Question about Canon PIXMA MP830 All-In-One InkJet Printer
Canon PIXMA MP830 All in One - A600 error
The printer was in the middle of printing when it stopped with an A600 error. I have turned if off and turned it on again, left it turned off for days, still get the same error message. All rather disappointing as I've only had it a month. If anyone can help I would appreciate it. J
  • 9 more comments
  • khirsig Feb 05, 2008
    I have the same problem as of this morning. I read the posted solution, however I cannot find the "sponge to the right of the ink cart". Thoughts? (Ive even taken all the ink cartridges out to check the individual sponges in case I missed something).
  • Anonymous Feb 07, 2008
    I have the same problem, error 6A00.and I can't find the sponge on the rt side either.The problem occured after I replaced 2 of the cartridges.Umi.
  • Anonymous Feb 13, 2008
    PRINTING AFTER I FINISH ERROR CAME UP ON SCREEN A600 TURN THE PRINTER OFF TURN BACK ON AFTER DAYS STILL SAME ERROR
  • Bicycleboy Feb 18, 2008
    I'm getting error 6A00 on an iP5200. Is this the same error with the same solution?
  • Anonymous Apr 04, 2008
    I received the A600 error message after replacing the main black ink cartridge. Tapping and reseating the cartridge and turning it off and on again works to clear the A600 but then when I try to print a new error (5C10) appears. Cancelling that brings back the A600 message. A great little cycle. All in all, I now have a virtually brand new printer that I cannot use. Any help greatly appreciated.
  • Anonymous Sep 24, 2008
    6A00 error arrives on my printer. I found the sponge at the bottom but dont know what to do!!
  • grammie2 Nov 05, 2008
    I have the same problem and I can't find the sponges that where refered to. please help. Thanks
  • chuckmal Jan 03, 2009
    I receive the same error code, but cannot access the "sponge" and other areas mentioned because the the ink tank carriage will not move to the left. It stays in the off position fully to the right and won't respond to pulling - I'm afraid to pull too hard for fear of breaking something.
  • singingsecre Jan 16, 2009
    I have the same problem. Thanks for the tip. It worked.
  • entree18 May 11, 2010
    Ink cartridges hide behind stage curtain - cannot tap felt as suggested.
  • Soulvisitor
    Soulvisitor May 11, 2010
    do you mean 6A00 ? or is it really A600?
    6A00 fix
    There is a sponge to the right of the ink cart that gets pushed up to prime each ink cart. The sponge then drops back down when finished. The problem is that the sponge gets stuck up. Just give it a tap and it will fall down, turn off then on and all fixed
  • 10 Answers
I had the A600 error on my Canon Pixma iP4000R . I looked at all of the help here and here is what I found that fixed my error!!! 12/30/08.
My ink cartridge wasn't moving. I thought I had a paper jam.
SO the "Sponges" on my Pixma iP4000R were black/navy from all the ink. The "sponges" were on the right where the ink cartridge "rests". One was rectangular and one was square like.They were both next to each other. A pen tip will pop them out. They are hard pieces of plastic or something. I was looking for a softer material.
I didn't see the sponges at first as there was a white plastic piece that had a spring attached to it and was moved forward out of its place due to the sponge popping out of its place. I used my pen and pushed that piece back and found that the rectangular "sponge" had popped out of its place.
I rinsed the 2 "sponges" out and they are now white again. I think the rectangular one had so much ink on it it popped itself out of place.
Anyhow. I have pics of what the sponges look like.
Posted on Dec 30, 2008
Here’s what I found.
There is a sponge to the right as stated but right next to that is a white plastic arm assembly with a spring attached to it.
