Question about ASUS M2N-MX Motherboard
Microphone Hi, microphone is not working as soon as I connect the Mic it say "Wrong Device connected" even though the right slot is connect with the mic. Speaker is working fine. Please help to resolve this issue.
    President:
  • 2,351 Answers
Open system properities. click hardware tab & than device manager. Scoll down to Sound, video & game controller. Do you see a yellow ! point there. That means the driver may need to be reinstalled. Asus is famous for having defective mic controllers & yes the sound works but no mic. You can also open control panel open sound & audio devices. You should have the same device under Audio & Voice. If you do, again your intergrated mic controller is bad. Your manual most likely will not have the correct number to call tech. They moved in 07. So I'll put it in here: 812-282-2787Tech IL Eastern Time. Good luck!
Please vote...........
Posted on Jan 16, 2008
Ac-648 mic not working
Either you have connected to the wrong socket on your computer, or the controls on your computer have not been set up. For example the microphone circuit is switched off or set too low for recording.
Jul 12, 2013 | Cyber Acoustics AC-648 Headset - Stereo...
My microphone is not working. What do I do? Trying to use Skype, but microphone want work
Hi ldlw65,
Please follow the below steps to set up your microphone properly :-
  1. Firstly check if your microphone's cable is in proper order, if it has been damaged, then it's that physical fault which stops microphone from working.
  2. Now if the wire or cable of microphone is OK, check if you have connected your microphone in the correct slot , in your motherboard , usually there is a sign of mic besides the microphone slot.
  3. Then check for the control panel's sound and audio devices option , by going in your control panel, if you open it and go in the audio tab you should see your recording device as enabled.
    If it's disabled then you need to install your audio driver's again.
  4. Now , if everything is ok till here , all you need to do is do a microphone check by going to sound recorder (start >programs>accessories >entertainment>sound recorder )in windows xp , in case you are using windows xp or any relevant software in the other operating system which records audio.
  5. Once you have the application like sound recorder try speaking on mic while you activate the record option , if you see that your sound is being recorded, then your mic is functioning properly, if it's not then you need to check if your mic is the current recording device.
  6. To check if your mic is the current recording device , all you need to do it double click on the volume icon on your task bar and you will have volume control box open , then you need to go to the options menu and choose properties.sajjad4help_2.gif
  7. After you choose properties you will have a radio button for recording , select it and you will find devices for recording , then make sure microphone is selected and click ok.sajjad4help_6.gif
  8. After you select ok , then you need to select microphone from the recording options to activate recording via your microphone.sajjad4help_7.gif
Now you should be able to use your microphone properly without any problems.
Your feedback would be appreciated.
Hope this helps ..)
May 13, 2011 | Toshiba (P000257700) Microphone
My mic seems to pick up internal noise even when muted
Hi, You can check you the connectios or the mic. remember that the mic is too sensitive, you can adjust it with the nobb on the mic by putting it on o -dB and reduce the highs on your mixer or EQ to reduce hiss sound.
But fisr check the connection properly to see if when muted, is muted properly.
Take care.
Jun 08, 2010 | Samson G-TRACK USB RECORDING MICROPHONE...
Acer aspire 5920 running vista has built in mic not working
Hey,
It is all because the Microphone is not set as a default device to start recording.
Its like your computer has no device for recording even if the computer has connected with Mic.
Just change the settings and enjoy..!!!
Check the below link:
How To Install and Setup a Microphone:
http://www.vista4beginners.com/How-To-Install-and-Setup-a-Microphone
Set up microphone:
http://www.microsoft.com/enable/training/windowsvista/srmic.aspx
Hope it helps.
Regards,
Nags
Jan 19, 2010 | Acer Aspire 5920-6727 Notebook
Logitech USB Desktop Microphone. I have Windows Vista. Followed install directions even though outdated. Looks like it is recording, and can save file, but no sound when playing it.
If there are more than recording device, then you have to select default recording device as you MIC connected to coresponding sound card..
For eg, if your MIC is connected to front panel and if the REAR IN is selected as a default device you wont able to record sound in Windows Vista..
