Question about Sewing Machines
Only sews a straight stitch
I do not know how to post my solution so I will send it to the tech guys. Ok my problem was that no matter what the stitch type I selected my 373 only sewed a straight stitch. The solution was to adjust the height of the needle via the adjustment inside the head of the machine. The needle was not going low enough but every time it came down it left a little loop two times down big loop, loop gets caught one stitch. But the loop only got caught every second time down so one time down was skipped. STRAIGHT STITCH Problem is fixed now but what is the correct height of the needle off the deck. One more thing when the machine was made the feed plate was misaligned so the factory just put a washer under one side to raise one side up. TACKY ,THANK YOU Just post this please Dale solved 1
  • guidinger Feb 12, 2008
    THANK YOU !
  • Sewing Machines Master
  • 1,388 Answers
NEEDLE BAR HEIGHT
With the pattern selector dial set at maximum zigzag width and when the point of the rotary hook exactly meets the right side of the needle in ascending travel of the needle bar from its lowest position, at the right needle drop position, the distance between the upper edge of the needle eye and the race of the rotary hook should be 3.3 ± 0.3 mm.
You also need to look at the timing
HOOK TIMING
With the needle bar swung to the right at the maximum zigzag width, the amount of ascending travel of the needle bar from its lower position to the position where the tip of the rotary hook exactly meets the right side of the needle should be 1.7 ± 0.3 mm.
Posted on Feb 11, 2008
My White 1788 only sews tiny stitches (in straight stitch setting), no matter what length I set.
Not knowing the make of your machine makes it difficult to answer. However, if you have an older mechanical machine, the feed dogs could be seizing due to old, dry oil.
Wheel on right side that controls the needle up and down is very tight...
Nov 12, 2017 | Sewing Machines
Feed dog dial disappeared into machine. Cannot adjust feed dogs.
tech it to a sewing machine repair guy
who will fish the control back out and remount it
Dec 04, 2014 | Sewing Machines
I have an old Kenmore sewing machine that belonged to my mother...not sure when she bought it. The model # is 17891. The machine will not stitch anything but straight stitch....any suggestions?
If you have a machine that does several patterns and stitches but only stitches straight stitch no matter what you select, you need to change the needle first, if that does not work then the mahine needs to be retimed.
Aug 24, 2011 | Kenmore Sewing Machines
I have an older New Home Sewing machine XR-V11 electronic I have figured out the threading, bobbin, regular stitching and back stitching. It has alot of fancy stitching on it I can get the dial to move to...
It does not matter what pattern you select, if you have the stitch width dial on 0 or set on straight stitch then that is all it will do, to do patterns you need a close stitch length about 2 or if it is not numbered get the stitches close to suit yourself and the stitch width on the widest number.
Mar 06, 2010 | New Home HF-2022
I have a brother vx1065 and don't know how to get it off zig zag
i have a brother vx1065 put big dial to 1 stitch length 1-4 stitch width 0 needle position any presser foot zigzag or straight hope this helps
Mar 28, 2009 | Brother XL-5500 Mechanical Sewing Machine
Selector dial stitches doesn't work
Suggest you ask the seller of yr machine. It runs on computers... They can malfunction. Singers were the Best for decades. From treadle days into the '70's. When a repair guy told me Singer only made parts for 2 yrs post purchase.
I have both of my Grandmother's treadle machines, and their scissors. Would Not buy a Singer, now.
Feb 05, 2018 | Singer Inspiration 4206
Proper Settings
A good standard tension setting is usually around 4.5.
If you find it to be looping on the bottom, raise your top tension. If it's pulling bobbing thread to the top, lower your top tension.
For straight stitch, your stitch width should be set to zero, although on some machines (and I believe your Baby Lock to be one of them,) the stitch width setting will change your needle position.
Stitch length is simply a matter of preference.
-R
Aug 14, 2008 | Baby Lock Ellure
Wont change settings
Take out the needle, tighten the needle clamp screw.
Select the zigzag setting plus the largest stitch width, run the machine quite fast for a few seconds. Turn the hand wheel so the needle bar is at it's lowest, turn power off, get hold of the needle bar and move it side to side half a dozen times.
Turn on power, run the machine again as before.
Go through all stitch type settings zigzag/straight etc and run the machine in each setting.
If after all that the problem is not solved I am afraid you need a sewing machine tech to have a look at it.
It would be interesting to know the make of machine and how old it is, plus when it was last serviced.
Best of luck
Rob
Mar 26, 2008 | Kenmore 15218 Mechanical Sewing Machine
Changing stitches
You probably have not adjusted you stitch width and length.
Also a manual for this machine is currently being sold on Ebay for $4+. Probably would be a good investment for you.
Mar 09, 2008 | Janome MyLock 634D Mechanical Sewing...
Sewing Machines Logo
247 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
