Dim headlights, Dim dashboard lights, Radio not working
Tying to figure out what is causing my dimm headlights, dimm dashboard ligths, and radio not to work on my 2000 Volvo S80. I checked all fuses. Any suggestions?
The door switch is located inside of the door latch. You probably have a bad switch and need to have the latch changed. Since the drivers door gets the most use, that is a good place to start.
Jun 9, 2011 - 2000 TA convertible: The problem started a few days ago, when I turn on my headlights, the dash lights and the radio display slowly dim to ...
Because the bulb(s) are blown - is one guess. Most factory radio lighting is tied to the dashboard lights. You can tell for sure if the radio lighting used to dim when you adjust the dashboard lighting intensity. If they were separate, then it could be a problem with a connection at the back of the radio or internal.
what lights, the dial back lights, is it stock>?
the radios have 3 power sources
1 for radio and amp.
2: dial lamps (dim,) if the other cars dim-able park lamps work then
the radio lamps are bad, or not connected (1 wire)
3: memory. power.
my guess is the rad back lamps are dead.
so turn on the parking lights (Head ligths 1st click)
does dashlight up.? no, turn the dimmmer up.
do they light now? yes, and radio no?
if no radio lamp now, the lamp is bad or wired wrong or the fuse blew
that the dial feed wires to.
if not stock, any thing is possible, (infinity)
just to clarify, the radio lighting goes OUT? or it DIMS...? the lighting is supposed to dim when you turn the lights on (brighter at daytime) and should be controllable by the dimmer switch - the same one that controls the brightness of your dashboard. if the lighting is actually going out, i would suspect a problem the dimmer switch itself. good luck!
The switch that you are talking about... the dimmer switch, must not be working. If you have warranty left, i suggest you take it in. If not, maybe find a good auto wrecker, and replace the switch yourself. I'm guessing they'll be expensive.
From the dashboard. 2 days prior to this my Airbag light fuse went out, I replaced it and now it works fine again. I am not sure if they have anything to do with eachother.
