Question about Radio Shack Pro-97 Handheld Scanner
Pro- 97 scanner
I need specific directions on how to scan just one talk group on my scanner instead of the whole city
  • 204 Answers
Here is a link to a site that has a large volume of info and knowledgeable people on scanning, Post your question there and you'll probably get more info than you really need,,,seriously, they use these things everyday and I'm sure they can steer you in the right direction. Good luck with it,,, Mechanic
http://www.radioreference.com/forums/forumdisplay.php?f=6
Posted on Jan 16, 2008
I can't figure out how to program my Radio Shack Pro-97 scanner!
If you can't program the unit using the instructions in the owner's manual, there's no way anyone can post a workable answer for you here. I suggest that you join a Yahoo users' group for the PRO-97. That way you can pose a problem to a group of users, plus get one-on-one assistance in programming your scanner.
Bill B.
Listening in since the 6y0's.
Oct 10, 2010 | Radio Shack Pro-97 Handheld Scanner
Radio Shack Pro 97 - Talk Group Problem & All Channels Locked out_ Re-Posted
restore the factory defaults .turn off n then on agn after 5 mins.this may help.wish u success bye.
Jun 07, 2008 | Radio Shack Pro-97 Handheld Scanner
Won't trunk track. Searches frequencies, but will not scan talk groups.
This radio will only work on analog trunked systems, if it is a digital or P25 system, you need to upgrade to a digital scanner like the PRO96, or newer.
Jul 13, 2010 | Radio Shack Pro-94 Scanner
How to program a radio shack pro 163 police scanner
The 163 is a trunking scanner, so programming instructions are long and detailed, and they vary for each type of trunking system. Programming instructions are best explained in the factory operating manual. If you don't already have it, you can download/print the manual here:
http://www.scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/PRO-163-164-OWNERS%20MANUAL_2000164_PM_EN.pdf
You may also want to join a users group for the 163. Check Yahoo or just Google PRO-163.
For a comprehensive database of active frequencies and systems in your area, visit:
www.RadioReference.com
The site also has information that explains the workings of trunking systems, links to users groups, and a lot of other useful scanning information.
Bill B
Jul 04, 2010 | Radio Shack Pro-97 Handheld Scanner
800 MHz frequency Mode problem
You have to program it TRUNKING mode when you enter the control channel frequencies. It is decoding okay as the MO shows motorola control channel and +DG means digital decoded and an OPEN group. You need to press the 'trunk' button everytime a talkgroup comes up that you want it to remember for future 'closed' group (-DG) talk groups. I suggest you go to 'RadioReference DOT com" and there are many forums there for your radio, as well as one or two YAHOO GROUPS specifically for your scanner. 73's
Jul 03, 2010 | Radio Shack Pro-2096 Base Scanner
Pro-164 scanner stops receiving when Motorola talk-ids are progra
I had to buy the Radio Shack USB cable 20-047 and install
the driver for it and then I downloaded a program named
"Win97" from the www.starrsoft.com website as listed
on page 21 of the Pro-164 manual. The cable costs
$34.99 and with tax you are looking at about $37.88.
The "Win97" software must be registered for it to work
after a 30-day free trial period. That's approx $25.00.
This is the ONLY WAY to go !! You put in everything
on the software GUI and then upload it to the PRO-164.
Works like a champ !!!!!!
Dec 31, 2009 | Radio Shack Pro-97 Handheld Scanner
Program prblems
your scanner has an attenuater.it lets you program your scanner to reduce scanners sensitivity .check to see if its on or off.
Jan 06, 2009 | Radio Shack Pro-95 Handheld Scanner
Pro-97, only want to listen to EMS
Not being completely familar with the radio system you use... i would presume that your dispatch uses a subaudio tone to "turn off" the squelch on the radio you use as an emt.... if you know that tone make sure it is turned on for the scanner on the frequency that you are using. i presume the id numbers are specific to areas of the city.
Robert
Sep 12, 2008 | Radio Shack Pro-97 Handheld Scanner
Trunking frequencies
Did you initialize your scanner? If you did, then you also deleted your trunking banks (1-9). These are the banks that store the channels that were inputted by you. The scanner will display "All channels locked out," when all of these banks are empty. You may have to put the frequencies in again. I suggest using win97. There is a 30day trial. This is the only program that I know of that will work with this scanner.
The pre-programmed channels should still be there. If you press and hold the scan button for a couple of seconds you should see the signal stalker running.
Good luck.
May 02, 2008 | Radio Shack Pro-97 Handheld Scanner
Scanner not working
Did you use a software program or have radio shack program the scanner for you? If so, check to make sure the banks were selected in the software to be enabled. I assume the your scanner shows 0123****** Now to manually select banks, simply press the number for the selected bank to both select and de-select as warrented. When you press 4, bank 4 will now be scanned. Also, should you press 1, bank 1 will not be scanned.
Feb 08, 2008 | Radio Shack Pro-96 Scanner
Radio Shack Pro-97 Handheld Scanner Logo
42 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
