Question about Dryers
Remove blower blade from motor
Dryer began squealing and smoking. Opened cabinet and cleaned all areas per manual. Cannot figure out if it is the motor or the blade that is making the noise. How do I detach the blower blade from the motor. Motor plate says "Hold wheel and turn shaft clockwise", cannot budge it at all.
  • 2 more comments
  • Johan138 Jan 15, 2008
    Kenmore model # 110.97575100 (7571) front loading dryer. Kenmore/Whirlpool Motor model # 279827 (3395652)
  • Anonymous Jan 15, 2008
    Have done that. Now just trying to figure out how to remove the motor itself, bracket clips and bolt holding motor to cabinet are easy to remove. How to disengage the motor from the blower fan blade is the problem, as the motor shaft goes through the back of the cabinet into the blower housing on the other side. There are three screws holding the housing to the cabinet, yet they are behind the blade.
    O.K. almost there. How do I disengage the motor (shaft) from the blower fan blade? to remove the motor itself. The hold down brackets and the bolt on the support brace came off no problem. But the fan blade is still attached to the motor shaft.
  • Johan138 Jan 19, 2008
    blower fan was "married" to the motor shaft and I ended up braking off the fan blade. My new motor comes with a blade so it was not that big of deal in the end. Thanks for your help anyhowse
    JB
    Novelist:
    Scholar:
  • 119 Answers
A guy who has been repairing these for twenty+ years told me sometimes the blower fan is just too tight to remove. If so, you have to use a screwdriver or punch from the motor side and literally break the plastic fan apart. I thought that was going to be my problem, but..... With wrench tightly fastened to the nut at the back of the motor and resting against the post of the rubber wheel, I put a sturdy wrench on the shaft at the front of the motor and whacked it in a clockwise direction with a hammer. It snapped and came loose! Hooray. Try that before you demolish the blower fan.
Posted on Jul 30, 2010
  • 283 Answers
Need brand and if possible model #
Posted on Jan 15, 2008
  • GORDON'S APPLIANCE SERVICE
    It's easier to clean the blower from the back. Remove the back panel and four screws holding the lower part of the the blower housing. You should be able to pull the housing towards you just enough to reach in and see if there's anything in the blades. If you need to remove the housing there are two screws at the top inside. Pull the top panel up to get at them.
    Put an adjustable wrench or vise grip pliers on the hex formation at the hub of the blower that extends through the bulkhead just in back of the motor. Use another wrench on the motor pulley in front and turn it clockwise. With the harness, ground wire and motor mounting clips removed, pull the motor up and out of its cradle while finishing turning the shaft out of the blower wheel.
Loud squeal from Frigidaire electric dryer, tumbler slipping, then smoke and blown breaker
Sounds like the bearing on the motor, had this problem with my two at the same time replaced the bearing and they are both ok now.
also check the back bearing on the machine usually hidden by a plastic cover thats where the squealing comes from they are easy to replace and don't cost much all it is ,is a bit of brass which doesn't last long.
hope this helps.
puggy
Jan 13, 2014 | Frigidaire Dryers
DEGX1 making a clicking noise & mild vibration
Sounds to me like a frayed belt.
www.manualslib.com/manual/889801/Fisher-And-Paykel-Smartload-Degx1.html?page=15#manual
Apr 02, 2017 | Fisher and Paykel DEGX1 Electric Dryer
Makes a irritating squealing noise most of the time?
In a dehumidifier most squealing noises are related to the fan motor or the fan motor shaft. Following the Owners Manual instructions for removing the unit's cabinet for routine maintenance. Lubricate the fan shaft with some light sewing machine oil or a similar oil. That should solve the annoying squeal. And while you've got the cabinet dismantled, do some routine maintenance, like cleaning the refrigerant coils and any other dust or lint you see.
Hope this helps you. Please let me know. Thanks.