To select default recording device
  1. Select your sound properties through the control panel or the sound icon in your system tray.
  2. Click on the properties tab,Check the recording box.
  3. Make sure you have selected the default device upon mutiple device
Please leave me comment, if you still need furthur assistance
RNJ VINOD KUMAR
Sep 24, 2009 | Logitech USB Desktop Consumer Microphone
Labtech 524 microphone does not pick up sound
I have written a guide on How to convert Records and Tapes to CD. I have found that when someone asks me a question like yours here is what I tell them. Go to http://audacity.sourceforge.net/ Download the program Audacity. It is a completely free program. It works great for many audio applications. It does not have spware or adware or anything like that attached to it. In fact many studios use this program. Click on the Download Audacity 1.2.6 link to download the program. Install the program and open the main window. In the middle of the window you will see a field that is labeled Microphone. If the field is not set to Microphone then change it by clicking on the drop down menu. There are two slider controls to the left and right of the small microphone icon. Click on the sliders and set them at about 1/2. These 2 controls are your microphone input level and your Audacity main volume control. Now simply click on the round red record button. Talk into your microphone. If your mic is recording you should see recorded sound waves in the middle of the window. Click on the square stop button and then click on the rewind button. Next click on the green play button. Make sure your computer speakers are turned up. If this doesn't work your sound card may not have recording capabilities or you may have your mic plugged into the wrong connection on your tower. You can move the mic to a different connection and try recording again. Just don't plug into your speaker connection this could damage the microphone. You can check to see if your sound card has recording capabilities by competing the following On your desktop click on start - control panel - sound, speech, and audio devices then click on sound and audio devices. When the small Sound and Audio Device Window opens, click on the audio tab. Under the title sound recording, you should have a sound card listed in that field. For example my card is a SoundMaxDigital Audio. The field is right next to the small microphone icon. If there is no card listed you can buy a cheap one online or even at Wal - Mart. They are very easy to install. You just find an empty slot on *********** board and your computer should recognize the card.
Mar 13, 2009 | Labtec Verse 524 Consumer Microphone
Mic is plugged in correct spot but no voice AT ALL goes through
Mar 12, 2009 | Audio Players & Recorders
Vista 64 microphone not working
hmmm did you try a different mic, and exure its jacked into the mic in of your sound card.. If you have dual sound devices, ensure its in the correct selected device...
1.)To see which device you have as the selected device, Click Start, All programs / accessories / entertainment, volume controll..
2.)Choose Options and then properties
3.)In the mixer device drop down list, ensure that the correct device is selected. Click on the drop down list to see all aviable devices..
4.) Now under the Adjust Volume For selection select recording
5.) In the Show Following Volume Controll Box, select Mic,(make sure its ticked)
6.) Click Ok
7.) The mic and aother controlls will show up, under mic ensure select is checked..
NOW TEST YOUR MIC..
1.)Start, All programs / accessories / entertainment / Sound Recorder
2.) Click Edit then Audio Properties
3.) Under Sound Recording Select the Appiorate device..
4.) Click Record and try it..
5.) Stop it and play it back..
IF THAT DONT WORK REPLY HERE AND WE WILL HAVE A LOOK AT THE DRIVERS..
Jan 13, 2008 | Creative Labs Sound Blaster Audigy LS...
Cyber Acoustics PC Microphone Not Working Anymore
Well to find out if your computer even recognizes it, you need to right click the white speaker on the bottom right of your computer. Select audio devices. More than likely it will tell you it isn't connected.
I uninstalled the sound completely from my computer. Then i restarted the computer. This will reinstall the drivers for your sound and the one you need for your mic. I have vista but this should still work for XP.
-right click on computer (should be on ur desktop or under start menu)
-select manage
-device manager
-click on the plus next to sound, video and game controllers
-right click on the audio (high definition audio device)
-select uninstall
- restart your computer.
This will do the trick.
your computer should recognize the mic.
Oct 27, 2007 | Cyber Acoustics CV-1064 Microphone
ASUS M2N-MX Motherboard Logo
105 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
