Question about Intuit Computers & Internet
Quicken Deluxe thinks I'm not connected to the internet.
My new Quicken on my new Windows Vista will not bring up help, says I have an Internet connection problem, yet I note it uses the net to get to other information. I have enjoyed using Quicken for 15 years, and dearly want this on my new computer. but I can't get to setting up my checkbook entrys.
Please feet free to access my computer. I have ZoneAlarm so may have to OK your message. Keep up the good work
Don Godwin
e-mail: dgodwin@cox.net
    Habit-Forming:
    New Friend:
  • 177 Answers
You can be in Quickbooks without bring online, but in order to use help you must be logged in; however you should be able to get into the check register without beng online.
Posted on Dec 07, 2017
SOURCE: how to connect linksys router with aztech adsl modem
1-Go to ip address of aztech modem 192.168.1.1
2-Default usermname and password is "admin"
3-Go to quickstart-> Turn off firewall (uncheck)
4-Save changes
5-Connect modem to router's wan port
6-Go to router setup , and select connection type as dynamic ip.
7-Save and restart modem
Solution 2
1-Go to modem quickstart
2-Select connection type as bridge, save changes
3-Go to router's setup, select connection type as Ppoe, give ur username and password provided by internet provider
4-Save changes
5-Restart modem and router
Posted on Jun 06, 2008
SOURCE: Acer Aspire 4315 can't connect to internet through wireless ADSL router
netsh int ip reset reset.log
netsh winsock reset catalog
Reboot
Posted on Oct 06, 2008
rockitman187
  • 2559 Answers
SOURCE: Quicken 2003 isn't recognizing my cable modem to access internet
Open Quicken and go to the menu bar, Click Edit, Click Preferences to open the drop down window and select, Internet Connection Setup and Web Connect. Options will show the different settings that can be customized.
Please Rate This FixYa Solution.
Posted on Jan 23, 2009
  • 37 Answers
SOURCE: Connected with limited access
This actually sounds like the device is not getting proper DHCP settings.
First of all, power cycle the router, and reboot the computer to make sure a fresh connection from both devices is achieved.
If the issue persists, check to make sure the computer does not have any static IP settings stored in the adapter.
The following steps will tell you how to do so:
-Start
-Control Panel
-In Classic View, select network connections
or
-In Category View, select Network and Internet connections, then select network connections
- Right click the appropiate network adapter (Local Area Connection, for cabled connections, wireless for wireless connections)
- Select Properties
- in the "This connection uses the following items:" Box select the "Internet Protocol (TCP/IP)" (making sure to keep the checkbox selected (selecting the name helps) then click properties.
- If obtain an IP address automatically is selected (and the boxes below are grey), and Obtain DNS Server address automatically (again grey boxes below) are selected then something else may be happening, which will require more advanced steps.
If the boxes are not grey, then you may have incorrect settings, select the appropriate radio boxes (listed above) to make the boxes greyed out, and that may resolve your issue.
Posted on Feb 26, 2009
  • 17 Answers
SOURCE: Can I use 2WIRE 2701HG-B router in COX internet connection
No. A router has 2 main interface types WAN (for the internet connection side, and LAN (for the home network side) the 'LAN' side often has up to 4 ports and wireless connectivity for the home network.
The most common routers available at electronics retail use a CAT-5 connection for the WAN ports and the LAN ports. Your DSL modem/router uses a phone line input for it's WAN port, which uses a signal type that is incompatible with the cable modem output.
If COX doesn't offer a router with the cable modem package, you can go and purchase and common brand of home networking router, and attach it to the output of the cable modem.
Posted on Feb 28, 2009
Tip
Quicken will not print more than seven checks.
You may run into this problem if you use the 2005 or 2006 version of Quicken’s personal finance software (such as Quicken Basic, Deluxe, Premier, Premier Home & Business). If you try to print eight or more checks at once, they won’t print.
According to Quicken Help & Support, Intuit fixed this problem for both the 2005 and 2006 versions of Quicken. You’ll need to download and install the latest patch, which includes the fix for this problem. Quicken offers manual and One Step Update methods to update your version of Quicken with the latest patch. You’ll need an Internet connection to download the patch. If you have a dialup connection, connect to the Internet before you start any of the update methods below. Once you complete the patch installation, Quicken will be able to print eight or more checks.
To read Quicken’s solution for this problem, visit www.quicken.com, click Help & Support, and then select 2006 For Windows (make sure Quicken For Windows and Quicken 2006 appear in the Product fields). Next, type 2997 into the Search field and click Search.
Update Quicken 2005 manually
Visit Quicken Help & Support, select 2005 for Windows, and enter 3810 in the search field. Open the How Do I Manually Update Quicken 2005 For Windows To The Latest Release? link. This page has all of the patches for Quicken 2005. However, you only need to download the patch that has the highest R number. The latest patch carries all of the data from the earlier patches. In this case, you will want to download patch QW05R5PATCH.exe.
