Garmin StreetPilot c550 GPS Receiver
Problem for Garmin StreetPilot c550 GPS Receiver
Software Update - Non-working Garmin Lock
By Kevin A on Jan 15, 2008
Ok, this is very complex and I am waiting for Garmin to get back to me on this, but I thought I would put it out here and see if anyone has any suggestions.
I updated the software on my C550 from 5.7 to 6.0. Since then, the unit would "flash" white for a second intermittently, and it lost the ability to repeat the distance when the lower right button was pressed. I spoke to Garmin, and they told me they had never heard of this, and after I asked, told me how to re-install version 5.7. I did this. Unfortunately, they did NOT tell me this would wipe out my favorites, just like a Master Reset which I did not want to do. The flashing seems to have stopped, but the unit still will not repeat the distance. It DOES say it initially. Further, the Garmin Lock no longer functions. The unit comes right on. I have tried to turn the lock on and off, and the unit asks me to set the PIN, which I do. It then asks me to set the Security Location, which again, I do. It immediately goes back to the Garmin Lock screen, as though it worked, but when the unit is powered off and on, it comes right on without asking for a PIN. Anyone have any experience with this? I have since reset, Master Reset and reinstalled all software.
Comments:
Jan 16, 2008
- This kinda fixed itself. The Garmin Lock came back when I plugged the unit back into the car, and with 6.0 reinstalled is back to flashing and still won't speak distance. Garmin has sent me two replies, one stating that they don't support "older" software and the other stating there is no way to get the favorites back (but they did not address the flashing or loss of spoken distance). It seems to be back to where it was prior to my reinstallation of the old software, minus all my favorites.
Jan 18, 2008
- Thanks for the attempt, but I routinely erase the recent selections. Besides, when I re-loaded the previous version, it acted similar to a Master Reset, which removed all of that. I did the Master Reset later as well, so the favorites are good and gone. What I remembered I reinstalled, and as I recall what was in there on a per case basis, I reinstall further. Thanks again, though.
Same Problem
Feb 02, 2009
-   i updated the software and now i have the white flash as well. -   mrc98
Solution #1
posted on Jan 18, 2008
Somewhat Helpful)
audiqv8
Rank: Guru
Rating: 88%, 328 votes
Check to see if "Recent Selections" contain any of your favorites. You can then rebuilt Favorites from the Recent Selections. If the Recent Selections contain any of your favorite just select it and then select Save.
Was this helpful?
Yes
No
Popular Solutions for Garmin StreetPilot c550 GPS
Questions and Unsolved Problems for Garmin StreetPilot c550 GPS
Do you recommend Garmin StreetPilot c550 GPS Receiver?
Answer
Answer
tengo un pleblema con el equipo es que el equipo de garminstret pilot c550 se tranco con el pin de... (More)
Answer
i plug garmin to charger and screen started flashing went blank with backlight on...will not respond... (More)
Answer
forgot my pin number and want to reset the pin number on my garmin c550
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top GPS Device Experts
Top GPS Device Repairmen
in , FL
(408) 298-8188
Auto Nav 2000 Plus, Inc can repair most portable...
Auto Nav 2000 Plus  IS YOUR ONE Stop GPS Store
(281) 371-2722
GeoQuip is a "One Stop Trimble Repair...
Gulf Coast GeoQuip
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
