SOURCE: Fabric Softner section won't fully drain....
take your soap draw out pull the fabric softener tub out wash leave all of your soap draw in a bucket of hot water scrub with a brush this should clean a small hole which lets your conditioner out simply fix common fault m8
SOURCE: fabric softner
Remove the dispenser tray. Inspect the area just above the fabric softener portion of the dispenser. There should be a series of holes where water feeds into the tray during the rinse cycle. Sometimes these holes become clogged with fabric softener residue. If the holes are clogged, water will never dispense the fabric softener out and it will stay in the tray. If you take some cotton swabs and meticulously clean all the holes out, I bet your problem will go away. Let me know if this was helpful to you.
SOURCE: front load washer
Friend,
ngfam1 At your service!
Try opening the little holes in th softener try that may be clogged up! it's usually this
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
SOURCE: GE Front loader fabric softner wont'
Peace Friend,
Try to find the couple of little wholes in the rear of the softener cup and open them!They are clogged!
If it corrects the problem GREAT!!!
If not only a trained laundry tech can make the electronic diagnoses.
If none of these tasks remedy the problem then here is a good company that's found nation wide.
A&E Factory Service
1(800) 905-9505
You will be fine
Bless You ngafm1
SOURCE: Fabric softener does not drain out of dispenser
Hi. Remove dispenser and thoroughly clean, are you sure you have cold water going into dispenser?
Here is a tip that I wrote about
what I found out about the fabric softener not dispensing into the
washer...
Fridgidaire
Washing Machine Fabric Softner not going into washer
heatman101