Click the file’s link. If you have Windows XP, a File Download – Security Warning may appear. Click the Save button. In the Save As window, choose a location to which you’d like to save the file and then click Save. When the download completes, simply double-click the file to start the patch installation.
(NOTE: This method involves downloading and installing a single patch file. If you don’t have an Internet connection but have a friend who does, you can download the file to his PC and then burn it to a CD [assuming your friend’s PC has a CD-RW]. Use the CD to transfer the file to your computer.)
Update Quicken 2006 manually
Visit Quicken Help & Support, select 2006 for Windows, and then enter 3796 in the search field. Open the How Do I Manually Update Quicken 2006 For Windows To The Latest Release? This page has all of the patches for Quicken 2006. However, you only need to download the patch that has the highest R number. The latest patch is QW06R3PATCH.exe and carries all of the data from the earlier patches.
Update Quicken 2005 Or 2006 With One Step Update
You can also update your version of Quicken using One Step Update. You can start the update by clicking Online Menu and then selecting One Step Update. Next, uncheck any checkboxes that appear and then click Update Now. The tool will download and install the latest update for you.
by: -micromaster
on Mar 19, 2008 | Intuit Quicken Basic 2004 (028287007543)...
Running windows vista service pack 2 but quicken 2014 won't open
One solution would be to run it pretending your Vista is XP. I have seen it done but as I have no Vista machine, I cannot tell you the steps. Search for running Vista in XP mode - once you have managed that, try installing the software.
The second solution would be to open a virtual machine on Vista and running that as an XP machine. Again, I have seen it done.
Try the links I have added below.
The problem I had was with Quickbooks, not Quicken, but the principle is the same and worth a try. Good luck.
Use XP Compatibility Mode in Windows Vista Win7 Vista Windows XP Compatibility Mode in Windows 7 and Vista
Feb 13, 2014 | Intuit QUICKEN 2014 DELUXE
Is Quicken99 compatible with Windows 7 and/or XP?
The best way to install older versions of Quicken on Vista or Windows 7 is to run the setup program through the Windows Compatibility feature:
In Control Panel search for 'compatibility' that will bring up an item 'Run program made for previous versions of Windows'.
Select this and step through the process which will eventually show a list of all programs loaded on the system.
Select the first option 'Not listed'. This will then prompt you for a location of the program.
Click 'Browse' and select the location of the Quicken install program (either CD or disk).
Once found, select the Quicken install program and continue. This will the suggest that the installer run in XP mode. Click 'Next' to run the installer.
Aug 09, 2010 | Intuit Quicken Deluxe 99 for Windows...
I absolutely hate vista....i wasn't able to transfer my microsoft money so had to download quicken and transfer info...then twice now i have had to reinstall quicken because it won't open up...i guess it...
There is a work around to getting Windows XP programs to work under Windows Vista - Virtual PC 2007.
Virtual PC 2007 is a free download from Microsoft and it allows you to install any operating system and run it in a "window" on your Vista desktop.
Download Virtual PC 2007, create a Windows XP virtual machine, install Microsoft Money and transfer in your data. You can install Quicken as well.
The virtual machine will use your PC's actual connections (network, serial and printer but not USB) to connect to devices and the Internet.
Again - this is a work around that is proven to work. One side benefit - you can copy the virtual machine to an external hard drive / USB memory stick and run it on any comptuer that has Virtual PC 2007 installed on it.
Hope this helps
Nov 18, 2009 | Microsoft Windows Vista Ultimate Edition
Cannot open printer from Quicken 2001 Deluxe
Check intiut's website. There have been some problems with 64-bit Windows Vista. You didn't specify whether you have 32-bit or 64-bit operating system.
Aug 09, 2009 | Intuit Quicken 2001 Deluxe (256101) for PC
I cannot get quicken 2002 basic to install on my new computer with windows vista.
That's because Quicken 2002 will NOT run on Vista. Quicken 2005 & 2006 will run on Vista, but will have issues and script errors. Intuit will only ensure Quicken 2007 and newer will work on Vista.
Aug 08, 2009 | Intuit Quicken 2002 Deluxe (78588)
Quicken Deluxe 2009 stopped working
your quicken deluxe 2009 is very OK... i think your system vista 64bit is the problem.. is there any other way that your 64bit vista is updating? if you try to use your quicken deluxe and it might works there.. so this time you are going to system restore your vista 64bit and back the recent checkpoint that quicken is run normally...
Jun 19, 2009 | Intuit Quicken Premier 2009 for PC
Open Questions:
Computers & Internet Logo
66 people viewed this question
Top Intuit Computers & Internet Experts
Alun Cox
Chris Larocque
Mike
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
