (or how to find) its IP to use the Web interface or even to Factory Reset.
Any light for a network newbie would be super-appreciated!
Miserable in Chinatown.
  • 1 more comment
  • milesahead Jan 15, 2008
    Thanks networkmagic. It's an HP ProCurve 10/100 Hub 24 (J3295A).
    Thank you for guidance on auto-negotiation. I just do not know how to assess how it's been configured or if it ever was configured. Unlike its sister model -- the 24M -- there is no way to connect a console to it. I know the 24M has a Web interface; again, I'm not sure about the 24.
    Still, it seems weird to me that changing modems would have such a massive effect when everything else remained the same. I guess the only other change would be increased bandwidth coming into the ProCurve too . ..
  • Anonymous Jan 06, 2009
    italiani terroni
  • Anonymous May 11, 2010
    I probably wont be able to help much, but I do have some tidbits of advice.
    you said that individual computers still receive network slow downs.
    Are they having problems communicating for file transfer to one another
    without the Westell connected to the network? Make sure that its a
    file thats in the range of 1+gb that your going to xfer. Also, do you have a virus scan program or a
    anti-spyware program such as spybot - search and destroy?
    the Hub is going to be default gateway. That should be it's network address in order for you to go into it and change its settings. If you need to get into the Westell, you can try connecting directly to the Westell modem, have it auto-negotiate dhcp, and see if you can get into it from there after it gives you its IP address if you don't know what it is. Your hp ProCurve may not have a web-interface at all.
    On windows machines, to knock its bandwidth to half-duplex, you need to go onto your device manager, find your network card, and there should be a place in there to manually change the bandwidth settings.
    There may be a firmware update for both your router and your network hub. Go onto both of their sites and check it out.
    Half-duplex means that your computer will send or receive packets of information, full-duplex means that it will send AND receive packets at the same time. half-duplex is effectively cutting down the efficiency of a network into two, just keep that in mind.
    Novelist:
  • 139 Answers
I can assist with the full and half duplex question...but I'll need a specific HP model number for the Procurve in order to give you correct advice about it.
If the Procurve is not configurable, or has never been configured, then it is using autonegotiation to determine speed and duplex. Each of your computers should also be set to auto for speed and duplex.
The general rule of thumb is to make sure that speed and duplex for both ports on a link are set the same. For example, if the port at one end of a cable is set manually, then the port at the other end must also be set manually...to the same speed and duplex values. If one port is set to auto, then the port at the other end of the cable must also be set to auto.
Posted on Jan 15, 2008
  • networkmagic Jan 15, 2008
    This users manual may be helpful, if you don't already have one. The J3295A is not manageable, so the ports cannot be configured. It does support autonegotiation....so it should cause connected devices to set themselves to half duplex.
    It's possible that the negotiation method used by your Westell router is not fully compatible with your older hub. It's difficult to check this without a special tester, but if your Westell happens to be using full duplex, it would explain why you're experiencing a general slowness problem...it's a classic symptom when full duplex meets half duplex. You might want to consider one of the newer LinkSys (or similar) switches as a replacement for the Procurve hub. This is an example that would work as a direct replacement for the ProCurve in your scenario.
6ya staff
SOURCE:
How do i connect my verizon dsl westell 6100 to my belkin g rtr?
Wellll....since it seemed an impossible task, I tried the next best thing.
I bought a wireless adapter for the other pc and voila! they are on the internet, and I am returning the router.
Westell modem + Verizon DSL w/usb = No connection to router.
Dec 28, 2009 | Belkin Wireless G Plus MIMO (F5D9010)
Switching from a verizon 6100 dsl modem to a 327w versalink
make sure that your old setup not still on go to connect to from the start and right click on the connection and see the one that you are using is present
Nov 08, 2009 | Westell Wirespeed VersaLink...
Is there an actuall modem for DSI
There is no modem for the DSi directly, but if you had a Wireless Router connected to a DSL or Cable Modem you would be able to go online with your DSi (Assuming the DSL or Cable Modem is connected and activated with a real Internet Service Provider).
Jul 06, 2009 | Westell Wirespeed LiteLine 6100...
Blinking light on Westell 6100 DSL modem
I have a westell 6100 modem also- The light your are talking about always blinks- it blinks as long as the internet is working (it is sending and transmitting data)
May 28, 2009 | Westell Wirespeed LiteLine 6100...
Switching DSL Modems
Your dsl line stays the same. you're only changing your dsl equipment.
if you are not able to go online using the 327w, you might need to have it configured depending on the type of connection that you have. if you are using PPPoE (which means you enter a username and password on the modem to connect to verizon) you need your 327w configured for pppoe. but if you are using DHCP connection, any modem or routers should be plug and play.
Most verizon customers from the west coast uses DHCP while those on the east coast uses PPPoE.
You can call tech support to make sure which type of connection you are using.
Mar 29, 2009 | Westell Wirespeed VersaLink...
Blinking light means that firmware on your DSL modem just got updated. The modem is pinging the Networ/Computer connected to it. If you open your Modem Page 192.168.1.1 you will see the difference, unless you never have done it before.
Jan 25, 2009 | Westell Wirespeed LiteLine 6100...
Setup DIR-655 w/ Westell 6100 USB DSL Modem
First check if your computer can get on the modem with an Ethernet ( This is to find out if your router will work with your modem) If you cannot get on give your ISP a call to have them configure the modem for Ethernet connection. If you do get on then connect the router to the modem and your computer to the router. You can run the CD for the router or do the connection manually.
Jul 27, 2008 | D-Link Xtreme N DIR-655 Wireless Router
I can't get on line
A blinking DSL light means that you have no DSL sync -- you are not receiving a digital signal. You will need to contact your ISP to have them repair your service.
Steps to do first:
1. Powercycle the modem -- unplug the power from the back for 15 secs, plug it back up.
2. Ensure that all phones that share a line with the DSL have filters attached.
Jan 28, 2008 | Westell Wirespeed LiteLine 6100...
Westell 6100 dsl modem
I use a Westell 6100 modem....internet goes out periodically and is not red...just blank....in a few minutes it comes back on....and later out it goes again....
Dec 02, 2007 | Westell Wirespeed LiteLine 6100...
Can only get dsl if i use landline
Hi, Rob just studied ur problem.Iam a tech which handles this kind of issue. I talk to verizon,at&t,bellsouth,qwest daily for such issues. Well i can suggest u onething u can get the efficient speedstream 4100 series modem which comes with a 1 yr warranty. And also checkout with verizon clearly abt ur distance from the central office.Bcos might be ur dsl circuit may be not technically feasible i:e NTF. For further clarifications plz get back to me.
Jun 07, 2007 | Westell Wirespeed LiteLine 6100...
Open Questions:
See all HP ProCurve 24x10/100 Mbps Networking Hub Questions
HP ProCurve 24x10/100 Mbps Networking Hub Logo
922 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
