Question about Toshiba Satellite A85-S107 Notebook
Satellite a85-s107 if i fomatted the hard disk will the problem of the keyboard not responding be solved?
    Novelist:
  • 137 Answers
If you were getting nothing from the keyboard, reformatting and reinstalling might not help. You should check the physical connection too. To do this, start up the computer and while it's booting tap the Caps lock button and check to see if the light turns on and off. If it does, than you probably have a good physical connection, if not, you should check the ribbon cable. If the keyboard wasn't working in windows, you can also try to start in "Safe Mode" and .... damn this post is old isn't it.
Posted on Apr 29, 2008
Just formatting the HDD won't help your problem. If u have the original cd that came with your notebook that will fix it
Posted on Apr 02, 2008
Do you have restore disc that came with laptop if you use this to reformat coputer yes it should help
Posted on Jan 15, 2008
How do I change a keyboard on a satellite A85-S107 laptop?
1. Take out the battery and AC adapter, unplugged from the wall, enusre the laptop is fully powered off.
2. Remove those screws with a T-8 or Phillips screwdriver.
3. Turn the laptop back over and open it up. Check and see if the Toshiba Satellite A85-S107 keyboard is tucked under any plastic pieces. If so, find them if those plastic pieces are screwed into anything, and unfasten them as well. If not, it probably uses clamps that can easily be removed.
4. Remove the plastic pieces carefully.
5. Unscrew any screws at the top (if necessary) and remove the keyboard itself from top to bottom. You'll notice that the keyboard is connected with a thin, but wide, data cable to the system board at the bottom.
6. Disconnect the data cable attachment of the keyboard which will sever all the remaining attachments of the laptop keyboard with the laptop computer motherboard. To remove this cable, you have to just carefully pull it out from the socket to which it is attached. Then you can lift out the entire keyboard out of the laptop.
7. Take the new Toshiba Satellite A85-S107 keyboard out of the plastic and place it inside with the right orientation, attach the data cable.
8. Refasten the keyboard in place at the top.
9. If you had to remove any plastic pieces, carefully snap them back in and replace any screws you had to remove.
10. Turn the laptop over and replace all of the keyboard screws.
11. Put the laptop battery back in place and switch it on to check Toshiba Satellite A85-S107 keyboard functionality. If everything has gone according to plan, you should be ready to type away!
Mar 12, 2012 | Toshiba Satellite A85-S107 Notebook
I need to know what type of harddrive my toshiuba satellite A85-S107 uses is it sata or pata ??
The type of hard drive that is compatible with that model laptop is IDE/PATA not SATA.
Regards.
Apr 12, 2010 | Toshiba Satellite A85-S107 Notebook
Toshiba satellite A85-s107 dvd/cd drive has quit working
you should try this start-my computer-right click-manage-device manager -dvd/cd drives-here right click uninstal or update driver.
this should work is your drive in not damage.
Jan 29, 2010 | Toshiba Satellite A85-S107 Notebook
I have a toshiba satellite a85-s107.....got blue screen of death
when ya boot it up...press F8 a bunch of times and try to go to safe mode and try to copy all your files to a hard drive and then put the disk that came with your computer in, and reinstall your operating system and that usually works for me
Dec 27, 2009 | Toshiba Satellite A85-S107 Notebook
I have a toshiba a85 s107 & need a repair disk.
just go to the manufacturers support website, and look for the phone numbers for tech support, give them a call asking for a operating system cd, have your model number, serial number and a credit card ready, you are going to pay like 20 dollars.
Jan 14, 2009 | Toshiba Satellite A85-S107 Notebook
Keyboard replacement
Hello this is for uprading the memory , But does show how to remove the keyboard
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A85/replace-laptop-memory-1.htm
Good Luck .Joe
Oct 07, 2008 | Toshiba Satellite A85-S107 Notebook
Problem running the restore disk for Toshiba A85-S107
I have the same model and i just reformatted the hard drive with the original restore disk and it does loop around several times. That is the way it is suppose to do on this particular restore disk. So don't be afraid if it goes around several times because it is doing different tasks each time it loops.
Nov 19, 2007 | Toshiba Satellite A85-S107 Notebook
Toshiba Laptop Keyboard Malfunction
If you boot a XP cd and select repair will it let you type?
Sep 21, 2007 | Toshiba Satellite A85-S107 Notebook
Toshiba Satellite A85-S107 Notebook Logo
243 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