It was the white plastic assembly arm that was stuck and not fully retracted. I tried to move it back and forth and then (pingk) it fully retracted. I powered on the printer leaving the ink caddy to the left and as it was cycling I could see the plastic arm was covered with dried ink. I powered it off and moved the ink caddie to the left again and powered it on again. As it cycled I pulled the power plug leaving the assembly fully exposed. Grabbed some paper towel and put some alcohol on it and cleaned the dried ink off as best I could. I left the caddie to the left as I powered it up to see the assembly work
The printer is working again
Posted on Dec 26, 2008
  • Canon Master
  • 1,113 Answers
6A00 fix
Posted on Jan 15, 2008
  • Soulvisitor
    Soulvisitor Jan 16, 2008
    How do you wish to be helped, by rating unapprriate does that mean that your error is A600? and not 6A00
I had the same error. (a600) The sponge was all gummed up and got stuck. Pushed it down and it cleared the error. Just have to manually move you cartridges to the left (all the way to get your hand in there), and the sponges are located where the cartridges usually sits when your printer is on standby. My normal printer use is pretty light.
Posted on Nov 04, 2008
Hey guys for the ones who don´t know where to find the sponses there on the right side of your printer where the inkt cardrigeds clean, when you open up the printer and move the cart car to the left, on the right you see 2 sponses that can move, push them down furly
Posted on Aug 15, 2008
Where is the sponge that suppoed to drop down? I cannot find it.
Any more specific detail please as I am not a young person?
Bill
Posted on Jul 05, 2008
Getting error code on printer screen A600 why does
Mine kept doing that. My dad found website where lots of people had turned it upside down, shook it and then was fixed, so we tried it and it actually worked!! Now is printing again and no error codes!! Worth a try!!
Feb 09, 2011 | Canon PIXMA MP600R All-In-One InkJet...
MP830 A600 error code
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs replacement. A Pixma MP830 would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidently, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model. And its always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow.
Jan 20, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Our canon Pixma 830 is giving us a error code of 6500. It quit printing in the middle of a page and then wouldn't power up. Now we got it to turn on and now we have this error message
Unfortunately Canon is very little help on this issue... this is what they say..
Issue: ERROR: Error code 6500
1. Press ON/OFF switch to reset the multifunction device 2. The MP830 may require repair
Canon Solution: The MP830 may require repair
Unfortunately, the issue you describe seems to indicate that your product requires repair service. Canon has excellent service options and we are eager to provide any assistance you may need. Click the link below to locate an authorized service facility and obtain further instructions.
http://www.usa.canon.com/consumer/controller?act=ServiceLocatorAct&fcategoryid=238&modelid=12804
Oct 11, 2009 | Canon PIXMA MP830 All-In-One InkJet...
MP830 A600 error with no evidence of ink tank carriage movement
Remove cartridges and head.Unplug unit from wall.
Leave unplugged for an hour.
Plug back in and re-install everything.
This should bring you back to factory.
Let us know if you still have errors ors lights flashing.
Oct 04, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon mp830 printing paused
GO ONLINE AND TYPE
CANON PIXMA MP830 INKJET PRINTER PAUSE PRINTING
OR
CANON PIXMA MP830 PRINT PUASE
OR
CANON PIXMA MP830 FORUMS USERS GROUP
ROD
Feb 09, 2009 | Canon PIXMA MP830 All-In-One InkJet...
I receives error message A600 on my printer
6A00 fix
Oct 21, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Cannon MP810 when turn on display error A600. There is also no light displaying on the printing cartridge.
A600 or 6A00. If 6A00 then the fault code is for the AP motor position error. Error lies with the sheet feed unit, Purge unit or Logic board.
http://www.tradebit.com/filedetail.php/4588588-canon-pixma-mp810-printer-service-manual
This is a complete service manual
Sep 14, 2008 | Canon PIXMA MP960 All-In-One InkJet...
My canon mp830
Error code 5200 means the print head temperature is too high. The only was to resolve this error is either replace the print head or replace the logic board. The print head is available, part number QY6-0061 but you will struggle to find a logic board. The only other thing you can try is resetting the EEPROM on the logic board, this sometimes clears the error. A service manual will show you how to do this: http://www.tradebit.com/filedetail.php/4546483-canon-pixma-mp830-printer-service-manual
Jun 10, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon MP830 Service Error 6000
Canon PIXMA MP830 all-in-one Inkjet Printer
Error code 5C10 on computor screen and on the printer it says 6A00
Jan 18, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
2,348 people viewed this question
old marine
old marine