May 06, 2011 | Haier HPAC7M Air Conditioner
The dryer rattles in the motor area also the dryer takes a long time to dry.
You have a bad blower . This piece slides onto the motor shaft and pulls the heat thru the drum and out thru the vent hose . It is easily replaced ( and inexpensive if you do it yourself ) by removing the front of the dryer .
Mar 20, 2011 | Maytag Dryers
Model Whirlpool le8650. My dryer stopped working. I noticed the brass clip in the upper right corner just above the door had broke off. I locaated 2 screws that were holding the part that was broken. I...
Unplug the dryer.
Remove the lint filter.
Remove the 2 screws at the lint filter slot.
Place a flat blade screwdriver under the front edge of the top and pry it up. Remove the 2 screws holding the front panel to the cabinet on the right and left sides just inside the cabinet.
Replace the door switch assembly and reverse the above order to re-assemble the dryer.
Sep 19, 2010 | Whirlpool Dryers
Clean Dryer Lint Vent in Kenmore elite HE4
If you wish to clean the interior cabinet of the dryer follow these steps:
1. UNPLUG the dryer. Dangerous voltages are still present even with the dryer turned off.
2. Open the dryer door and remove the lint screen. IMPORTANT: You must remove the lint screen first in order to remove the blower fan housing.
3. Remove the lower toe panel directly below the dryer door by removing the screws under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off. NOTE: For better access, you can prop the front feet of the dryer up (a 2x4 works well).
4. Loosen the screws on the blower fan housing directly below the drum and remove. There's usually a small clip holding the cover in at the bottom that you may need to pull out to release. NOTE: You may also have to disconnect the auto dry sensor plug (yellow wires with white plug - use a small screwdriver to release the locking tabs) and/or ground wire to accommodate removal of the cover.
You should now have access to the dryer interior and the blower fan squirrel cage motor. Take the time to clean out the blower fan housing cover as well. A long bristle brush made for dryers works well at removing any lint inside the dryer in the hard to reach places, followed by vacuuming.
NOTE: After cleaning, you may experience a slight burning odor. This is normal as lint gets stirred up in the cleaning process and can settle on the heating components. The odor should dissipate after a short period of use.
If you have any questions, please let me know. I hope this helps you.
Sep 29, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer doesnt go on
I opened up the lower panel of my kenmore 90 and then removed the blower cover. I found two hair pins lodged in the blower and removed them. I tested the dryer with it open and the blower and drum began to turn again. I buttoned everything back up, and it is running fine now.
Jul 21, 2009 | Kenmore 73952 Gas Dryer
Ler7646eq2 shaking and blower noise
To remove the blower wheel you will need to get it from the front of dryer.You will need to first remove the screws where your lint screen is.Then you will need to lift the top up and remove the front panel.There are 2 1/4 inch screw on the inside part of the front panel on the left and right corner area.After that you will need to take the belt off and remove the drum.After the drum is removed you will need to use a cresent wrench and a pair of vice grips to remove the blower wheel. first take off the motor clip around the blower wheel area then Put the cresent wrech on the plastic blower wheel it is square.wendge the cresant wrench against the drum roller shaft then clamp on your vice on the opposit side of the motor shaft then give it a good turn so that the cresant wrench is pushing aganst the drum rollor shaft that should remove the blower wheel and just reverse after done.Hope i helped
May 18, 2009 | Whirlpool LER7646E Dryer
Squeal then smoke
Bad motor or you are your drum is rubbing on the maching. What does the soke smell like? Like electrical or plastic. I also recommened that you do not use this until either we can get it diagnosed for you or you call a service tech
May 16, 2009 | Washing Machines
Kenmore 110.86874100 Motor (?) Squealing
I don't think they can be, but, also take a look at the fan bearing assembly too. You should be able to isolate if the noise is from the motor bearings or blower bearings.
Jan 26, 2009 | Dryers
Dryers Logo
2,465 people viewed this question
Top Dryers Experts
