Question about Panasonic CT-36G34 36" TV
Power fault Internal 2.5A fuse blowing on switch on
  • Blinglover Jun 10, 2008
    Where is the fuse to try a new one?
    TV just plain died.
    Problem Solver:
Any fuses I have dealt with are behinde the back panel. Depends on the tv size as to how many screws. Usually phillips screw driver and a 4 amp fuse will fix you up. Just unplug the tv, remove the screws for the panel itself, pull the panel, the fuse is a glass tube approx 1" long. A wire in the tube should run end to end. If the wire Is broken, fuse problem. Take the fuse with you to purchase a new one. If you don't have one allready, purchase a surge protector. While the panel Is off try cleaning some of the dust Inside. A shop vac with the hose hooked to discharge works for me.
Hope this helps the Immediat fuse problem, but remember, there is still a reason the fuse blew.
Posted on Sep 26, 2008
  • 2,335 Answers
If a fuse is blowing It means there is a short circuit inside the TV set. I suggest to check the Horizontal output transistor first and the diodes or voltage regulator around the power supply.
Posted on Jan 15, 2008
My RCA audio system shelf does not power on. I changed outlet and check for a defective fuse but to no avail. Any suggestion? It's a RCA 300WATTS 5 DISC AUDIO SYSTEM RS2767I
Could be an internal fuse in the power supply area. Follow the mains cable. However the fuse blowing could be the sign of a fault. If it blows straight away again there is a fault.
Jan 01, 2017 | RCA Audio Players & Recorders
Volfenhag zx 7170 amp blowing fuses what would
blowing fuses alway mean you have a fault with the device, if fuses still blow with nothing connected to the speaker outputs then the fault is internal. if the fuse blow when you turn up the volume that another matter.
Oct 21, 2014 | Car Audio & Video
Power ON/STANDBY switch is blinking only nothing is displaying and i did microprocessor reset.Actually My son was playing with the disc holder he open that and close that suddenly it stop working
OK, i Fix it, after checking the Power-parts in the Subwoofer, i check the receiver, it was the IC-802, a 2,5A Fuse which looks like a little Transistor (on the Print with the 25pin.connector).since the repair it working......
Dec 01, 2011 | Denon S-101 System
Internal fuse on cambridge a1 mk3 has blown and when replaced,blew instantly??
When the fuse blows suspect an overload in either the power supply or Main Amp section.
Check for burnt/damage parts first!
Power Supply faults that will blow the fuse are: Transformer, Rectifier, Voltage Regulator, Large Electrolytic Capictors, Diodes & any other semiconductor connected with it.
Main Power Amp faults are: any semiconductor device on the heatsink.
Jan 04, 2010 | Audio Players & Recorders
Fuse in microwave oven keeps blowing
does the fuse in the plug blow or the internal fuse if it blows the internal fuse it could be one of the door switches two of the switches have a red button on them and one has an orange button its normally the orange one thats at fault
Dec 28, 2009 | Panasonic NN-P295SF Microwave Oven
Unit blew the internal fuse. SONY SA-WMS367 SUB-WOOFER
Bad output IC or voltage rectifier are the most likely at fault.
Nov 28, 2009 | Sony SA-WX700 Subwoofer
No power!
There's an internal fuse - about 20 Amps. It usually blows when the magnetron dies. Unplug the unit from the wall and access the internals. You should plainly see the fuse holder - remove and check the fuse. Spares are available at any ACE hardware store. If the unit is more than 5 years old, I wouldn't mess with it.
May 24, 2009 | LG LRM1260SW Microwave Oven
Fuse keeps blowing
If fuse keeps blowing that means that there is a shortage on AC wiring or switch controlling the air conditioner.
Also an abnormal power draw from AC caused by an internal fault on AC can cause the fuse to blow.
Test wiring and switch with a voltmeter, the most common is that there is a short to ground between wiring and car body somewere.
Apr 29, 2009 | 2000 Chevrolet Malibu
Subwoofer blows the internal fuse when receiver is turned on
possible solution - this can be caused by a fault in the receiver unit. the sub has a triac 'high side switch' circuit that can cause the fuse to blow if it doesn't get a good switching signal e.g. if the receiver power supply is not running at the full voltage. check the plug pack wire for damage, check the 12v input area on the receiver board for dry joints, particularly the power input socket. hope this helps.-pj
Dec 11, 2008 | Bose Acoustimass 16 Speaker
Power supply
Hi have a nice day!
Check if new fuse is of same type that is needed ie 2A , 2,5A as manual says. dont put different.
If you put correct fuse and blows then there is a short circuit at power supply area or after it and your TV must take to a qualified repair shop.
If you are familiar with electronic repairs write me down make and model to look for a service manual available.
Mar 18, 2008 | Televison & Video
Panasonic CT-36G34 36" TV Logo
74 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
